How can I repair my junk plastic tool case?
Discussion in 'Garage / Workshop' started by drewskie, Nov 1, 2018.
  1. Nov 1, 2018 at 1:47 PM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    You guys are good ad this stuff, so I will ask here. I have one of those million-in-one shitty tool kits that I got from Costco, and surprisingly the tools themselves work pretty well and I use the kit all the time. The problem is the garbage, blow-molded plastic case the tools came in. It has cracked completely on both hinges and on the locks so it is impossible to carry unless it's in 3 pieces which is a huge pain. If I buy hinges they will end up costing more than the damn tool kit is worth. Also, I know I can just toss them and buy a quality set but I hate wasting perfctly good stuff for no reason. I was thinking maybe velcro straps? Zip ties somehow? I don't care how ghetto it is as long as it works. Any ideas?
  2. Nov 1, 2018 at 1:49 PM
    AugustusJack
    AugustusJack Well-Known Member
    A.J.
    NW WA
    '19 DCLB OR, '00 XC 3.4L 4wd MT
    Velcro straps likely the simplest and most reusable? Small squares on the box itself to keep the straps aligned while traveling if needed.
    wilcam47 likes this.
  3. Nov 1, 2018 at 1:56 PM
    drewskie
    Drew
    Burbank, CA.
    Yeah, i think I will give those a shot, just not exactly sure how to mount them.
  4. Nov 1, 2018 at 2:01 PM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    Ratchet strap
  5. Nov 8, 2018 at 9:48 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Just buy a $5.00 tool bag for them then call it a day?
    drewskie[OP] and wilcam47 like this.
  6. Nov 8, 2018 at 10:30 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  7. Nov 9, 2018 at 10:32 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    JB weld a pair of cheap hinges in their place?
  8. Nov 10, 2018 at 1:30 PM
    drewskie
    Drew
    Burbank, CA.
    I didn't think about that. Does JB weld work on that thin junky plastic?
  9. Nov 10, 2018 at 10:26 PM
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    sure. It's great at bonding plastic to metal. If the old hinges are still there you can just weld it together with the stuff. Apply liberally and give it time to cure.
    wilcam47 and drewskie[OP] like this.
  10. Nov 16, 2018 at 11:19 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    I have 1/16 rubber gasket material i make hinges out of all the time. Use a good adhesive. Mines fabric reinforced, but for your app anything will do. Might even be able to pop rivet in place depending on how much room you have
    drewskie[OP] likes this.
  11. Dec 18, 2018 at 12:05 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Plastic gets brittle with age .
    I have boxes from Snap On that cracked the same way being 20 plus years old.
    depending just what you want to do many options Tool Bag buy a cheap tool box
    I have used them all
  12. Dec 20, 2018 at 11:24 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
