How do you remove center caps
Discussion in 'Wheels & Tires' started by Rellik01, May 1, 2012.
  1. May 1, 2012 at 8:27 AM
    Rellik01
    Rellik01 [OP] Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Like the title says how do you remove the center caps from 17" sport wheels?
    Thanks
  2. May 1, 2012 at 8:46 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    With the lug nuts off, they should just pop off. There are little plastic clips that hold them in. I believe you can get them off with the lug nuts on, it's just easier when the wheel is off.
  3. May 1, 2012 at 8:56 AM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    that should do it, if that doesn't work try this...
    verynearlypure likes this.
  4. May 1, 2012 at 8:56 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    No offense, but if you have to ask how to remove a center cap from any wheel, maybe you shouldn't be messing with your truck.
  5. May 1, 2012 at 9:01 AM
    Pugga
    Massachusetts
    Not really... I've removed my wheels plenty of times and never had to take the center caps out. If you just yank them out, the tabs break and they won't clip back in. Removing parts is usually easy, removing them nicely so they go back together can be tricky with all the cheap plastic tabs and clips they use on vehicles these days.
  6. May 1, 2012 at 9:12 AM
    Yamaha Dave
    Have you tried small needle nose pliers that way you can depress the clip and it will come out nice and clean.
  7. May 25, 2012 at 11:18 AM
    rdd11
    rdd11 Well-Known Member
    Ross
    Red Deer, AB
    08 TRD Double Cab long box black
    K&N cold air, Exhaust
    Well that's offensive guy is just asking a simple question if he doesn't know then he will learn not sure but I mess with my truck to learn about it and vehicles in general only difference is I own an automotive repair shop and have
    Mechanics, any tool I need and a huge discount on every part performance or original.
    I'm about to take my caps off to paint them I'll let you know in a few minutes
    Tacolover92 and everymanalion like this.
  8. May 25, 2012 at 11:43 AM
    rdd11
    Ross
    Red Deer, AB
    If you haven't got it yet they just pop out with a flat blade took two seconds
  9. May 26, 2012 at 7:37 PM
    Rellik01
    Craig
    Windermere, Florida
    Small thin flat blade screw driver to pop off center cap.
  10. May 28, 2012 at 8:13 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    those center caps can be tricky- if it does not just pop back into place, your bending or breaking tabs... I personally take mine off prior to a tire rotation so the tire monkeys do not damage the caps :cool:
  11. May 28, 2012 at 10:37 AM
    Large
    Large Red
    I'm not sure about the Tacoma wheels but the FJs have retention rings inside the center caps and it will be a total PITA to take them off without removing those rings. [​IMG]
    Pinch the spring part of it & the clip comes out pretty easily then the center cap practically falls off.
  12. Mar 18, 2014 at 1:18 PM
    samsquamch1981
    samsquamch1981 Well-Known Member
    Tacoma
    i still can't figure out how to take mine off. i pried it with the tire iron and used a flat tip screwdriver..they moved a little, but i was afraid to break the plastic by prying too hard...is there a special spot i should be pressing to make it come off? i have taked many tires off before, and feel like a newb with this center cap. I don't want to have to take the tires off to access the caps if anyone was going to suggest that.
  13. Mar 18, 2014 at 1:35 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I have always had to take the wheels off. With the wheel removed, flip it over and use 3-4 flat tip screw drivers to gently pry the clips back 1 at a time, leaving the screwdrivers in place as I work my way around.
    If they were easy to take off we would be complaining about them falling off:rolleyes:
    UnloadedRex likes this.
  14. Aug 16, 2014 at 7:29 PM
    Twinkie0311
    Twinkie0311 Mall crawling like a boss
    Hillsboro, Oregon
    13 DCLB TRD Sport MGM
    OME Lift w/ Dakars, TRD catback exhaust, 275/70/17 with SCS Stealth 6. and much more.
    Just took mine off using a flat head. Came off fairly easy for me. Thanks for all the info in this thread.
    Now I just gotta wash the wheels and plasti dip them. I ordered those fj trail team black center caps to replace the stock ones.
  15. Jan 31, 2015 at 5:30 PM
    Sparkler
    Sparkler Jedi
    So. Cal.
    2011 Tacoma 4x4, 4cyl.
    Don't feel bad, I'm having the same problem with mine....damn things don't want to come off! Maybe I'll just leave them on. I can get the lug nuts off without removing them...
  16. May 23, 2016 at 5:46 PM
    tgmisso
    tgmisso New Member
    Mississippi
    2013 Tacoma prerunner
    K&N Air Filter, HID headlight conversion, Weather Tech floor liners
    My 2013 tacoma has 2 fastener bolts holding the cap on. Its decieving because there are 4 "dummy" bolts. I figured this out because 2 of the real fastener bolts backed themselves out with normal driving. Now, im in search of the correct replacement fastener bolt.
  17. May 31, 2021 at 4:34 PM
    wm_pops7
    wm_pops7 New Member
    2014 Black Tacoma TSS
    Did you find the replacement bolts? I have been looking with no luck
  18. Aug 23, 2022 at 6:39 PM
    Tacolover92
    Tacolover92 Member
    Blake
    Tacoma 97
    Soon to be everything lol. Not my first toyoter
    Right though?? My first ever vehicle was an 85 Toyota. Not even 24 hours of owning it a High off his rocker college kid t-boned the front end of the truck. Well with my brain I was pretty easily able to see what needed to be done but I had never changed an oil. Never had a dad or someone in my life to teach me those things okay Dicks I had to learn it all myself and the hard way. Anyways I did a front clip swap, swapped carburetors, manifold for headers and full better exhaust. All kinds of fun stuff like that. Before I learned to change an oil. So just because you don't know something random that you've never done doesn't mean you shouldn't be doing it. I never had center caps. My tacoma now is the first rig I've ever had with them. I didn't want to break anything and end up needing something as this is my daily and My first taco, so I looked up how to do it to make sure I wasn't going to do something wrong. Or like the other day taking my stereo out. Super easy thing to do right? Well there was a couple hidden screws I couldn't find and I had to Google it so I didn't break shit. Doesn't mean at all someone shouldn't be working on their own rig. It's called learning and it's what we're all here to do. Teach and share tips and tricks, things you wish you knew before. Don't be toxic or if you want to be at least take it to the Honda pages man
    AxisCab likes this.
  19. Feb 24, 2023 at 5:28 PM
    JakeSouliere
    JakeSouliere Active Member
    2022 Red Tacoma Sport Prem
    All stock.
    Exactly. And I like how his answer starts out with, “No offence.” Pretty much means what comes out of his trap is going to be offensive lol.
