How can I shorten the tailgate cables?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ggnoob, May 28, 2020.
  1. May 28, 2020 at 8:51 AM
    ggnoob
    ggnoob [OP] New Member
    Logan
    2020 Black TRD Off-Road
    2" lift, TRD Pro wheels/tires, bed rack, tube steps
    This may be a dumb question, but I've done a lot of searching and I cannot find anything.
    I have a hitch mount bike rack that sits just high enough that if I open my tailgate while it's on, the tailgate will hit and get scratched/dented. I need to shorten the tailgate cables by just about half an inch so that it won't hit and can hold the normal weight without crashing down onto the bike rack.
    Any ideas? I thought maybe I'd just be able to order a shorter one online, but anything I find seems to be just to replace the stock cables. I don't want chains or anything that would prevent me from closing the gate.
    The main reason for needing this is that our dogs will be in the back of the truck and I'd like to put the tailgate down to let them out without having to take the bike rack off.
  2. May 28, 2020 at 9:04 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    MannyS, shakerhood and Big tall dave like this.
  3. May 28, 2020 at 9:06 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Don’t be that guy that drives around with a bike rack that doesn’t have a bike on it
  4. May 28, 2020 at 9:07 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Here you go and useful for many other things:
    Credit: YF_Ryan
    I left off the '@' since he is probably getting tired of me tagging him for these. Haha!
    eurowner and shakerhood like this.
  5. May 28, 2020 at 9:07 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Perhaps make a small loop and use a crimp?
  6. May 28, 2020 at 9:11 AM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    Have you considered a hitch extender that pushes the rack out a little further? That might give you enough clearance and would be better than having short cables.
    AZ Pete and MoneyMan55 like this.
  7. May 28, 2020 at 9:12 AM
    ggnoob
    Logan
    Haha no we wouldn't!
    I did see this already, I'm thinking you can't close the tailgate with those chains? I want to be able to close it and just not have it open all the way when I need to open it.
    Not sure why I didn't even think of getting a different cable. Something like this could be perfect.
    tonered[QUOTED] likes this.
  8. May 28, 2020 at 9:13 AM
    ggnoob
    Logan
    I'll have to check out how far I'd have to push this out. I just wouldn't want it sticking out too far either as right now it's pretty much perfect. Honestly didn't know these things existed. New to trucks and using a hitch!
  9. May 28, 2020 at 9:14 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It takes less than 30sec to install / remove the chains. Yes though, the chains have to be removed to close the TG.
  10. May 28, 2020 at 9:17 AM
    rtadams89
    rtadams89 Well-Known Member
    Phoenix, AZ
    2017 Tacoma Limited
    If you know what length you need, you might be able to find a replacement strap/cable from a different vehicle. Dorman makes a ton. Alternatively, I see a few people have replaced the cables with two pieces of barstock with a pivot point in the middle. If you make your own out of bar stock, you can make it open to any length you want.
  11. May 28, 2020 at 9:24 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    jmauvais and Big tall dave like this.
  12. May 28, 2020 at 9:42 AM
    ggnoob
    Logan
    tonered likes this.
  13. May 28, 2020 at 11:58 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
  14. May 28, 2020 at 12:24 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    There was a guy here that installed a bolt on each side near the tailgate latch and he looped the cable under the bolt to hold it up but so it wouldn’t be all the way down.
  15. May 28, 2020 at 9:07 PM
    BOZOJUICE
    BOZOJUICE Well-Known Member
    2016 dclb offroad 4x4 MGMSOLD/2023 ICE CAP PRO
    Have a look at Gate King, The tail gate adjuster.
  16. May 28, 2020 at 9:11 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Kind of an expensive option for a minor issue.
    shakerhood likes this.
  17. Jan 18, 2021 at 6:13 PM
    kevinob123
    kevinob123 New Member
    Kevin
    2017 TRD Sport
    Has anyone tried the shorter 2000-2006 Tundra cables? Do they fit?
  18. Jan 2, 2024 at 12:17 AM
    Ayusuf99
    Ayusuf99 Well-Known Member
    Ali
    2021 green tacoma trd off-road
    Stock
    Who needs a bike rack when you have a truck? Just throw the bike in the bed
    andthen likes this.
  19. Jan 2, 2024 at 9:56 AM
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    You might get them from the same place GM does. They have them too short from the factory. The tailgate doesn't open flat with the bed. I think it is to make it more difficult to slide stuff out of the bed. Most GM truck owners wouldn't notice this of course since they don't use the truck as a truck. :rofl:
    But for a solution for your problem, maybe a semi hard foam placed on the bike rack will protect the tailgate? Then you don't have to deal with the GM problem when you're using the bed.
