How big a tire can I go with a factory leveling kit already on my 2023 Tacoma 4+4 trail edition ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Latoyathetoyota, Mar 3, 2023.
  1. Mar 3, 2023 at 7:27 PM
    Latoyathetoyota
    Latoyathetoyota [OP] New Member
    New Jersey
    2023 magnetic grey Tacoma 4+4 trail edition
    None yet
    I’m sure this is a FAQ here but I recently bought a 2023 Tacoma trail edition and the dealer told me it already has a factory leveling kit on it . It has 265 70 r 16 on it but looks to be plenty of room to go bigger . My question is without cutting my truck up how much bigger a tire could I go ?
  2. Mar 4, 2023 at 1:09 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
  3. Mar 4, 2023 at 2:33 AM
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    265/75/16
    or 35s and :sawzall:
    or 255/85/16 with the right offset wheel.
    A 0-3” lift doesn’t affect max tire size generally speaking.
  4. Mar 4, 2023 at 2:34 AM
    guest_707
    guest_707 Well-Known Member
    255/85r16
  5. Mar 4, 2023 at 2:34 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    285s with a good alignment might fit if the wheels are a +4 offset. Maybe add a 1/2 spacer for a little more lift.
  6. Mar 4, 2023 at 4:30 AM
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    255/85/16 pizza cutters will be fine with those wheels and that’s a real 33”.
    285/75/16 will work with some alignment and trimming. Yea, you will need to trim stuff if you off road at all.
    265/75/16 if you want slightly larger and don’t want to worry about changing anything else.
  7. Mar 4, 2023 at 7:52 AM
    Latoyathetoyota
    New Jersey
    None yet
    Great info thank you guys so much ! I’m thinking of going 265/75/r16 which I believe is a 32 so I don’t have any issues . I’m not a hardcore off-roader but I want her sitting right with a more aggressive larger tire . Thinking the MT Baja 500 a/t hybrid . Any input is much appreciated, thx again !
    BC Hunter and SnuggleTruck like this.
  8. Mar 4, 2023 at 8:09 AM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    You could get a pretty good price selling the 16” rims and go to a 255/75R17 tire on (Toyota) wheels. 32.5” OD, and a fairly decent range of tire choices with that being a Wrangler size.
    Latoyathetoyota[OP] likes this.
  9. Mar 4, 2023 at 8:16 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I have the 275/70r17's and they are just over 32. No special alignment or upper control arms and about 2 inches vs factory higher in the front. I trimmed away some of the cosmetic plastic from the inside rear of the front fender wells. I don't beat the truck up off road but I go out in the desert and the mountains etc. With the -10 offset wheels I have I get a very slight tell of some contact with the outside edge of the tread. You can see in the picture, maybe, what I am talking about. Strangely, it seems like the tad bit of rub occurs while driving around town.
