How do you remove the rear quarter panel?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hunter75, Aug 1, 2017.
  1. Aug 1, 2017 at 7:22 PM
    Hunter75
    Hunter75 [OP] Member
    2016 Tacoma TRD Off-Road 4x4
    How do you remove the rear quarter panel on a third-generation Tacoma? Do you have to take the whole bed off or can you simply unbolt the one side?
    My back left quarter panel was crushed and I would like to replace it without having to take the whole bed apart.
    Any past experience with this to include photos would be appreciated.
  2. Aug 1, 2017 at 9:47 PM
    Don A
    Don A Active Member
    Don
    Barcelona Red SR5 4x4 Access Cab
    Hi,
    Nasty damage.
    I am not a body repairman but i am pretty sure that the box is not bolted together ... i believe that all of the components (front, both sides and floor) are welded together.
    I am sure that someone with more knowledge than i will chime in to either confirm or correct my statement.
    Don
  3. Aug 1, 2017 at 10:12 PM
    erok81
    erok81 Well-Known Member
    Imposter
    It's a tight squeeze but you can do it without removing the bed. There are around 6-8 bolts on the front. Then the wheel liner and brackets, then the stuff behind the tail light.
    By the end you'll be cursing those front bolts.
  4. Aug 1, 2017 at 10:13 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Here's a diagram of the pieces.
  5. Nov 4, 2018 at 7:56 PM
    mano84
    mano84 Member
    Did you have any luck with this? I have the same problem, but I’m not sure if the quarter panel is welded to the bed. If it’s just bolted on, I’ll attempt to remove it myself. Got damaged in a parking garage in Brooklyn!
  6. Nov 4, 2018 at 9:19 PM
    erok81
    Imposter
    They unbolt. Not too hard. :thumbsup:
    mano84[QUOTED] and shakerhood like this.
  7. Nov 4, 2018 at 10:42 PM
    mano84
    mano84 Member
    Thanks, that gives me a green light, I’ll try and do it myself then
    erok81[QUOTED] likes this.
  8. Nov 5, 2018 at 9:05 AM
    erok81
    Imposter
    Huh?
    It’s not a first gen. They unbolt.
    Nunya Bizness[QUOTED] likes this.
  9. Nov 5, 2018 at 11:02 AM
    mano84
    mano84 Member
    Thanks for the replies everyone. I’m trying to figure out if the rear quarter panel on my 2017 Tacoma (ie 3rd generation) is welded or bolted to the bed. So far your replies are: 2 to 1:
    2 say it’s bolted, 1 says I need a grinder (presumably for welds). Any other input before I attempt the tear down?
  10. Nov 5, 2018 at 11:14 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
  11. Nov 5, 2018 at 11:50 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Bolted - - kinda hard to weld to a composite bed. You know it's not welded to the frame... so what else are you thinking it is welded to? All of the diagrams show the bolts. If you need more, I'll gladly get what I can.
  12. Nov 5, 2018 at 12:33 PM
    erok81
    Imposter
    I’ve taken mine off. They bolt on. There is not a single weld. Here’s my truck if you don’t believe me. Notice those aren’t stock bedsides.
  13. Nov 5, 2018 at 12:45 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    I would look for a paintless dent removal guy that knows what he is doing. Probably $200 and it could look like new.
  14. Nov 5, 2018 at 1:30 PM
    Nunya Bizness
    Yeah I suppose you are correct. I was thinking of a car with seam seal. Spot welds. And a precise cut
    erok81[QUOTED] and mano84 like this.
  15. Nov 5, 2018 at 2:01 PM
    mano84
    mano84 Member
    Thanks everyone, that settles it, I can get on with this now. I’ll post pics when it’s done. Right now this is what I have:
  16. Nov 5, 2018 at 2:52 PM
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    I second PDR If the paint is fine. I had something that was going to require 2k worth of body shop get fixed for 300 bucks by my PDR guy. Damn magicians they are. They really know how to work the metal. I see them using all sorts of braces and tools to bring back some massacres to showroom condition. Check it out.
    Edit: it seems it got hit from the rear. Not so sure if pdr will work with the crushing near the bumper.....
    Nunya Bizness and mano84 like this.
  17. Apr 1, 2020 at 12:31 PM
    Demonblitz
    Demonblitz Angry Smurf Tacoma
    2019 Cavalry Blue TRD OR 4x4
    Bilstein 5100 front struts and rear shocks, Wulf Suspensions add a leaf, 265/75R16 Goodyear Wrangler UltraTerrain tires,
    Alright I'm curious, what happened?
  18. Apr 1, 2020 at 12:46 PM
    Rat_Bastard
    Rat_Bastard Well-Known Member
    Brian
    Tucson AZ
    2016 OR
    Are you replacing with a new panel? I'm also looking to replace mine but the junkyards dont have any available. Or at least in black.
    AceOfClubzs likes this.
  19. Apr 1, 2020 at 1:04 PM
    Demonblitz
    I haven't even been able to find the part online anywhere.
  20. Apr 1, 2020 at 8:31 PM
    ericvega
    ericvega Well-Known Member
    Eric
    2019 MT TRD OR DCSB
    Magnusson Supercharger Kit RCI Skids C4Fab Sliders CBI BedRack Bilstein Bypass Shocks Icon RXT Leaf Pack
    try searching for bedside. I think that’s the correct name for it.
