How can one fit 20 inch wheels on a TRD Off-road?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BakingEggs, Jul 5, 2018.
  1. Jul 5, 2018 at 5:04 AM
    BakingEggs
    BakingEggs [OP] Well-Known Member
    Noah
    Richmond, VA
    Cement Truck
    TBA
    Disclaimer: I am aware of the hate I will receive.
    But I have been looking at running an 18,19, or 20 inch wheel.
    The 20 inch wheels are definitely obnoxious and horribly flashy, but the look has really grown on me.
    What kind of lift/offset, tire size would I need to run a larger rim (18+)?
    And also, does a 2nd gen wheel fit a 3rd gen? It looks like the bolt pattern is the same, but I wasn’t sure if the wheels would run or require cutting, just looking for confirmation
    Rockefelluh likes this.
  2. Jul 5, 2018 at 5:11 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  3. Jul 5, 2018 at 5:27 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  4. Jul 5, 2018 at 5:39 AM
    H3ATH3N2016
    H3ATH3N2016 Soul Stealer
    Bren
    Jones County, Ga
    2016 DCSB TRD SPORT 4x4
    9"+/- Lift, 20" Dropstars, 35x13.50x20 Toyo Open Country M/T, Predator Tube Rails, Ultimate LED signal lights, Much Much More
    2nd will fit 3rd gen ...
    as for wheel size, its all in numbers game, if you're looking at an aftermarket 20" wheel it's about offset and tiresize. HOw high would you like to go? I was previously on a 20x10 with a -19 offset on a 35x12.50x20 MT tire on a 6" lift, if that gives you any idea
    Thuguon2.7 and ChadsPride like this.
  5. Jul 5, 2018 at 6:20 AM
    BakingEggs
    Noah
    Richmond, VA
    Cement Truck
    TBA
    Certainly gives me a good idea. This is probably an even dumber question, but do you need a 6 inch lift?
    I’d prefer just to stay on the stock height and save a few $, max I’d like to do is 3” if need be though
  6. Jul 5, 2018 at 6:22 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    Thuguon2.7 likes this.
  7. Jul 5, 2018 at 6:26 AM
    BakingEggs
    Noah
    Richmond, VA
    Cement Truck
    TBA
    H3ATH3N2016 and ChadsPride like this.
  8. Jul 5, 2018 at 6:49 AM
    scottsglock29
    scottsglock29 Well-Known Member
    Scott
    Wisconsin
    2019 Cement TRD Sport DCSB
    Going from a 16" stock wheel to a 20" aftermarket wheel you are going to lose a lot of sidewall. IMO, the smaller diameter of the wheel; the better overall ride will be as you bumps and imperfections of the road are absorbed more. Your suspension will also come into play with the overall feel and handling.
    2nd gen wheels should fit on your 3rd gen fine.
    Offset and backspacing are going to depend on what you are looking to achieve. Do you want your tires to poke more out of the fender wells? Are you looking to get larger tires? The wider the wheel/tire combo the more likely that you will be doing some sort of trimming.
    You can run a larger wheel without adding lift as long as you stay as close as possible to the factory offset and backspace. As well as keeping the tire height and width as close to factory as possible.
    H3ATH3N2016 likes this.
  9. Jul 5, 2018 at 6:56 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    Problem solved!
    kent50, fiftysix, Koolbreeze7 and 7 others like this.
  10. Jul 5, 2018 at 7:17 AM
    H3ATH3N2016
    Bren
    Jones County, Ga
    Hope you found the info you wanted ... I got busy and couldn't get back here quick enough I suppose. #toyotapartscounterlife :rofl::p
    Dirty Harry and ChadsPride like this.
  11. Aug 13, 2020 at 4:42 PM
    TheBigMan
    TheBigMan New Member
    Oh no sock lay blue!!! 20" 4runner pro style rims gloss finish +0 offset wrapped in 275/55/20 ko2s !!! No rub. Eat your hearts out ladies!!
    I posted this last one out of respect to my old girl 300k miles still in my back yard
  12. Aug 13, 2020 at 5:07 PM
    Chastaco
    Chastaco Well-Known Member
    2020 ORDCSB Cement 4x4 Auto
  13. Aug 13, 2020 at 7:31 PM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
  14. Jul 22, 2024 at 6:58 AM
    Wvu0728
    Wvu0728 New Member
    Lee
    Toyota tacoma
    Where did u find 20 inch pro wheels with a 0+ offset?
  15. Jul 23, 2024 at 5:37 PM
    T.BROCK
    T.BROCK Well-Known Member
    NorthEast Tennessee
    2022 Barcelona Red 4x4 Off Road
    3.5 lift... 20x12 -51 offset...305/50r20's their 32" tires
    I barely rub at full lock!
    turkeyslayer66 likes this.
  16. Jul 23, 2024 at 5:47 PM
    JJ Customs
    Jay
    NV
    And they just let this shit slide in TN? Wow.
  17. Jul 23, 2024 at 5:56 PM
    T.BROCK
    NorthEast Tennessee
    What shit?
  18. Jul 23, 2024 at 5:59 PM
    JJ Customs
    Jay
    NV
    Just giving you a hard time. Got a little bit of that HI look.
    Chew likes this.
