How difficult or easy is it to add fog lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ngaudet, May 31, 2018.
  1. May 31, 2018 at 8:19 AM
    ngaudet
    ngaudet [OP] Active Member
    Pirate
    a ybody do this ?
  2. May 31, 2018 at 8:35 AM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    It’s pretty easy. The hardest part was getting through the firewall
  3. May 31, 2018 at 9:37 AM
    ngaudet
    Pirate
    How do the lights mount to the bumper
  4. May 31, 2018 at 9:38 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Are you talking about installing a set of factory fog lights on a truck that was not equipped with them, or aftermarket fog lights with a switch in the cab?
  5. May 31, 2018 at 9:40 AM
    ngaudet
    Pirate
    Your first the factory ones can I buy them on eBay etc
  6. May 31, 2018 at 9:50 AM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    Two things.
    If they are genuine "factory" lights, they bolt right in after you pop out the blanks in the fog light space. The wiring should already be there; just plug them in.
    Second, you will need the switch for the dash; the wiring plug should be there too. You might also have to install a small relay on the wiring board behind the driver's side kick panel.
  7. May 31, 2018 at 10:02 AM
    ngaudet
    Pirate
    Awsome I’ll see if toyota offers a kit or something to that do you know if yota offers a kit thank for all the advice
  8. May 31, 2018 at 10:08 AM
    loaderman82
    loaderman82 Well-Known Member
    Dalton
    Flippin, AR
    2008 Off-Road
    I was wondering the same thing. I replaced my fog lights with the caliraised leds. My dad has a little two wheel drive Tacoma without factory fogs. I just gave him my old factory ones. I poped out his blanks and put the lights in but didn’t see any factory wiring anywhere. Is it tucked up somewhere maybe that I didn’t look or what?
  9. May 31, 2018 at 10:11 AM
    Newfiebruh
    Tom
    Don't go OEM, overpriced when you can go aftermarket for like 80 bucks. I bought mine on Amazon and they've been great. The blanks pop out of the bumper easy and then you just have to fiddle with the lights till the pop into place. If you're not prewired for fogs you run the wires to the battery, and to a ground point on the fender. Make sure you wire a live cord into a fuse so it doesn't trip and catch on fire. I wired mine into the trailer fuse. Then feed your switch through the fire wall and its a done deal. Took 1 hr and 80 dollars and I couldn't be happier. OEM kits were like 300-500$ I heard people say Toyota wanted like 800-1200$.
  10. May 31, 2018 at 10:14 AM
    Newfiebruh
    Tom
  11. May 31, 2018 at 10:14 AM
    Muddinfun
    Muddinfun Well-Known Member
    Some trucks are prewired for fogs. Some are not. If yours is prewired, you must use the factory Toyota switch. If yours is not prewired, I think it's more economical to buy the aftermarket kit with wires, relay, and switch. If yours is prewired, look in marketplace for someone selling their OEM fog lights.
    Newfiebruh likes this.
  12. May 31, 2018 at 10:16 AM
    Newfiebruh
    Tom
    The amount of things that are pre wired on these trucks is insane lol. Went to take off my tailgate, and there was wiring for a back up cam. And I also have the satellite radio receiver, but neither are hooked up.
  13. May 31, 2018 at 6:59 PM
    Barzini
    Barzini Well-Known Member
    Don
    2019 Tacoma Access Cab
    From what I’ve read in other threads, it seems like most 2012-15 4 cyl models are not prewired for fog lights. I assumed my 2013 might be since it was a SR5 but it was not.
    If you want to go factory, there is a full OEM wiring harness and switch on eBay (ray’s auto) for $168 plus shipping. Used factory fog lights are often for sale on this site. As others have mentioned, aftermarket version is much cheaper.
    There are many installation You Tube videos for 2005-11 and 3rd generation; however, I have not found one for the 2012-15 models. The wiring diagrams and written instructions I’ve seen are inconsistent. To install the interior on/off switch, do you have to remove the kick panel and part of the dash or can you just use use a bottom row blank spot which is accessible through the fuse box opening?
  14. May 31, 2018 at 8:13 PM
    Newfiebruh
    Tom
    Mine had the fuse for the switch built into the harness, so it was just plug and play
    Barzini[QUOTED] likes this.
  15. Jan 5, 2021 at 5:33 PM
    kumurick
    kumurick Member
    Richard
    2008 White Tacoma Base Model
    None
    I've been looking to do the same thing on my 5 lugger base model and have a bull bar with light bar that I plan to install/wire all at the same time - Having it be prewired sure would be great - Has anyone here done this on a base model that old?
  16. Jan 5, 2021 at 5:43 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Buy a set of Diode Dynamics SS3, well worth the money.
    Boco10 likes this.
  17. Jan 5, 2021 at 6:04 PM
    GrayTacoma
    GrayTacoma Well-Known Member
    Andy
    Huntingtown, MD
    2011 TRD off road
    PIAA ion yellow fogs stay on all time,aux reverse lights, aux lights, camper with rack, cb, air bags, on board air, aux fuse box, aux batt, CAI, etc.............
    160989765342322118930445633006.jpg 16098977331972840843144787623295.jpg 16098978228486223936080852529663.jpg
    This is all I got, from a 2011. OP make me an offer.
  18. Jan 5, 2021 at 9:36 PM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    Not to burst your bubble, but the OP was from May 2018...
  19. Jan 6, 2021 at 9:08 AM
    LancerRevo
    LancerRevo Well-Known Member
    Phillip
    2007 Tacoma Pre Runner V6 4.0
    My 07 prerunner dclb was pre wired but I ran into problems along the way, but finally solved it. Wires are hanging there at the bottom of the front bumper if you are pre wired. You need the exact factory Fog light button plug from the dealership. I bought 2 OEM ones from eBay, didn't line up with the wire plug in behind the blank button, or actually fit in the slot where its suppose to be. Then you got to add the fuse into the engine bay. I was already annoyed, so I recommend getting the button and fuse at the dealership. Fog light wise, I got from eBay. Its been way too long so I couldn't tell you which ones to get. Just look at the picture and match the connections
  20. Jan 6, 2021 at 3:55 PM
    GrayTacoma
    Andy
    Huntingtown, MD
    2011 TRD off road
    I miss Anchorage. 2003 -07.
    Thanks I didn't noticed the dates.
    So... anybody else wants this things?
