How do You program keyless entry on 2007 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jack Patton, Mar 14, 2008.
  1. Mar 14, 2008 at 9:36 AM
    Jack Patton
    Jack Patton [OP] New Member
    Tacoma Sport Prerunner
    Bull Bar, Side rails, K&N filter, Rubber bed liner
    Hi Ya'll need some help,
    have a new keyless enty fob and need to reprogram it to open doors
    I have seen several post either for the RSVIP system or older Tacoma's.
    So far all those posted havent worked yet. :mad:
    JP
  2. Mar 14, 2008 at 5:47 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    I've found out on these forums that each Toyota region seems to have some what different tricks to program the alarms, fobs, ect.. You might add what region your in and others might speak up. Other wise maybe the dealer yet.
  3. Mar 24, 2008 at 4:07 PM
    bluebell
    bluebell New Member
    2005 Tacoma Access Cab 4wd TRD
    www.programyourremote.com states for a 2006 Tacoma:
    1. Start with the key out of the ignition. Open the driver door (all other doors are closed). Driver door is unlocked (other doors don’t matter).
    2. Perform these steps within 5 seconds
    a. Insert the key into the ignition (don’t turn it) Pull key out
    b. Insert the key into the ignition (don’t turn it) Pull key out
    3. Perform these steps within 40 seconds
    a. Close, then open the drivers door.
    b. Close, then open the drivers door.
    c. Insert the key into the ignition (don’t turn it) and pull it out.
    4. Perform these steps within 40 seconds
    c. Insert the key into the ignition and leave in the ignition.
    d. Close the drivers door, Turn the ignition to ON (as far as you can go without cranking the engine), then back to off .
    e. Remove the key from the ignition.
    5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
    6. Perform these steps within 40 seconds
    a. Press the lock and unlock buttons on the transmitter simultaneously for 1.5 seconds
    b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
    7. Open drivers door
    Hope this helps, I've come across the need for this type of programming on other vehicle before and I have referred to this website with success before.
    Tex-Tac and HankG99 like this.
  4. Mar 24, 2008 at 7:33 PM
    dbbd1
    dbbd1 Well-Known Member
    Let us know if it works for the '07's too.
  5. Mar 25, 2008 at 8:28 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    So, what does this do? Just let you use a new remote?
    What I'd really like is some way to automatically lock the doors when truck is put into gear.
  6. Mar 30, 2008 at 1:01 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Hope this can help you out. Its kinda long.
    For 2001+ Tacomas equipped with a factory alarm or keyless entry, here are some programming options that allow you to adjust the way your locks work.
    The first programming option allows you to set the entry unlock to: (A) unlock the driver door with one push, and the remaining doors with a second push OR (B) unlock all of the doors with a single push.
    1. Open the driver's door. Remove the key from the ignition switch.
    2. (Complete these steps within 40 seconds)
    A. Insert the key into and remove it from the ignition switch 2 times.
    (IN - OUT - IN - OUT)
    B. Close, then open the driver's door 2 times.
    (SHUT - OPEN - SHUT - OPEN)
    C. Insert the key into and remove it from the ignition switch 1 time.
    (IN - OUT)
    D. Close, then open the driver's door 2 times.
    E. Insert the key into the ignition switch and leave it in.
    F. Close the driver's door.
    G. Turn the key from LOCK to ON 4 times, ending at LOCK
    (LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK)
    H. Wait for the locks to stop, then remove the key from the ignition switch.
    3. On the key fob, press and release both LOCK and UNLOCK buttons at the same time.
    A. [For all doors unlock] press and release the UNLOCK button.
    B. [For driver door unlock] press and release the LOCK button.
    4. Open the driver's door. The programming is complete. If programming did not occur, start over.
    The second programming option allows you to set the doors to lock when when the key is turned on, and unlock when the key is turned off.
    2. (Complete these steps within 30 seconds)
    A. Insert the key into the ignition switch.
    C. Turn the key from LOCK to ON 5 times, ending at ON
    (LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON)
    3. Programming option (select one of the following).
    A. [Ignition controlled lock ON] Close the driver's door.
    B. [Ignition controlled lock OFF] Close the driver's door twice, leaving it closed.
    (SHUT - OPEN - SHUT)
    4. Turn the key to LOCK. The programming is complete. If programming did not occur, start over.
    When performing the programming, the park lights may or may not flash to confirm that the program was accepted. The only way to confirm the programming is to test them to see if they are functioning as desired.
    Tex-Tac likes this.
  7. Mar 30, 2008 at 8:12 PM
    sawdust
    Frisco, TX
    luk, have you had success with this? I've tried that. No dice. It's for the 1st gen tacos.
  8. Mar 30, 2008 at 9:29 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Sorry I posted the wrong one, and after you brought it to my attention I then realized that when I sold my previous 2002 Prerunner and bought this one I deleted the old codes but actually I deleted the ones for the second gen tacomas. I just wasn't paying attention sorry again.
  9. Mar 30, 2008 at 9:46 PM
    4x4x4trd
    North Texas
    Talked to a Gulf States tech. awhile back and he ran my vin. # and told me the following:
    I have the S6 security upgrade on the sticker. This is the 3200 system. He told me there are only 3 things you can program on the 2nd gen. trucks with this system. This is the 20 sec. headlight on or off feature during the arming, and or, disarming of the system with the fob. The other is passive automatic arming of the system. The ignition on, door lock or ignition off, unlock is no longer an option with this security system or by programing the trucks main computer. It is just not available now. This is on GST trucks anyway. As stated in another thread I would have just gone with the keyless entry which came with my TRD truck and the new chiped key given the amount of options in programming this system for the cost. Later
  10. Mar 31, 2008 at 3:37 PM
    sawdust
    Frisco, TX
    Understood. I've got a Gulf States truck, but no alarm, just the TRD keyless entry. I'm looking for programming for that.
  11. Mar 31, 2008 at 5:41 PM
    4x4x4trd
    North Texas
    You've got all your gona get.;)
  12. Apr 26, 2008 at 3:28 PM
    cardogie
    cardogie New Member
    hawaii
    07 tacoma sr5
    thank you
  13. Apr 27, 2008 at 5:59 PM
    99TRD
    99TRD Well-Known Member
    17 Tacoma TRD OR DC Auto V6
    Smoke headlights, improved LED tail lights...Pending: De-chrome badges and grille, new tires
    Is there a way to get the horn to beep when it locks? Mine is silent, but it locks the doors and the lights flash.
  14. Apr 27, 2008 at 6:05 PM
    99TRD
    Disregard the last post. Looks like its a whole thing to get the beep.
    Shoulda done a search before posting.
  15. Jan 14, 2009 at 6:37 PM
    warrantbird
    warrantbird Member
    Romeo
    El Paso, TX
    08 TRD Sport, DC, LB
    2.5 Suspension Lift, TRD Cold Air Intake, Banks Monster Exhaust, Doug Thorley Short Headers, Toyota Brush Guard & Running Board, BAK Flip Tonneau Cover, XD Hoss 17X9 Wheels, Elusive Elements Grille
    :):) Thanks for the great information. I used it on my 08 and had no problem.
  16. Jan 21, 2009 at 6:00 AM
    bspencer505
    bspencer505 Active Member
    09 Tacoma 4x4 V6 TRD Offroad w/JBL
    None
    I've read everything - It appears this is it. However I'm posting anyway - JUST in case The 09's are different. There are some differences between the 08's and 09's. For example VSC is a standard now. Maybe the the remote programming has changed too.
    Does anyone have the keyless remote programming instructions for the 2009 Tacoma? I have the standard keyless system that comes with the offroad package. No alarm, just vehicle anti theft system.
    There are a few options I miss from my Silverado (You dont miss em until they are gone):
    1. Marker lights go on when truck is remotely locked and unlocked
    2. Doors auto lock when truck in put into drive or auto lock when truck hits 5 to 10 miles per hour
    It appears the above is not available on the Tacoma???
    I also miss my automatic headlights. However with the Tacoma if you leave the lights on they will go off when the key is off and removed. So its kinda auto headlights.
    Still love the truck though.
  17. Jan 23, 2009 at 12:37 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    worked on my 08 as well. beats paying money at the dealer!:cool:
    Thanks
  18. Feb 4, 2009 at 6:20 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    just got my 09 trd taco, the salesman said he programmed the remote before i jumped in. It honks and beeps when you unlock or lock the truck, when you put it in gear all doors lock and when you take out the key all doors unlock. I am trying to get the horn to shut up since I leave at 4:30 in the morning, dealer is a pain in the a$$ to get to with socal traffic.
  19. Jun 5, 2009 at 10:12 PM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    Actually step H is backwards on post #6. Remove the key from the ignition. Wait for the locks to stop firing, then proceed as follows.
  20. Sep 10, 2009 at 5:09 AM
    Scott_in_Charlotte
    Scott_in_Charlotte New Member
    Scott
    Charlotte, NC
    2007 Tacoma TRD
