How Do I Read My Oil Dipstick Properly
Discussion in 'Technical Chat' started by pcbeachjim, Oct 11, 2012.
  1. Oct 11, 2012 at 10:28 PM
    pcbeachjim
    pcbeachjim [OP] Member
    Jim
    Panama City Beach, Florida
    2013 Toyota Tacoma
    thanks everyone
  2. Oct 11, 2012 at 10:34 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Well I would have to look at my stick to recall exactly what is what, but if you are in between the grated area you're good.
  3. Oct 11, 2012 at 10:41 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    sadly there is no grated area like other dip sticks, just smooth steel and 2 dimples, harder to read than others
  4. Oct 11, 2012 at 10:50 PM
    aaronatl
    aaronatl ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    after changing the oil on mine, and adding 5.5 qt. it would look low on the obverse side
    on the reverse it would look normal. after a week or two it would look fine when the oil was slightly discolored
  5. Oct 11, 2012 at 10:52 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Run it, shut it down, let it sit for about 5 minutes, pull the stick, wipe it, reinsert, remove, and read.
    It should be between the dimples. Expect some smearing from the tube, but one side or the other on the stick will give you a solid, smear-free reading.
    TRKSMTH likes this.
  6. Oct 11, 2012 at 10:54 PM
    BurqueTaco
    BurqueTaco Well-Known Member
    Albuquerque New Mexico
    04 trd tacoma 4x4
    Custom pinstriping, pleasure hole, Fox 2.0 rear, Fox 2.0 coilovers.
    read it in the morning before you start the truck. At least thats what ive always been told.
  7. Oct 11, 2012 at 10:54 PM
    pcbeachjim
    Jim
    2013 Toyota Tacoma
    Thank you very much, Aaron....Jim...
  8. Oct 11, 2012 at 10:56 PM
    acdronin
    acdronin Well-Known Member
    well, you have to wait for a full moon, then at 3 AM you have to dress up as a rabbit wearing a tutu, sacrifice a chicken to the Tacoma gods, dance in a circle for five minutes praising Satan.......
    Oh wait....ok just the oil?
    If there is no crosshatched design etched into the metal, sometimes the normal range is the area between the two dots, if you are unsure, run it by a dealer and ask a service tech to show you
    ixnay of the chicken sacrifice :)
  9. Oct 11, 2012 at 10:58 PM
    pcbeachjim
    Jim
    2013 Toyota Tacoma
    "They're Coming to Take me Away, HaHa"........
  10. Oct 12, 2012 at 3:24 AM
    abn2060
    abn2060 Infidel
    N Florida
    2014 Tacoma OR 4x4
    Stock
    Might not be a bad idea to read your owners manual. A lot of useful information in there.
  11. Oct 12, 2012 at 6:08 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You mean they still put them in new vehicles?!?!
    OP, check the oil when the engine is cold and it should be between the 2 dots on the dipstick.
  12. Oct 12, 2012 at 6:10 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    I don't remember how it was in my Tacoma but in my FJ the dipstick is next to useless. Even after I had just changed my oil, I was still getting a really low reading.
  13. Oct 12, 2012 at 8:36 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Welcome to TW :wave:
  14. Oct 12, 2012 at 8:55 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yep these dip sticks are hard to read. What i did was etch the area between the 2 dots with a file. I made it a "X" pattern fileing one way, then the other. After the truck cools down pull the stick out and wait 20 minutes before re-inserting. When you pull the stick out it carries some oil up the tube... you need to give it time to drain back down to get an accurate reading.
  15. Oct 12, 2012 at 9:01 AM
    BEEFY_CHEESY_TACO
    BEEFY_CHEESY_TACO DUDE MAN BRO
    Hot Carl!!!
    Roy UT
    2010 TRD-Off Road TACO Extra value package
    Icon Ext Travel w/ Resi Front and rear, Dakar leaf springs, total chaos UCA's, color matched rear bumper, color matched satoshi grille with black chrome TRD emblem, konig countersteer offroads (black) w/ 285/75 Duratracs, sockmonkey Trailiens 3rd tail light cover, Tacomaworld.com sticker (made by me), debadged all around, Relentless Front Bumper, Sliders, Rear bumper, and bed bars with Yakima rack w/ full size spare, shovel, hi-lift
    interesting....I can't say I've ever encountered a "hard to read" dipstick, but anyways you're supposed to check it with the engine cold in order to get an accurate reading
  16. Oct 12, 2012 at 9:27 AM
    CaptQuinn
    CaptQuinn Well-Known Member
    Quinn
    Alaska to Oregon
    '13 Sprucie Sport
    Dakar EL095R :Front Coils-2885 :Shocks-90000
    Oh Christ, I've had mine for a week tomorrow and haven't looked at my dipstick (...on my Taco!) once. Okay, time to go make that happen....
  17. Oct 12, 2012 at 9:31 AM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    i find it much easier to read dipsticks after the vehicle has sat for a night. then you know all the oil in the engine and in the dipstick tube has dripped back down to the pan. I'll usually get a really clear reading like this
  18. Oct 12, 2012 at 9:32 AM
    Nunavut
    Nunavut Eh oh, Canada go.
    Canada
    A friend of mine owns a shop, and he had a guy come in saying he needed a new dipstick. His didn't work. It never showed he had any oil...
    I wonder why eh?
  19. Oct 12, 2012 at 4:54 PM
    dafloydboy
    dafloydboy Well-Known Member
    M.L. Evans
    lancaster s.c.
    15' base access cab
    Are camper shell
    my owners manual says 6.1 qts but 5.5 gets it full
