how do you put the wheel in the tire?
Discussion in 'Wheels & Tires' started by dpak, Sep 7, 2011.
  1. Sep 7, 2011 at 9:51 AM
    dpak
    dpak [OP] Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    I will be purchasing wheels and tires separately and trying to find ways to save money. Rather than a paying a shop to put the wheel and tire together, is there a safe and easy way to do it yourself? Or is this something that shop should do?
  2. Sep 7, 2011 at 9:53 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    you need a shop. or a friend that works in a shop :D
  3. Sep 7, 2011 at 9:58 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You can do it yourself but you'll scratch the hell out of your rims and there will be lots of choice 4-letter words. I've done it with ATV tires and that's a hell of a workout, truck tires wouldn't be fun to mount on your own. You're much better off taking it to a shop. Even if you did manage to mount the tires on the rim, you have no way to balance the tires.
  4. Sep 7, 2011 at 10:01 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    they are actually quite easy to mount but if you have to ask how, you probably should do it yourself my 2 cents
  5. Sep 7, 2011 at 10:09 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    me and my brother have done it with a forklift, pry bar, driving another car on top of the tire/wheel with desired tire on it (we were doing a swap). lots of cursing and scratched rims as mentioned before. just take it to a cheap shop that will do it is your best bet. . . . another idea, some high schools (mine did) with auto mechanics class have tire changers. guy that was a grade below me's family owned a tire shop. we'd take our tires in there and he would do it like a pro. so if you got a little brother, cousin, whatever in a high school shop class you could try that. free!!
  6. Sep 7, 2011 at 10:20 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    or go to a technical school/city college with auto shop..worth the shot.
  7. Sep 7, 2011 at 10:20 AM
    dpak
    Richmond, VA
    Thanks for everyone's input and you all have convinced that this is not task to do yourself. I guess I'll be packing PB&J sandwiches to work for the next few months to save money.
  8. Sep 7, 2011 at 10:22 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Find a local independent tire shop that has a hydraulic mounting machine..shouldn't cost more than $50 to get all 4 done.
    Once they're mounted they will need to be balanced.
  9. Sep 7, 2011 at 11:26 AM
    Mescalero
    Mescalero Beretta Taco
    Anderson, SC
    '15 DCSB TRD PRO Mag Gray
    Find a walmart. Bastards only charge $5 to mount each tire and $5 each to balance ($7 per for lifetime balancing).
    Cheapest option i believe.
  10. Sep 7, 2011 at 11:32 AM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    Many shops won't charge you for mounting the tire if you do the balancing with them. That's what happened to me. I ended up paying like $20 out the door with tires mounted and balanced.
  11. Sep 7, 2011 at 11:36 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Get down to the local Harbor Freight store...I have used one of their cheap machines to mount over a hundred motorcycle tires over the years...
    Howard
  12. Sep 8, 2011 at 12:34 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    They will only mount new tires.
    So watch what you bring in..
    and some are stifflers..will only charge that fee if you buy tires from Walmart. Douches.:cool:
