How do you get a wider stance on a 2nd gen taco?
Discussion in 'Wheels & Tires' started by veet skeet, Sep 24, 2011.
  1. Sep 24, 2011 at 10:43 PM
    veet skeet
    veet skeet [OP] Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    Just like the title says. How do you get a wider stance on 2nd gen tacomas without the use of wheel spacers?
    I want to widen the stance of my truck, but I don't know how. What things do I have to do or get to widen my trucks stance? Thanks!
  2. Sep 24, 2011 at 10:45 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Different backspacing on your wheels or you could go Long travel.:D
  3. Sep 24, 2011 at 10:48 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
  4. Sep 24, 2011 at 10:50 PM
    veet skeet
    Cali
    What's the most backspacing you can get on your wheels for a tacoma?
  5. Sep 24, 2011 at 10:53 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Idk. you could start rubbing you cab mount if you go to much, but idk where that point it.
  6. Sep 24, 2011 at 10:57 PM
    veet skeet
    Cali
    Here's the setup I have right now.
    Bilstein 5100's all around. Front at 2.5'
    I don't have any lift in the back so the front is a little bit higher than the back, but I plan on getting a dealer TSB soon.
    Was thinking about running 285/70/17 but IDK how much it'll rub and how much I'd have to trim on the cab mount.
  7. Sep 25, 2011 at 10:35 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    4.0 is about the limit on 2nd gens. You'll start rubbing on the outside of the tire if you go less than that.
    And to clarify, if you want a wider stance, you want less backspacing, not more.
  8. Sep 25, 2011 at 11:19 AM
    veet skeet
    Cali
    So negative backspacing will give you more of a wider stance?
  9. Sep 25, 2011 at 11:29 AM
    TexasTacoma37
    Negative backspacing would mean the rim mounting point is further out than the back of the rim....no such thing, at least on these trucks...some duallies might have that but :notsure:
  10. Sep 25, 2011 at 11:30 AM
    veet skeet
    Cali
    Lemme try to get this straight haha.
    So if I wanted to get new wheels and tires for a wider stance, what offset would I have to get? +12? 0? -12?
  11. Sep 25, 2011 at 11:31 AM
    TexasTacoma37
    -12 will stick out the most, but we also need to know the rims width to calculate backspacing, and the tire size, to see if they will fit.
  12. Sep 25, 2011 at 11:32 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    ^ -12
    Edit: damn KPT is fast
  13. Sep 25, 2011 at 11:33 AM
    TexasTacoma37
    I have this little chip in my head that dings when a wheel related question is posted
    :laugh:
  14. Sep 25, 2011 at 11:51 AM
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    I get confused with how backspacing and offset affect the overall wheel fit.
    Backspacing (inches) is the measurement from the back of the hub to the inner wheel rim, yes?
    Offset (mm) is the measurement of the hub offset from the exact center of the wheel, - or +, yes?
    Does the hub thickness play into these numbers for offset and backspacing?
  15. Sep 25, 2011 at 11:55 AM
    TexasTacoma37
    Backspacing is the distance from the wheel mounting point to the back of the rim. Offset is the distance from the center of the rim to the wheel mounting point. So hub thickness affects both equally. One confusing thing is that "width" is not actually the width of the wheel, it's the distance between the bead seats. So the rim is actually about an inch wider than the advertised "width".
  16. Sep 25, 2011 at 12:47 PM
    tacomtn
    I'm looking at the Ultra Rouge wheels with these specs.
    17x8 4 7/8 BS +10 Offset 108 hub bore.
    Will this come too close to the UCAs or present other problems?
  17. Sep 25, 2011 at 12:50 PM
    veet skeet
    Cali
    Oh okay gotcha. I was thinking of running this:
    I have 265/70/17 Nitto Terra Grapplers
    Either:
    17x9 Ballistic Jesters
    17x9 Revolvers
    Both I believe have rims that come in -12 offset.
    Would that make me have a wider stance?
  18. Sep 25, 2011 at 12:57 PM
    TexasTacoma37
    What size tires?
    The LT or P- metric terra grapplers? The LTs aren't approved for 9" wide rims in that size.....too wide of a rim.
    Anyways, a 9" wide rim with -12 offset (4.5" bs), will stick out 2" more than your stock rims.
  19. Sep 25, 2011 at 1:02 PM
    veet skeet
    Cali
    I believe mine are the P-metrics. I am running TRD sport rims on em right now.
    So my tires would fit a 17x9 -12 offset rim?
  20. Sep 25, 2011 at 1:03 PM
    TexasTacoma37
    According to the nitto website, yes.
