How Do People Figure Out Which TPMS Sensor Is Bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by comradeshrek, Apr 7, 2022.
  1. Apr 7, 2022 at 8:02 AM
    comradeshrek
    comradeshrek [OP] Well-Known Member
    Artie
    2011 White Tacoma TRD Sport
    Exactly what the title says lol. I got the dreaded TPMS light and want to switch it myself. I don't have the signal reader from Toyota. How do people know which one goes bad? Do any small shops have these signal readers? Any DIY ways to tell?
    Thanks!
  2. Apr 7, 2022 at 8:06 AM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    I purchased all of my last rides tires/wheels and Discount Tire here in Omaha (not sure how far or wide that chain is spread) and they have the handheld meter that can read a good/bad TPMS.
    comradeshrek[OP] likes this.
  3. Apr 7, 2022 at 8:07 AM
    comradeshrek
    Artie
    We've got them here in Ontario, will call and ask. Thanks!!!
    Out2gtcha[QUOTED] likes this.
  4. Apr 7, 2022 at 8:10 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    There are inexpensive readers. Google is your friend.
    You may find your local part store is willing to help. Than you can purchase a replacement from them or go OEM. Not sure if a dealer would help, you could ask. And of course you'll have to get the new one installed.
  5. Apr 7, 2022 at 8:14 AM
    comradeshrek
    Artie
    I've tried searching for them on Google but I only see the cheaper GMC vehicle TPMS sensor readers. Can't find one for Toyotas.
    I also have a winter set of wheels that I'm planning on taking a TPMS sensor out of. It's already programmed to my car, I literally just need to know which wheel needs it
  6. Apr 7, 2022 at 8:17 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Pretty much ANY TPMS scan tool can identify sensors and quite simple, if one isn't producing a signal, it's dead. The rub is whether the tool can write to the Toyota ECU.
  7. Apr 7, 2022 at 8:18 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The general advice is that if one goes bad and its been around five or more years since you replaced the whole set, you should probably replace the whole set.
    Its a pain in the ass to do those one at a time when they reach their end-of-life.
    Jimmyh, b_r_o, Toy4me and 2 others like this.
  8. Apr 7, 2022 at 8:21 AM
    Not a golfer
    Calgary, Alberta
    www.autelmfg.com
    That's a popular brand. Your local parts store may offer TPMS reading as free service. Even a local tire shop may do the same or a small fee to read TPMS.
  9. Apr 7, 2022 at 8:30 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Once one goes they all start to go. The batteries die around the same time. Recommended to replace them all if you can.
  10. Apr 7, 2022 at 9:26 AM
    Ridgewalker1
    Ridgewalker1 Well-Known Member
    Philip
    Longmont, CO
    2003 Tacoma TRD OR, 2015 Tacoma TRD OR
    2003 1 5/8” lift, 235-85r16 BFG KO2, ARB Bull Bar, Warn M8000, sliders, Snugtop; 2015 Hefty Fab al bumper and sliders, Warn Zeon 10k, Rago bed stiffeners,
    Just a thought, but if you have an Auto Zone, they will usually loan tools if you buy parts from them.
  11. Apr 7, 2022 at 9:39 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There's handheld scanners specifically for tpms systems and larger/expensive scan tools that cover everything inc tpms
    On your 2011 I'd consider replacing them all as a set. All the batteries are likely getting close to end of life
    Ridgewalker1 likes this.
  12. Oct 19, 2023 at 11:23 PM
    odautel
    odautel Autel Scanner
    odautel
    You need a tpms service tools obd2 scanner
  13. Oct 20, 2023 at 2:22 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If one goes bad replace them all. Typical life is 7-10 years, but I've seen some last 14+ years. I've started just replacing mine proactively after about 8 years before they go bad. You can buy 4 new sensors aftermarket for $60-$80 and take them with you to any tire store and have them installed at no extra charge when buying new tires. If I need new tires, and the sensors will be 8+ years old by the time I expect to buy tires again, they get new sensors.
    If you wait until they actually go bad, you're looking at another $10/tire to install them if you're not buying tires. That will almost double the cost of the sensors. If you're close to needing new tires just wait it out and replace them all at the same time.
    It isn't that hard and the cost is about equal to one tank of gas every 8 years or so.
