How Do I know Its 2 Inches? Or what is 2 inches?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by COToycoma, Feb 18, 2022.
  1. Feb 18, 2022 at 12:37 PM
    COToycoma
    COToycoma [OP] Active Member
    2007 DBL Cab TRD 4x4 => 2018 DBL Cab TRD 4x4
    Front leveling spacers, 17" wheels, work in progress for Overlanding, towing and off-roading
    Next warm weekend all this is getting installed, then 34" (285/75R17) Falken WildPeak tires.
    When I bought my truck is had leveling pucks on it that I assume are about 2" of lift in front.
    Now that I am going to install a lift kit I don't have a reference measurment (starting point). Since the C/O are ment for 2" and much beyond that the down travel/droop gets to small I want to traget that 2 inches of lift from factory.
    Is there an average measurement for center of wheel/hub to fender for the front of 3rd Gens?
    Or can a few people that are stock height tell me what they measure? (center of hub/wheel to botom of fender well)
    44-16 Taco and Speedfreak like this.
  2. Feb 18, 2022 at 1:41 PM
    MENACE
    MENACE Avid toker
    2018 MGM SR5 SPORT 4x4 MANTRUCK EDITION
    Don't know if this helps since I have an SR5 4x4. I've got exactly 21 inches from center of wheel cap to top edge of wheel well on both sides on stock suspension and 16 inch wheels.
    I think TRD's have different suspensions and wheel size though so you may want to get numbers from those guys. Good luck with the install!
    COToycoma[OP] likes this.
  3. Feb 18, 2022 at 1:52 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    22 inches on 3rd gen im pretty sure is the center hub measurement for stock. Im sitting at 23.5 on my second gen with a 2.5 inch lift and they came an inch shorter from factory so mine was 21.
    71tattooguy likes this.
  4. Feb 18, 2022 at 4:19 PM
    COToycoma
    Thank You - I think that matches something I found on Toy Tech's site that says 23 inches for 2" lift. Thanks for posting - seems like I am looking for ~ 23 inches.
    MENACE[QUOTED] likes this.
  5. Feb 18, 2022 at 4:29 PM
    dirt_seeker
    dirt_seeker Well-Known Member
    Utah
    2017 TRD OR
    21" is a pretty "standard" front height center of hub to fender measurement for 3rd gen. sS yes 23" would be a 2" lift. Hub to fender measures are immune to wheel and tire size, so you can't go wrong measuring that way.
    AndrewMT34 likes this.
  6. Feb 18, 2022 at 5:12 PM
    AndrewMT34
    AndrewMT34 Well-Known Member
    WY/UT
    2019 Calvary Blue LB Offroad
    ADS/FOX/DEAVER
    As others have said, 23" is about right. I'll be curious how the 34's fit with a 2" lift!
    CaptainBart45 likes this.
  7. Feb 18, 2022 at 8:01 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    All 3rd Gen Tacoma's have the same suspension height front and rear, regardless of trim. With the one exception of the TRD Pro being 1" higher in the front only. The rear is exactly the same as any other trim.
    Skydvrr likes this.
  8. Feb 18, 2022 at 9:16 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Every gal I ever dated was eventually convinced this was 6 inches.... so... 2 inches is whatever you want it to be...
  9. Feb 18, 2022 at 9:19 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    McAllen, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Sports tend to be a hair lower than Off Roads.
  10. Feb 18, 2022 at 9:26 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Well at least you got the lift before the tires, good plan.
  11. Feb 22, 2022 at 6:53 PM
    COToycoma
    Andrew - I have done a body mount chop and went with SPC UACs to hopefully push the tires forward a bit. With the chop it looks like I have about 1.5 inches, since I have 32s already (265/70R17) the radius is going to increase ~ 1.1 inches when going to 285/75R17 tires. So I hope I will be OK.
    I actually don't think that 2 or 3 inch lift makes a difference - you will still travel up and down about the same, so a 3 in lift will rub the same as 2 in lift unless you really reduce up travel.
    Time will tell if it is worth it.
    AndrewMT34[QUOTED] likes this.
  12. Feb 22, 2022 at 7:04 PM
    AndrewMT34
    WY/UT
    ADS/FOX/DEAVER
    I hope they fit as well! I’ve got the SPC UCA’s as well, they are great. I know there are folks that still get rubbing with 285/70/17’s especially off-road with 2” lifts. All depends on the offset of the wheel I think.
  13. Feb 22, 2022 at 7:14 PM
    COToycoma
    hmmm - you are making re-think it then. An addition 1/2 inch ground clearance isn't worth the hassel of rubbing and having to re-do a body mount chop or relocation.
    Thanks for the info!
  14. Feb 22, 2022 at 7:28 PM
    AndrewMT34
    WY/UT
    ADS/FOX/DEAVER
