How best to eliminate axle wrap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skynet Surfer, Mar 4, 2020.
  1. Mar 4, 2020 at 6:04 PM
    Skynet Surfer
    Skynet Surfer [OP] Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    I have a 2015 4x4 dc 4.0 sr. I'm consistently dealing with axle wrap issues. What's the best way to solve this? I've been thinking about rear springs. I lubed the drive shaft slider. Yet if I stop suddenly in LA traffic I always get this. I don't have a lift or leveling kit. Yet thinking about doing that later.
    Thanks for any help.
  2. Mar 4, 2020 at 7:13 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    What makes you think you have axle wrap?
  3. Mar 4, 2020 at 7:16 PM
    Bishop84
    Bishop84 Well-Known Member
    How can you tell the pinion is winding up?
    Usually axle wrap is on hard acceleration with grip. Or in high torque low range offroading.
    Worn, curved leaf springs will do this easier, but its not typically a daily issue.
    A quality set of springs will fix this, the stock Toyotas are awful.
    A drastic method is to use traction bars, but they are usually for the big rear lift kits.
  4. Mar 4, 2020 at 7:26 PM
    badger
    badger Well-Known Member
    07 SR5
    Yeah, If you have stock springs you have axle wrap. Ss mentioned, good aftermarket springs will fix it.
  5. Mar 4, 2020 at 8:04 PM
    Skynet Surfer
    Dis
    15 DC v6 SR
    Hard braking and soon as I let off the brake the truck lurches hard forward. Already greased the yoke on the driveshaft. Yet is still does it under hard braking. It used to be more violent before I greased the yoke. Violent as in it would lurch 3ft forward. I can feel it on acceleration but not that dramatic compared to the lurching. So if it's not axle wrap and not the driveshaft yoke. What could it be?
  6. Mar 5, 2020 at 2:23 AM
    Stormtrooper457
    Stormtrooper457 Well-Known Member
    Indiana
    2013 TRD Sport DCLB
    Nano Ceramic Tint Heated Clazzio Seats TRD Pro Wheels Softopper
  7. Mar 5, 2020 at 2:51 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  8. Mar 5, 2020 at 2:52 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    I had lurching coming to a hard stop. It was caused by a hard late downshift. I even thought someone rear ended me at a stop light once.
    Remedy was more transmission fluid, there was a slow leak on the output shaft seal.
    PzTank likes this.
  9. Mar 5, 2020 at 3:02 AM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I posted this a little while ago on another post, but related... It works as a band-aid.
    https://www.tacomaworld.com/threads/replaced-driveshaft-still-vibrates.654638/page-4
    Also check transmission mount. If the rubbers are bad, it can let the driveshaft raise higher on acceleration, which increases pinion angle, which bends the front half of the leaf pack more, which increases axle wrap. Easy test is to push up on the tcase, if the transmission mount pushes up easy until the limiting bolt hits, and you hear 'ting', rubber is busted.
  10. Mar 5, 2020 at 5:38 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Turn it into a dually
  11. Mar 5, 2020 at 6:02 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Make sure to check the torque on the rear U-bolts. Should be at 73 ft/lbs. In your case, I think it's more likely normal transmission shifting, especially if it only occurs after hard braking.
  12. Mar 5, 2020 at 7:32 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
  13. Mar 5, 2020 at 7:42 AM
    su.b.rat
    su.b.rat broken truck
  14. Mar 5, 2020 at 7:45 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    su.b.rat[QUOTED] likes this.
  15. Mar 5, 2020 at 7:49 AM
    su.b.rat
    truth is the bar itself is good and, for me, eliminated wrap and gained me a ton of performance at the rear. no doubt.
    but the bracket is not finished, actually i'd say it's not even designed. it's a joke.
    i have already discussed with Pablo and he's wanting to gusset the hell out of it at the axle housing and try again. i'm game for that plan. truck is gonna be in pieces starting next week so i may see if he has time to do it this round. i want the bar back, but must do my own bracket solution.
  16. Mar 5, 2020 at 7:54 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Good luck I’ll be on the look out for the end result.
  17. Mar 5, 2020 at 8:28 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I wouldnt bother with budbuilt. had one on my truck and it was more trouble that it was worth.
