How do you remove the inner fender screw grommets?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcs4, Mar 23, 2011.
  1. Mar 23, 2011 at 2:55 PM
    bcs4
    bcs4 [OP] Member
    I've searched for hours, and there are many posts about the inner fender, but none specifically addressing the fender liner screw grommets.
    This may be an incorrect name, as there are some grommets that take a flat head and a 90 degree turn. I've got these out already.
    The ones I want to know about are the grommets with the hole in the center.
    Thanks in advance.
  2. Mar 23, 2011 at 2:57 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    if i am correct the ones with the hole in the center must be pushed in while pryed up...
    but i might be wrong...
    aanyway free bump.....
    oh yea buy extra cuz you will alwys break a few
    Catdog likes this.
  3. Mar 23, 2011 at 3:47 PM
    bcs4
    bcs4 [OP] Member
    That hole is deep! Snowing here now, and I put the truck in my tight garage for the night, I'll post here if it works. Thanks for trying even if it doesn't work. I may end up drilling them out..
  4. Oct 22, 2015 at 1:55 AM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    This is a few years old, so hopefully by now someone found a good way to remove these little bastards. I still need to know.
  5. Nov 8, 2015 at 2:56 PM
    drewskie
    Drew
    Burbank, CA.
  6. Nov 8, 2015 at 3:28 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Not sure exactly what you are talking about but if its what I am thinking of, once you pull the center part out the outer part simply pops out.
  7. Nov 8, 2015 at 3:38 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    These are the worst ones. Take a small flathead, pry inwards on one side of the tangs, pull downward on that side, hold that side down while you do the same to the otherside, it will require some coercion, but it will come out.
    You will curse like a sailor trying to pull them out, just know that.
  8. Nov 20, 2015 at 2:49 PM
    drewskie
    Drew
    Burbank, CA.
    Thanks everyone. I pulled two out, took about an hour and like you said, lots of cursing. i said fuck it and just pulled the flare off. Broke most of the blue and orange clips, but luckily I have some replacements.
