How do you size the width of tires to the width of your wheels?
Discussion in 'Wheels & Tires' started by Jason12085, May 25, 2023.
  1. May 25, 2023 at 6:51 PM
    Jason12085
    Jason12085 [OP] Well-Known Member
    2013 MGM Access cab
    I know it's a dumb question. I want to run 255/70R17s on my truck, what width rim will make it so the sidewalls aren't ballooning?
  2. May 25, 2023 at 6:53 PM
    Tacospike
    Two Trucks
    :boom:
    HondaGM likes this.
  3. May 25, 2023 at 7:00 PM
    eurowner
    eurowner Duke Sky
    Scoty
    6.5”, 7.5” preferred, 8.5” rim width recommendations.
  4. May 25, 2023 at 7:07 PM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    See the tire manufacturer website and look at the specs for your size, and it will say Approved Rim Width, most are the same for particular tire size among the different manufacturers..Looks like for your desired tire is 6.5-8.5
    Good Luck
  5. May 25, 2023 at 7:14 PM
    Jason12085
    2013 MGM Access cab
    Thanks, I understand that the manufactures recommend a wheel width range for a given tire size. What I'm wondering is what's the difference if I went with a 6.5" or a 8.5" wide wheel? Will the wider wheel or the narrower wheel accomplish what I'm trying to do?
    TBaca11 likes this.
  6. May 25, 2023 at 7:48 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Wider rim will make the tire be lowrider’esque.
    Narrower rim will make the tire have sidewall bulge.
    https://vehiclefreedom.com/does-rim-width-matters-for-tires/
    CrippledHo likes this.
  7. May 26, 2023 at 3:36 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    IMO I like to keep the wheel at least 1.5-2” narrower than the section with of the tire.
  8. May 26, 2023 at 4:22 PM
    DevilsPineapple
    DevilsPineapple Well-Known Member
    Richmond
    Voodoo blue 2020 TRD off-road 6MT
    RRW sliders, lil b's hybrid front bumper, Evo 10s, rigid radiance fogs, Agency6 fairlead and flatlink, DRT cmr, SPC uca's, trimmed front fenders, RRW RR7-H 17x8.5 -12 offset, 255/85/17 Micky Thompson baja boss AT, Litner designs forged acs with two xl pods, UpTop Overland Bravo roof rack, rigid radiance series 40" amber backlit led light bar, oem bed lights, c4 inner fender liners, OEM TRD Pro grill, Nitro 5.29 gears, ECGS bushing kit, bilstein 5100s, 2/1.5 lift, old man emu 2888 coil spring, icon add a leaf, long range America fuel tank, OTT tune,
    Example 17x8.5 255/85/17 Like gotoman said ideally you would go with a 7 to 8 inch wheel for a 255, this insures adequate pressure on the bead when aired down.
  9. May 26, 2023 at 4:23 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @Jason12085 an 8 inch is ideal and won't cause ballooning or stretching of the tire. Avoid 7inch or 9 inch and your golden.:thumbsup:
