How do I know if I need to replace my coil springs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Boatwithwheels, May 24, 2021.
  1. May 24, 2021 at 12:39 PM
    Boatwithwheels
    Boatwithwheels [OP] Member
    1st gen tacoma 2.4L RWD
    Hey everyone! so I've got a 1st Gen RWD 2.4L Tacoma and I was thinking about replacing the coil springs. They don't look too bad (pretty good actually) but my ride isn't the smoothest when the road gets bumpy so I thought maybe something in the suspension needs to be replaced.
    It's got about 220k miles on it total. What do you all think?
  2. May 24, 2021 at 12:45 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    It's most likely your shocks that are blown if the ride is garbage. You may be able to find new springs with lower rates if you want it to ride like a caddy.
  3. May 24, 2021 at 12:47 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Buy kyb gas adjust shocks on Amazon and check ur ball joints while at it. 30 bucks a piece
  4. May 24, 2021 at 1:44 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    At that mileage it's a safe assumption that your spirngs are worn out, but as @Das it mang said, the shocks are what contribute the most to the "ride" you feel.
    When they're worn out, springs just sag a little so they don't support the weight as well as before. So probably safe to replace both. That said, I'd start with the shocks.
    Das it mang likes this.
  5. May 24, 2021 at 1:45 PM
    jbrandt
    Justin
    A softer spring will just make is sag more, and can even make the ride worse because it's more likely to bottom out.
    Shocks are what will make it ride like a caddy or not.
    Thatbassguy likes this.
