How big of a tires fits a stock 03 Tacoma without rubbing?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hawaii2OH, Aug 4, 2023.
  1. Aug 4, 2023 at 6:36 AM
    Hawaii2OH
    Hawaii2OH [OP] Active Member
    2003 Tacoma 4x4
    Can I fit a 265/75/16 without rubbing or how big of a tire will fit stock 2003 Tacoma?
  2. Aug 4, 2023 at 6:44 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
  3. Aug 4, 2023 at 8:05 AM
    GoJo
    GoJo Well-Known Member
    Utah
  4. Aug 4, 2023 at 8:11 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I have 265/70/16s. Big as I could go (and wanted to for that matter).
  5. Aug 6, 2023 at 9:27 PM
    spidiracer
    spidiracer Member
    I have 265/75/16's and they rub. I assume it's on the pinch welds... I need to do that mod.
    Just sharing my experience. I have stock height suspension and they are Toyos.
  6. Aug 6, 2023 at 9:41 PM
    DoubleC
    DoubleC Well-Known Member
    Christian
    Oxford, MS
    1999 Tacoma 3.4 TRD (Natural White - the best white)
    no lift, 31" diameter.
    265/75 16 is about 32
    If you want it to fit nicely, add a 2" lift. If you don't care how nicely it fits, smash the pinch welds in and call it a day.
  7. Aug 6, 2023 at 10:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I mean, did you even try?
  8. Aug 6, 2023 at 10:19 PM
    DoubleC
    Christian
    Oxford, MS
  9. Aug 6, 2023 at 10:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    But really to add some helpful info, a lift (with the exception of a drop bracket kit) will not aid in fitting a larger tire so stock or not, a 265/75/16 is ideally the largest tire you can fit without interference.
    You can get away with slightly larger, but the only person that can answer "how much larger" is you seeing as how every single truck varies slightly.
  10. Aug 7, 2023 at 5:21 AM
    DoubleC
    Christian
    Oxford, MS
    This is true. Any larger than 265 and you’re gonna have to do something other than a lift. I have found 2” lift and 255/85 16 (33 x 10 pizza cutter) to be great. Performs great off-road, had to smash the pinch weld, but no rubbing at full lock, and imo the best looking tire on first gens. Very rare with only 4 brands making the size. I’ve got Yokohamas :D
  11. Aug 7, 2023 at 9:06 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    265/75/16 is the largest you're going to go before encountering rubbing - especially at full lock left or right. A good alignment, stock upper control arms, stock suspension will all factor into the 'will it scrub the frame' question.
    If you don't or can't install a lift then stick with 265/70 or 265/75 16's. Just be aware you'll hit the frame a little at full lock. Just don't turn the wheel all the way and you'll be fine.
    Moving away from stock 1st gen taco/3rd gen 4Runner wheels will also cause issues. Anything beyond a 4.6 backspace and you'll need additional mods to make it work.
    In addition to threads mentioned above, take a look at this write-up.
    https://adventuretaco.com/guide/what-size-tires-fit-my-lifted-tacoma/
  12. Aug 7, 2023 at 9:15 AM
    Area51Runner
    Seems like everyday someone creates the same thread on 4x4 not working, prerunner 4wd conversion, blah blah blah. It's a given and nothing is going to change it.
    Ignore the bs comments. Ya just joined the forum. Definitely use the search feature when possible and check the sticky threads but no need to feed the posts giving you crap.
  13. Aug 7, 2023 at 1:57 PM
    Hawaii2OH
    2003 Tacoma 4x4
    Thanks bro. I’m new around here but you gotta love when the kids want to act like they run stuff
    Taco Wedo likes this.
