How can I make 295/70/R18 tires fit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yotaking11, Jul 19, 2016.
  1. Jul 19, 2016 at 2:16 PM
    Yotaking11
    Yotaking11 [OP] I'll make ya famous
    Jacob
    Virginia
    06 4.0 4x4 double cab Tacoma TRD
    Supercharged Bully Dog Chip Body armor accessories
    I have an 06 4.0 4x4 double cab that came with 265/70/R17 stock. My tires are worn out and I have been looking for some new ones and found a great deal on a set of 295/70/R18 with XD rims. I have a body armor bumper on that took away alot of the lower front bumper (if i would had to of trim anything on it) but what else would I have to do to make them fit. In the cheapest but most effective way?
  2. Jul 19, 2016 at 2:22 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Not gonna work
  3. Jul 19, 2016 at 2:25 PM
    Nighthawk
    Levi
    Casper Wyoming
    You would have to have a lift with tires that big
  4. Jul 19, 2016 at 3:00 PM
    Pigpen
    Northwest Montana
    You can totally do it without lifting. Remove the strut assembly, mount the tire/ wheel, and lower the truck to the ground. Now cut out anything that touches the tire. Next turn the steering wheel all the way one direction, cutting off anything that the tire touches along the way. Repeat that last step turning the other direction. Now put the strut assembly back in and enjoy!
  5. Jul 19, 2016 at 3:03 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    ^^^^ This.
    Maybe add some paint/undercoating at the end to prevent rust.
    Also plan to cut a lot of shit off.
  6. Jul 19, 2016 at 3:14 PM
    TACOtrd1106
    TACOtrd1106 Well-Known Member
    Cali
    2012 Black TRD 4x4
    Cab mount chop is a must
    Pigpen likes this.
  7. Jul 19, 2016 at 3:19 PM
    Pigpen
    Northwest Montana
    OP would figure that out when the tire was pressed against the cab mount :D
    TACOtrd1106[QUOTED] likes this.
  8. Jul 19, 2016 at 3:20 PM
    Nighthawk
    Levi
    Casper Wyoming
    Or you can just lift it and not have to cut as much off. 34 inch tires will look ridiculous with no lift, not to mention you will have no clearance between your tire and wheel well.
  9. Jul 19, 2016 at 3:20 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    :popcorn:
    ib4 the "I did this with a 1" spacer lift and it fits fine" guy.
    Unchained 5150 and eccracer104 like this.
  10. Jul 19, 2016 at 3:20 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    You can fit it with a lot of cutting and trimming. I run 295/70-17 I'm lifted, did the cab mount chop and cut away all the plastic. It still rubs sometimes.
    digitaLbraVo likes this.
  11. Jul 19, 2016 at 3:21 PM
    Pigpen
    Northwest Montana
    @Yotaking11
    I appreciate your enthusiasm. Most people don't come in with such bold plans Welcome to the TacomaWorld family! :cheers:
  12. Jul 19, 2016 at 3:24 PM
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
  13. Jul 19, 2016 at 4:15 PM
    Arcticelf
    Gladiator
    Not really. If he doesn't do something about up travel we all end up at the same point at full stuff. A spacer lift will help, but that's just moving the problem.
  14. Jul 19, 2016 at 4:21 PM
    Pigpen
    Northwest Montana
    I vote trim now and lift later. You're going to have to trim anyway - might as well get it out of the way. Pun intended.
    Arcticelf likes this.
  15. Jul 19, 2016 at 4:51 PM
    digitaLbraVo
    Wanting tires that big without lifting I see a big shitty drop bracket lift in the OP's future. Complete with under glow and color changing halos. He isn't gonna want or need to trim for travel.
    eccracer104 likes this.
  16. Jul 19, 2016 at 4:53 PM
    Pigpen
    Northwest Montana
    Maybe he's saving his duckets for extended travel Kings with resis and clickers...
  17. Jul 19, 2016 at 4:54 PM
    digitaLbraVo
    Should put those on before big 'ol mall crawler 18" wheels.
  18. Jul 19, 2016 at 5:07 PM
    Pigpen
    Northwest Montana
    But he found a good deal on the wheels and tires - Craigslist, maybe? If that's the case, I totally encourage this kind of behavior.
  19. Jul 19, 2016 at 5:11 PM
    digitaLbraVo
    On the bright side: a harbor fright reciprocating saw is probably cheap? It may even work long enough to finish the cuts to get these things to fit!
    :sawzall:
    Pigpen[QUOTED] likes this.
  20. Jul 19, 2016 at 5:46 PM
    Arcticelf
    Gladiator
    We can all hope.
