How do you remove a fuse?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by the_tick, Jan 21, 2009.
  1. Jan 21, 2009 at 4:17 PM
    the_tick
    the_tick [OP] Active Member
    Lake Mary, Florida
    07 Tacoma Reg Cab
    OK, sounds silly I know. But what do you use to pull out those tiny fuses? And what are those fuses called? Mini ATM? They sure are tiny.
    CaptainBart45 likes this.
  2. Jan 21, 2009 at 4:34 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Not silly if you havent done it! Well you can either use a pair of needle nose plyers (thats what i do most of the time) or you can buy a cheap fuse puller outer thing at any automotive store. they are plastic and very inexpensive. I have one but when i cant find it i just you needle nose.
  3. Jan 21, 2009 at 4:34 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    There is a fuse puller in the fusebox lid under the hood. Also, those aren't ordinary mini ATM fuses. They are a new generation that don't have the long legs. The legs run down the sides.
    Marc M
  4. Jan 21, 2009 at 4:35 PM
    Dustin03
    Dustin03 The Cooler King
    Arizona
    Expeditionary vehicle in training.
    Old Man Emu 2.5" lift, brush guard (about to be changed), grey-wire mod, custom bed mounts for 4 jerrycans, custom survival box, maglite mount, KC Dayliters.
    ^^^ That's all the information you need!
  5. Jan 21, 2009 at 4:45 PM
    the_tick
    Lake Mary, Florida
    07 Tacoma Reg Cab
    you guys rule! i'mgoing to check now to find the fuse puller. now about the fuse size. i can buy tose at an auto parts store right? even if i get the ones that stick out a bit, they will work, right?
  6. Jan 21, 2009 at 5:04 PM
    Marc M
    Marc
    '06 TRD O/R Dbl-Cab
    Most parts stores sell a little kit with the new style in various amp sizes. I purchased my little kit from Advanced Auto.
    Marc M
  7. Nov 29, 2020 at 12:54 PM
    J4keFr0mSt4teF4rm
    J4keFr0mSt4teF4rm Member
    2011 tacoma regular cab
    I have no heat and I am guessing its my 50 a fuse. How can I pull this out? Is there a special trick? Any ideas help thank you.
  8. Nov 29, 2020 at 1:02 PM
    Muddinfun
    Muddinfun Well-Known Member
    We tried to help you in your other thread, but you bailed.
    Guessing at component replacement is a lot more expensive than diagnosing the problem and replacing the faulty component. Besides that, if the 50A fuse is blown, a new one will also blow.
  9. Nov 29, 2020 at 1:07 PM
    J4keFr0mSt4teF4rm
    You did? Sorry I dint remember that but how do you mean? So replacing the fuses won't do anything for me?
  10. Nov 29, 2020 at 1:10 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I tried to pull a starter relay from a taco at a junkyard and I couldn’t get it out.
  11. Nov 29, 2020 at 1:11 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    If it blows another 50A you've got something wrong.
  12. Nov 29, 2020 at 1:12 PM
    Muddinfun
    Nope.
  13. Nov 29, 2020 at 1:13 PM
    J4keFr0mSt4teF4rm
    I dont even knoe how to get the initial 50 a fuse out. Thats what I'm trying to figure out. Would having too many red cords attached to the battery cause a problem? I'll take any suggestions. Thanks again
  14. Nov 29, 2020 at 1:14 PM
    J4keFr0mSt4teF4rm
    I've replaced the resistor, blower motor, ac hack control panel only the recirculating air and ac buttons do anything.
  15. Nov 29, 2020 at 1:19 PM
    Muddinfun
    Jimmyh, Too Stroked and Drainbung like this.
  16. Nov 29, 2020 at 2:21 PM
    J4keFr0mSt4teF4rm
    Alright so I fixed it and your kind of a prick
  17. Nov 29, 2020 at 3:46 PM
    Muddinfun
    How about if you grace us with your presence and make a worthwhile contribution to TW by explaining exactly what parts were actually bad, your logical conclusions that led you to replace a whole bunch of components and where you went wrong replacing functioning OEM components with inferior aftermarket parts.
    Oh, and out of morbid curiosity, post a pic of all the “red cords” attached to the battery. I’m curious if any of them have fuses.
  18. Nov 29, 2020 at 5:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Fuse types for future references.
    This is from the manual of the 2007 Tacoma.
    Notice that some have holes in the legs.
    This can sometimes mean you will have to physically unbolt it from the box.
    63A79D97-DA33-4AF9-8CFD-A86B01CEEA7F.jpg FBBDD86D-F235-4E83-8D46-6C4B66CBF5F5.jpg A96101BC-B42B-43E6-982D-E0E150E19BBE.jpg
    CGoss likes this.
  19. Nov 29, 2020 at 5:13 PM
    Muddinfun
    What’s with good & brown? Is that blown spoken with a Texas accent or is that a bad translation from a nonenglish origin?
    Thatbassguy and TnShooter like this.
  20. Nov 29, 2020 at 5:14 PM
    TnShooter
    Deogee
    STOCK
    Lol. I noticed that and I have no idea:confused:
    Maybe it’s a “translation” error.
