How do I find my Reverse signal wire?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by will84, May 5, 2020.
  1. May 5, 2020 at 11:31 AM
    will84
    will84 [OP] Active Member
    Will
    2005 Green Tacoma
    I have an 05 Tacoma. I installed an aftermarket head unit recently and it came with a free back up camera. I wired everything up except for the reverse signal wire. Right now the camera works all the time by selecting that video input on the head unit, but I want it to come up automatically when I shift to reverse. However, I don’t know how to find my reverse signal wire. The only sure ways I can think of are to wire it directly to my backup lights or my reverse switch on my manual transmission, but I would really like to wire it up under the dash away from the elements. Has anyone done this successfully?
  2. May 5, 2020 at 12:19 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I know it'll be under the door sill plastic. Do I know which wire, no. @Jimmyh might though.
  3. May 5, 2020 at 3:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The wire you seek is a red wire with a white stripe in connector ID2 in the Frame Wire and Instrument Panel Wire (Left Kick Panel). Terminal # 1
    will.i.was, CurtB, hoverlover and 4 others like this.
  4. May 5, 2020 at 5:34 PM
    cjsqueeky
    cjsqueeky Well-Known Member
    chris
    Chesapeake VA
    15 tacoma dbl cab
    front 2.5 headstrong lift, Freedom offroad UCA, 3 inch rear custom helwig lift, custom double cardon 2 piece drive shaft
    I just tapped off the reverse light which I used to power the camera also.. So when the reverse light goes on it turn on the camera and tells the head unit also.
  5. May 5, 2020 at 6:30 PM
    caribe makaira
    Caribbean, Puerto Rico
  6. May 5, 2020 at 6:49 PM
    mk5
    mk5 Probably wrong about this
    SoCal
    '05 access cab 4x4
    If you often have a blocked rear view (e.g., a camper shell, or a back seat filled to the ceiling with stuff), consider also adding a manual switch somewhere on your dash, to bring up the rear camera view while driving. It can be handy.
    If you go this way, you will need to add a diode between the switch and the reverse wire.
    Jimmyh likes this.
  7. May 5, 2020 at 7:47 PM
    caribe makaira
    Or just a SPDT (Single Pole Double Throw) switch...
    mk5[QUOTED] likes this.
  8. May 6, 2020 at 12:40 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Hey @will84. Any updates?
    BizzyB726 likes this.
  9. Oct 28, 2020 at 1:58 PM
    ToyotaBurrito
    ToyotaBurrito Well-Known Member
    2013 AC Sport MT
    I’ll ask the question here, before I ask it more generally. I have a 2013 MT and the reverse lights, camera and beep started only turning on intermittently and then they stopped working altogether. Is this a fuse issue or a bad reverse switch? Any help diagnosing/fixing is greatly appreciated!
  10. Oct 28, 2020 at 2:32 PM
    caribe makaira
    Well the fuse provides the juice and the switch provides the on/off...so replace the fuse and go from there.
    Edit: The fuse that the reverse uses feeds other circuits. So the reverse switch is the most likely culprit.
    Jimmyh likes this.
  11. Oct 28, 2020 at 5:33 PM
    ToyotaBurrito
    2013 AC Sport MT
    @caribe makaira, thanks, I checked all the fuses and the switch. Both are fine. Any other ideas?
  12. Oct 28, 2020 at 5:38 PM
    caribe makaira
    Harness...broke wire inside shield/insulation...broke terminal in connectors...lots to verify.
  13. Oct 28, 2020 at 6:33 PM
    Muddinfun
    Muddinfun Well-Known Member
    How did you check them? Did you put a multimeter on anything?
  14. Oct 28, 2020 at 7:40 PM
    ToyotaBurrito
    2013 AC Sport MT
    I checked the continuity on the fuses and I pulled the switch out (future trouble shooters see this thread: https://www.tacomaworld.com/threads/reverse-beep-and-backup-lights-not-turning-on.133113/ - it shows you what the switch looks like and part number - it's on the righthand side of the transmission housing) and checked the continuity on it too. After I put the switch back in and decided that I'd try jumping across it to just double check the circuit. I put the truck in reverse and everything worked again... I suspect I have either bad contacts or a failing switch... Thanks for the input!
