How do you remove center cap ? , factory steel wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hiluxski, Jan 1, 2017.
  1. Jan 1, 2017 at 10:05 AM
    Hiluxski
    Hiluxski [OP] Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Hi all I have a 2017 Tacoma SR model with the factory steel wheels. I can't figure out how to get the center cap off. on the aluminum wheels it has a little notch where you would put a screwdriver or a prybar and pop the cap off. But on the steel wheels there's nothing. do I have to take the Lugnuts off first? To get the cap off.
    Thanks
    tomar likes this.
  2. Jan 1, 2017 at 11:07 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    What does your center cap look like? If you post a picture I can tell you. I know some are on there and pop off and one type the lugs hold it on.
    tomar and Hiluxski[OP] like this.
  3. Jan 1, 2017 at 11:31 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Look closely, If you have the nuts with a washer, then yes, they hold the center piece on....Without the center piece, you would have to have the tapered "acorn" nuts without a washer..!!
  4. Jan 1, 2017 at 12:13 PM
    sodaryl
    sodaryl Well-Known Member
    Daryl
    Vancouver, BC
    2016 Blazing Blue DCSB M/T Sport
    -Relentless Off-Road sliders -265/70r17 Wrangler Duratracs -Diamondback HD -CCG Mesh grill -Pop & Lock PL8535 -BPF Heavy-Duty Front Tow Hook
    Drive on a really bumpy road...
    Thankfully I heard it pop off and saw it in the side mirror so I grabbed it and put it back on! On the TRD Sport wheels it's a kind of compression fitting, so a bit of pulling and prying should have it off fairly quickly.
  5. Jan 1, 2017 at 5:44 PM
    Hiluxski
    Ventura California
  6. Jan 1, 2017 at 5:48 PM
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Mine came off with little effort when I swapped a flat tire off. Forgot to put it back on until after the fixed tire/wheel was back on, and it just snapped into place with some mild tapping. Should be reasonable to pry off, my guess is there's a notch that the provided tire iron will fit jnto.
  7. Jan 1, 2017 at 5:51 PM
    Modesto Tacoma
    central california
    LIMITED 4X4
    That one should pop right off. Since it's brand new might be little tougher.
    tomar likes this.
  8. Jan 2, 2017 at 10:17 AM
    Hiluxski
    Ventura California
    Thanks for everybody's opinions and help. I just checked the center cap And there's nowhere to put a screwdriver or a prybar no little slot like there is on alloy wheels.
  9. Jan 2, 2017 at 10:46 AM
    over60
    Muskoka, Ontario
    Check your nuts, as I mentioned above..!! :)
    And, ...is that center piece made of metal, or plastic.....??
  10. Jan 3, 2017 at 12:33 PM
    Hiluxski
    Ventura California
    The center cap is made of plastic
  11. Jan 3, 2017 at 12:50 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Pretty sure (99.9%) those steel wheels have the acorn nuts. That cap has to "pop" off.
    G.
  12. Jan 3, 2017 at 2:24 PM
    over60
    Muskoka, Ontario
    I'm with you man... if it's plastic..it has to pop off...
  13. Jan 3, 2017 at 3:25 PM
    tincup33
    tincup33 Well-Known Member
    Beaverton, OR
    2021 TRD S AG DCSB
    On mine (granted they aren't these steel wheels but this looks similar) I had to flip the rim over and deal with the tension wire inside the center cap to get them off. You can get a small screwdriver in there and pop the wire out, then the caps should pop off.
    Also, you may want to reverse this order when putting them back on, I found that one of the tabs on the inside of my center cap would bend if I tried to put them back on after putting the wire back inside while the caps were off.
  14. Jan 3, 2017 at 3:31 PM
    R.Shaw
    R.Shaw Well-Known Member
    2016 Tacoma 4X4 TRD
    Left hand three fingers in lug holes, right hand three fingers in lug holes. Push hands together and at same time pull.
    tomar, over60 and Farcedude like this.
  15. Jan 3, 2017 at 5:37 PM
    over60
    Muskoka, Ontario
    That should work..:thumbsup:
  16. Jan 4, 2017 at 8:41 PM
    texastonka
    texastonka Member
    Justin
    Austin, Tx
    New. Stock. 2013.
    I have 4 black trd center caps I bought for 2013 Tacoma / Toyota for sale. New in box.
    Havanero likes this.
  17. Jan 6, 2017 at 4:29 PM
    oldman52
    oldman52 It's a Truck!
    Raytown, MO
    2016 Tacoma TRD Off Road DCSB 4x4 MGM
    5100's front and rear on stock OR coils set at .85 with 1/2 spacer LF, 1/4 spacer RF. LED interior lights. OPT7 LED low/high lights. Morimoto LED fog lights. Philips LED front turn and side marker lights. Philips LED rear tail/brake/turn all in one mod with license plate lights. ATX Series 202 matte black 16"x 8" alloy wheels. Goodyear Authority MT 265/65/16C tires. Matte Black painted OR grille with MGM painted front emblem. SR5 OEM fog light covers. Gloss black bedside decals-tailgate inlay. Subdued US flag decal each side and vehicle badging, Triple black custom Clazzio seat covers with custom embroidery TRD on head rests. TRD cold air intake. TRD cat back exhaust. TRD skid plate painted MGM, w/black vinyl TRD inlay by Rrentrop. Shift Sense Pro V2. Salex center console divider tray. Center console TRD coin holder with lid by Mesojdm. Total Chaos bed stiffeners. Engine cover decals by Rrentrop. TRD oil and radiator caps. Cheap Speaker Mod; Subaru tweeters - Kicker DS Speakers 6"x 9" front, 6.75" rear. RedLine Quicklift Plus hood damper struts. Noice 50mil sound deadening on front and rear doors. GassHole gas cap holder by Mesojdm. Ultimate LED turn signals by Mesojdm. Custom radio knobs by Tacowiede.
    I have been wondering if 16" TRD plastic center caps will fit on my stock off road wheels or the SR dark alloy wheels I also have? I would think the Pro center caps would or even the Baja TRD center caps. I have tried looking on line to see if they are compatiable but have had no luck!
  18. Apr 9, 2017 at 12:53 PM
    rjlem
    rjlem Well-Known Member
    Rick
    Franksville, Wisconsin
    2011 Reg Cab 4WD 2.7 A/T Bought used
    Int. Wipers, OEM Cruise, Fiamm Horns, Access Cover, Bed Mat, WeatherTech Floor Mats,
    Hiluxski, any luck getting your caps off?
    I'm in the same boat, I can't see a notch.
  19. Apr 9, 2017 at 11:11 PM
    Hiluxski
    Ventura California
    Yes, I just got them off yesterday they come off with the Lugnuts
  20. Apr 10, 2017 at 10:09 AM
    rjlem
    Rick
    Thanks!
    That's kind of what I figured looking at it.
