How can I run 315/75r16
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Southern_TRD_Offroad17, Dec 19, 2017.
  1. Dec 19, 2017 at 2:15 AM
    Southern_TRD_Offroad17 [OP] Member
    Jake
    2017 QUICKSAND TRD OFF-ROAD 4X4 DCLB
    looking for that perfect look of big tire and minimal lift not sure where to get some pictures or if this is even possible because I hear that tire size will drag your Tacoma down.... HELP
    TacoRD16 and ChadsPride like this.
  2. Dec 19, 2017 at 2:54 AM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    2.5" lift of choice OME Bp-51
    And 4:88 gears
    90yota and ChadsPride like this.
  3. Dec 19, 2017 at 3:11 AM
    Jake
    Ouch pocket hurts just looking at those lol
  4. Dec 19, 2017 at 3:14 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Be prepared to do the Cab Mount Chop
    Trim the front fender flares
    and beat the living hell out of the pinch weld in the front wheel well
    90yota, Ch78, smw62891 and 2 others like this.
  5. Dec 19, 2017 at 3:15 AM
    Tacomamike mike
    Michael
    Being pretty ain't cheap!
    TOP TACO and ChadsPride like this.
  6. Dec 19, 2017 at 3:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    No one ever said looks were cheap...........
    Maybe consider what you need to have for 90% of your use of the truck, then pick products that fulfill that need and look good doing it?
  7. Dec 19, 2017 at 3:19 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    You can run 35's with no lift... just be prepared to do the work to make them fit... But if you're set on 2.5 its very possible, as others mentioned you'll need to trim some plastic and cut and beat your pinch weld. Also depending on what wheel setup you will need spacers or if you get new wheels the proper BS will help out alot as well. Be careful though, 35's are a slippery slope and lead to many other things to consider with these trucks.
    90yota, Stemmy and ChadsPride like this.
  8. Dec 19, 2017 at 3:40 AM
    Tacomamike mike
    Michael
    33" is the perfect fit for our rigs IMO.
    You can achieve this with a basic inexpensive lift...i.e. 5100's all around OME coils light racing UCA's . AAL
    Looks great and functional
  9. Dec 19, 2017 at 4:07 AM
    Jake
    I reckon I’ll stick with the 33s
  10. Dec 19, 2017 at 4:08 AM
    ChadsPride
    Dont let us talk you out of what you really want!
    If you want to run 35s then do it!
    Just be ready for the "snowball" effect as mentioned lol
  11. Dec 19, 2017 at 4:29 AM
    Tacomamike mike
    Michael
    I guess the cool part is ...33" with mild lift to clear tire's . Go on the less expensive side . If you like the setup you can upgrade suspensions to fit your lifestyle.
    And if it turns out 35" are what you Really want, well then bite the bullet and do it right$$$$$ . Because it you don't the $$$$$$$$$$$ will be to fix the fallout. Lol I love my 4x4's
    ChadsPride likes this.
  12. Dec 19, 2017 at 4:31 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    THIS. I think 33's for looks are a great and you don't have to regear or worry about cutting them out to fit like you would with dirtys. I actually just went to dirties from my 33's because I wanted more ground clearance for when I am on trail and to hit some of the more challenging spots by me. If it wasn't for the need to wheel I would have been happy with my 33s, but hey I got to clear those obstacles!
    mcharfauros and 90yota like this.
  13. Dec 19, 2017 at 4:40 AM
    Tacomamike mike
    Michael
    Not sure where @Coot83 is going lol, but I can't imagine anywhere my 33" 2.5" suspension won't take me.
    But to be sure 35" on a taco has incredible ground clearance.
    But if you get into a lot of off-roading/climbing/crawling..the 4:88's while pricey, sure does make life easier off the pavement. Plus it solves the 3rd gen mystery shift issues :)
    And for gods sakes stuff an ARB air locker in the front too!!! :thumbsup:
    TacoRD16, Coot83 and ChadsPride like this.
  14. Dec 19, 2017 at 4:47 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    You can also achieve this on OPs truck with no lift at all, see link in my sig.
    EubeenHadd, ChadsPride and Miller1103 like this.
  15. Dec 19, 2017 at 4:48 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Its for the stuff that the big lifted trucks go. Also with my truck being LT, I naturally am a little shorter than the standard lifted taco. There is a grueling trail about 2 hours from me that if you don't have 34s, you will have to scrape through just to survive it so I finally committed to going up in dirties.
  16. Dec 19, 2017 at 4:59 AM
    Tacomamike mike
    Michael
    :thumbsup: LT hmmmmmm me want !
    Coot83[QUOTED] and ChadsPride like this.
  17. Dec 19, 2017 at 5:16 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Its never too late brother to join the dark side!
  18. Dec 19, 2017 at 5:24 AM
    Tacomamike mike
    Michael
    its a thought :thumbsup:
    ChadsPride and Coot83[QUOTED] like this.
  19. Dec 19, 2017 at 6:39 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    315/75R16s on a 3" lift. Big CMC, minor plastic trim, and just beat the pinch weld flat. No firewall.beating required. UCAs and forward caster are a must otherwise you won't be able to get aligned properly to avoid rubbing.
    This is full stuff on the front.
  20. Dec 19, 2017 at 6:41 AM
    ChadsPride
    :drool::drool::drool::drool::drool:
