How can I clean up this battery wiring?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Mar 15, 2019.
  1. Mar 15, 2019 at 8:14 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Installed some accessories including a breaker and blue sea fuse box along with a 27M X2 Power agm. The battery leads are long enough to reach the posts, though not the cleanest arrangement. But what I’m wondering is whether or not it’s acceptable to use busses for both positive and negative connections to the battery.
    I have a solar charger and aux fuse box connected to the battery currently. Can I run cables from the marine posts to positive and negative busses, then connect solar, and aux fuse panels (I plan to run aux power to another fuse box in the bed) to those?
  2. Mar 15, 2019 at 8:25 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    xxTacocaTxx and angeldavid216 like this.
  3. Mar 15, 2019 at 8:55 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    https://sdhqoffroad.com/products/sdhq-built-hd-billet-main-battery-terminal-upgrade-kit
    JoeCOVA and DavesTaco68 like this.
  4. Mar 15, 2019 at 9:05 PM
    Rujack
  5. Mar 15, 2019 at 9:11 PM
    Rujack
    Ok, at first glance I misunderstood how both of these work. They will work of course, but what I really would prefer is keeping my starter connected to the main posts, but then have aux buses mounted somewhere, powered by heavy gauge connections to the marine posts. Then just have my aux fuse boxes connected to those buses.
  6. Mar 15, 2019 at 10:13 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
  7. Mar 16, 2019 at 1:31 AM
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    All your wires are too short.
    Only way to get a really nice clean look is your own custom made lengths.
    Use a distribution box instead all wires going to your battery. Use OFC cables.
    If you decide to, you will need good proper crimping tool / solder/ heat shrink.
    When I did a motor swap years ago, I have yet to have anything get loose. All clean hidden wires.
    Don't let anything rub against the cables/ wires.
    Small wires use wire loom and tape.
    Just keep everything nice and tight.
    I would highly recommend a breaker switch.
    Working on any electrical is a breeze with a breaker switch. Switch on/ off without touching the battery clamp bolts and of course having a breaker switch.
    Screenshot_20190315-221645_eBay.jpg Screenshot_20190315-222838_eBay.jpgScreenshot_20190315-223418_eBay.jpg
  8. Mar 16, 2019 at 10:12 PM
    Rujack
    Nice, thank you. Do you have a crimp tool in mind? I’ve seen so many different types including hydraulic.
    What are OFC cables? I searched but only came up with fiber optic.
  9. Mar 16, 2019 at 10:36 PM
    Rujack
    Also, how do I figure out what gauge wire to use?
  10. Mar 16, 2019 at 10:57 PM
    Boosted_Carrera
    Hawaii
    OFC or OFHC cables are "oxygen free cables" . They're used for batteries/ amp by stereo guys due to high conductivity. O gauge for your battery will need a hammer tip ( cleanest way).
    Easiest to customize a 1/0 gauge is pre assembled .You can find one at any stereo shop. It's an amp kit.
    And USUALLY it is OFC cables for pos. and neg.
    Before clamping things down, check your voltage.
    Negative side should be around .04vdc. A good ground is just as important.
    These tools are great to have as it seems you like to work on your own vehicles.
    Screenshot_20190316-193659_Amazon Shopping.jpg Screenshot_20190316-193223_Samsung Internet.jpg Screenshot_20190316-193120_Amazon Shopping.jpg
    Rujack[QUOTED][OP] likes this.
  11. Mar 16, 2019 at 11:07 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Fyi "oxygen free cables" are total bullshit, especially if it's just power delivery.
    Rujack[OP] likes this.
  12. Mar 16, 2019 at 11:18 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    This hydraulic crimper is pretty good, just used mine fornthenfirst time today and I like the results much better than a hammer one.
    https://ebay.us/tIFrUH
    jmneill and Rujack[QUOTED][OP] like this.
  13. Mar 17, 2019 at 7:10 AM
    Rujack
    Mind checking what size dies those are? Can’t tell from pics and description doesn’t mention them...
  14. Mar 17, 2019 at 7:12 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Grossomotto[QUOTED] likes this.
  15. Mar 17, 2019 at 7:16 AM
    4x4yotaphan
    4x4yotaphan Well-Known Member
    SoCal
    SOLD: 2016 White TRD Sport DCSB 4x4
    Exterior: King suspension w/compression adjusters Icon billet UCAs Icon 3 leaf expansion pack Timbren rear bump stops w/U bolt flip kit Wheeler’s Offroad front superbumps BFG KO2 285/70/R17 on SCS Ray 10 17” wheels w/black wheel lock lug nuts TRD Pro grill TRD Pro taillights TRD Pro skid plate Demello Offroad front bumper Smittybilt XRC 9.5 comp winch w/Factor 55 fairlead and Flatlink E RCI LCA skids Beast Fab rock sliders 4 Extreme LED 4” pods Baja Design Squadron SAE LED amber fog lights Relentless Fab bedrail mount w/KC Flex dual amber chase lights AVS vent visors Interior: TRD Pro shift knob OEM instrument switch panel conversion (from 3 to 5 slots) Taco Garage DMM with Scosche Magicmount Upgraded Kicker sound system Husky X-act floor liners Performance: Airaid cold air intake system Pedal Commander w/Bluetooth
    JoeCOVA and Landpirate like this.
  16. Mar 17, 2019 at 7:30 AM
    Landpirate
    Landpirate Strong like horse, smart like tractor
    North Texas
    2018 Tacoma BBP SR5 4x4 DCSB
    OME HD leafs, 5100s, CaliRaised skids, UpTop Overland Bravo, KB Voodoo rack, Overlander RTT/awning, DECKED
    4x4yotaphan[QUOTED] likes this.
  17. Mar 17, 2019 at 7:58 AM
    OnHartung'sRoad
    They are punched with numbers - 2 through 150 or so. May be mm, still sleeping in... will get back soon. ;)
  18. Mar 17, 2019 at 8:27 AM
    JoeCOVA
    Joe
    Colorado Springs
    Grossomotto[QUOTED] and TACOVRD like this.
  19. Mar 17, 2019 at 10:14 AM
    Grossomotto
    2017 4WDV6LB6MT
    Do they come with two post adapters or just one for negative?
  20. Mar 17, 2019 at 12:08 PM
    ferntr33
    ferntr33 Well-Known Member
    Go to a welding supply store with the lengths you need and the terminals you want and they will sell you the cable and crimp the ends on for you. You just need longer cables to go around the battery instead of over top of it. I got those military style battery clamps as you can connect 4 wires easily and they look clean and are cheap.
    Here is my inspiration.
    https://www.tacomaworld.com/threads...oma-builds-on-to-new-adventures.528480/page-8
