How do you check for a bad tie rod end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Mar 2, 2024.
  1. Mar 2, 2024 at 2:57 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    While the suspension is assembled....
    I'm about to do ball joints and struts and want to check the tie rods before I go in there. If I try to rotate the shaft and it rotates easy, is that a sign of wear, considering the boot looks OK?
  2. Mar 2, 2024 at 2:59 PM
    Bishop84
    Bishop84 Well-Known Member
    Two ways, on the ground, have someone rock the steering back and forth.
    Off the ground, shake wheel side to side, unloaded.
    With ball joints theres a few ways, but jacking from the lower arm is best.
    https://www.youtube.com/watch?v=VQ5pckndLDA
    This is perfect for lower ball joint, for upper you simply pry down on the upper arm.
    TnShooter likes this.
  3. Mar 2, 2024 at 5:52 PM
    TacoTuesday1
    FL
    Check the age and miles.
  4. Mar 2, 2024 at 6:00 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    They're 3 yrs and 20k but I had a ball joint go bad so I need to see if other suspension parts went, as well
