How deep in water can Tacoma's go?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kalani88, Jan 17, 2023.
  1. Jan 17, 2023 at 7:20 AM
    Kalani88
    Kalani88 [OP] Member
    Hello,
    Just curious. Without or with snorkel, how deep can a Tacoma go in water and at what point does it get damaged? Where is water not supposed to access?
  2. Jan 17, 2023 at 7:23 AM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Jan 17, 2023 at 7:25 AM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    It depends on what parts of the truck you want to keep :) I wouldn’t go higher than the suspension ball joints since they will get wet and the grease will go bad.
  4. Jan 17, 2023 at 7:27 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Balls deep...
  5. Jan 17, 2023 at 7:28 AM
    mushroom_man7
    mushroom_man7 Well-Known Member
    smh a "snorkel" on a tacoma isnt for going into water. it is a dust snorkel. the wheels spin up dust in the wheel fender where the tacoma gets its air, the "snorkel" moves it to high above where there is less dust. turn on the submarine option in the menu and you will be able to drive underwater
    TacoManOne, Reggie4x4, MJTH and 7 others like this.
  6. Jan 17, 2023 at 7:33 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Many threads on this. One just last week.
    TS4x4, Chew and Rock Lobster like this.
  7. Jan 17, 2023 at 7:36 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Test it! It would be interesting to see a depth of water vs. repair bill cost comparison, ya know, for future reference.
    Kofe513, TacoManOne, Vmax540 and 2 others like this.
  8. Jan 17, 2023 at 7:50 AM
    Tacospike
    Two Trucks
  9. Jan 17, 2023 at 8:00 AM
    mcmcolem
    mcmcolem Google Search Mechanic
    Texas
    '18 Cement Taco
    Truck will run while submerged past the wheel well. Water will be in your lap shortly after. Max I'd go without damage/flooding is 2-3 feet
  10. Jan 17, 2023 at 8:02 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    they can go pretty deep but it's not a good idea
    erwigg and ToyoTaco25 like this.
  11. Jan 17, 2023 at 8:04 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    My mom drove hers into the ocean. We're still waiting on her to get back.
  12. Jan 17, 2023 at 8:05 AM
    ToyoTaco25
    North Carolina
    The ocean is deep! Might take a while to get to the bottom and back
  13. Jan 17, 2023 at 8:06 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    That video made me pause. The brain for the SRS system sits behind/underneath your phone pad in the center console. So about ankle height, with your shoes on the floorboard. For that reason alone I wouldn't want water to touch carpet. There are other reasons too, but thats a big reason.
    Tangental story that I oft repeat - in college I raced bicycles. For fun I used to cross deep water/mud with my bike. This usually meant that the bike had to be torn down to its frame, cleaned, drained, dried, chain (and sometimes cables) replaced and all bearings repacked. Neglecting any step of that meant that expensive parts would be trashed after only a few rides, and this college kid would rather have bar money than parts money. After about a year of having fun, that wasn't so fun anymore. No way I would want to do that to my truck. At least, not anymore. I did, once. It was expensive.
    Kev250R, Dawelda, Junkhead and 6 others like this.
  14. Jan 17, 2023 at 8:08 AM
    WarBeard_Actual
    WarBeard_Actual Well-Known Member
    Your alternator is mounted pretty low. Not a good idea to submerge it.
    CLTVTR, Dawelda, 69 Jim and 3 others like this.
  15. Jan 17, 2023 at 8:14 AM
    Zillon
    Zillon Well-Known Member
    NJ
    2013 SR5 Access Cab 4x4 V6
    Yep. I've done some really muddy bicycle races... and while they're a blast, the post-event teardown that ensues is miserable. A little mud is OK, but if it's going to be a slog from start to end, I typically pull the ripcord and bail on the event. Plus, it's just not good for the trails.
    I don't quite understand the obsession with going muddin' that a lot of people seem to quantify as off-roading (on bike or with their vehicle). That mud and water gets everywhere, and once it gets in, it's tough to get out. Inside the frame, bearings, bushings, shocks, moving parts, etc. It accelerates wear and tear tenfold, and I really don't like replacing parts more than necessary.
    Kev250R, Junkhead, blu92in99 and 2 others like this.
  16. Jan 17, 2023 at 8:18 AM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    This guy should be able to answer your question lol
  17. Jan 17, 2023 at 8:19 AM
    WarBeard_Actual
    bro... lmao.
    "But did you die tho???"
  18. Jan 17, 2023 at 8:31 AM
    Zillon
    NJ
    No, but the truck did?
    Malvolio likes this.
  19. Jan 17, 2023 at 8:48 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I don't know, I try to avoid any water over a couple of inches deep especially if it's moving. If at all possible it's best to pull over and wait it out if turning around is not an option. If there's a way to get off the highway just be careful your not driving into a wash out sink hole. Those flash floods are no upload_2023-1-17_8-51-18.jpg
    Zillon and Malvolio like this.
  20. Jan 17, 2023 at 9:11 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I'll copy n paste my answer from last week's thread
    "I didn’t read all the replies, so maybe this has been mentioned already.
    The problem is, not the depth it can handle, rather not being able to gauge the depth until it’s already too late. Turning around or backing out is the same unknown."
