How do I know if I need a relay?
Discussion in 'Technical Chat' started by mark5868, Oct 27, 2023.
  1. Oct 27, 2023 at 1:46 PM
    mark5868
    mark5868 [OP] Well-Known Member
    I would like to know if I need a relay or not? How do I know a relay is necessary?
    For example, I installed ditch lights and used a relay when I wired it together.
    Now I plan to install a Weboost Cell Booster and hard wire it.
    Will I need to use a relay before the on / off switch?
    Thanks for any advise you can provide.
  2. Oct 27, 2023 at 1:49 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Whats the load of the weboost? Will you use a signal wire from the truck to turn it on or adding a switch? What switch will you be using?
    TnShooter likes this.
  3. Oct 27, 2023 at 1:51 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The short answer is you need a relay if you need to control more current than your switch is rated for.
    There are other reasons too - some people like to keep all the high power wiring under the hood, for example.
  4. Oct 27, 2023 at 1:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    All the specs I see are either 5v/2.1A or 12v/1.5A
    A switch and a fuse is likely all you need.
  5. Oct 27, 2023 at 1:59 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    When I installed my Weboost Drive Reach, I used a CH 4x4 switch. I contacted both Weboost and CH 4x4. After discussing the power draw, we determined that a relay was not needed and the power draw was less than the max the switch was rated for.
    I have used it quite a bit up in the mountains and have had no issues.
  6. Oct 27, 2023 at 2:43 PM
    mark5868
    These are the specs of the Weboost Amp.
    Drive Reach Specs:
    • Frequencies:
      • Band 12/17 700 MHz
      • Band 13 700 MHz
      • Band 5 850 MHz
      • Band 4 1700/2100 MHz
    • Band 25*/2 1900 MHz
    • Max gain: 50 dB
    • Impedance: 50 Ohm
    • Power: 5v
    • Amp Draw: 4.5a
    • Connectors: SMB
    Booster dimensions: 6 x 4.5 x 1.5 in.
    I have these relays
    https://www.amazon.com/gp/aw/d/B074FSZWVT?ref=ppx_pop_mob_b_asin_title
    Looks like just a fuse and switch is needed.
    Thank You for your help guys!
  7. Oct 29, 2023 at 6:02 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It pretty much comes down to a personal Choice !
    Wire the complete Circuit with a heavy enough switch and wire to handle the load.
    Some people will use a relay for every application( depending on the length of the circuit) to save on wire cost since things went price crazy.
  8. Nov 25, 2023 at 10:51 PM
    TacomaWorld2023
    TacomaWorld2023 Well-Known Member
    Can you drop some photos of the wiring setup? I'm literally trying to draw up plans to replicate this thread. CH4x4 Weboost switch to my Blueseas Fuse block.
    From what I gather, I have to cut the end of the 12V power source and get to soldering. I'm spacing on the setup though.
    If I use the Amazon Relay you dropped, its just the blue wire to the WeBoost power source and the red wire to the fuse block?
  9. Mar 18, 2024 at 3:35 PM
    Faroutspacenut
    Faroutspacenut Well-Known Member
    Southern California
    2020 DCLB TRD OR
  10. Mar 22, 2024 at 3:21 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    The simple answer is yes. You can purchase a single lead wiring harness already set up with a relay for fairly cheap. You would then order a custom switch form CH4x4 (or any place) and mate it to the purchased wire harness. It's really not difficult to do.
    Here is a link for a single lead.
    https://amzn.to/3TvnLR9
    In the pic you can see the switch that comes with the harness. You would be replacing that switch with whatever switch you want. Unless you really enjoy making your own harnesses and already have the random parts floating around in your garage. This is the easiest, cheapest way to get the entire package in one shot.
    Faroutspacenut likes this.
