How bad is it f my A/T temp light to come on?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TuckHolladay, Feb 17, 2021.
  1. Feb 17, 2021 at 3:37 PM
    TuckHolladay
    TuckHolladay [OP] Well-Known Member
    JT
    NJ
    2015 TRD Offroad, Blue, stock for now
    So I just got myself pretty stuck in some deep snow. I unstuck myself, but making it back to the road I noticed the Trans temp light had come on. I shut it off immediately and waited a while. It isnt on anymore. I’m almost at 100,000 I’m wondering if I need to go get this flushed soon.
  2. Feb 17, 2021 at 3:40 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    I can't remember how hot you have to get it to turn on. I think 280? The light is pretty useless.
    But yeah, it would be smart to drain and fill the trans
    SR-71A and Mully like this.
  3. Feb 17, 2021 at 3:40 PM
    AKTacoParty
    AKTacoParty Well-Known Member
    Jake
    Astoria, OR
    2013 DCLB
    885s, Dakars, Bilsteins, Allpro Sliders, Archive Garage Hammer Hangers, Wheelers Ubolt flip, super bumps, RCI front skid
    Most people will recommend a drain and fill at that mileage. Instead of your traditional flushing service
    gearcruncher and Mully like this.
  4. Feb 17, 2021 at 3:43 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Oil temp light comes on at 302 degrees. Get the fluid changed. Good luck.
    eherlihy and LoveableWerewolf like this.
  5. Feb 17, 2021 at 3:43 PM
    Mully
    CA
    Yes, drain and fill.
    LoveableWerewolf likes this.
  6. Feb 17, 2021 at 3:45 PM
    LoveableWerewolf
    Nashville
    Oh my, even more useless than I thought. Pretty cooked.
    You'll probably be fine, just drain and fill the fluid. It's due anyway, life happens.
    Mully[QUOTED] likes this.
  7. Feb 17, 2021 at 4:28 PM
    gearcruncher
    Canadain bumper technician
  8. Feb 17, 2021 at 4:50 PM
    AKTacoParty
    Jake
    Astoria, OR
    2013 DCLB
  9. Feb 17, 2021 at 5:19 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Like everyone has already stated. Drain and Fill.
  10. Feb 18, 2021 at 5:16 AM
    TuckHolladay
    JT
    NJ
    drain and fill if you’ve never flushed before?
  11. Feb 18, 2021 at 5:27 AM
    AKTacoParty
    Jake
    Astoria, OR
    2013 DCLB
    Yes, generally with higher mileage transmissions that havent had regular fluid changes you will have clutch material in your fluid. The belief is that flushing the trans with a machine, usually backwards flushing, will cause that material to get stuck in various parts of the valvebody causing issues or that the fluid helps the friction surfaces and may cause your trans to slip after. YMMV
  12. Feb 18, 2021 at 4:44 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I would drain, replace ATF filter and clean the pan in order to get a good look at the crud build up.
    Refill
    Run for 30 seconds.
    Drain and refill again.
    i’m wondering if it would have been better not to turn off the engine. Keeping the engine running would push the ATF through the ATF lines, allowing for quicker cooling. If you didnt know the cause, I would have shut it down also. Here, you knew it was related to getting stuck. Or, maybe you hadn’t made the connection then? Just thinking outloud ...
  13. Feb 19, 2021 at 6:00 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    I too was thinking the same thing,
    your ATF goes to a cooler does it not? The answer to this question does nothing to help OP, but it might help another.
  14. Feb 19, 2021 at 1:32 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ATF light comes on when shit gets REAL hot.
    Do a full proper drain n fill of 11ish quarts.
    Also... next time, 4LO, keep her in lower gears and rpms up, this will put way less load on the trans and generate WAY less heat.
  15. Feb 19, 2021 at 2:51 PM
    03maurderman
    03maurderman Well-Known Member
    Had a 2006 Matrix that I bought new & did a drain & fill every 25k miles...Doing the same with my 2.7 Tacoma....Not sure how to do this with a 6 cyl...There's a lot to be said for old technology.....
  16. Feb 19, 2021 at 2:57 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    OP you have 2 options, You can drain and fill it, or take my $500 bucks for it.
