How are u-haul hitches?
Discussion in 'Towing' started by jpg366, May 14, 2009.
  1. May 14, 2009 at 6:38 PM
    jpg366
    jpg366 [OP] Well-Known Member
    AL
    09 Silver Prerunner SR5
    Hitch, Running Boards
    Anyone have experience with the U-haul class-iii hitch? It seems pretty reasonably priced. I have a 2009 Tacoma Prerunner SR5 V6 on order, figuring to add a hitch myself. No plans for heavy towing, just occasional small stuff, under 2000 lbs. Vehicle will be garaged.
  2. May 14, 2009 at 6:42 PM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to the site.
    How much are they asking for it?
  3. May 14, 2009 at 7:07 PM
    jpg366
    AL
    I recall the web price being around $160.00, not including accessories. Bare price, not installed.
    edit - checked again, it was quite a bit lower.
    Hitches for a 2009 Toyota Tacoma
    Hitch# Type ClassMax weight Max distribution weight Finish Price 78279 Round Tube Rec. 3 5000 6000 Black $119.95
  4. May 14, 2009 at 7:08 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    toyotas towing package FTW. Transmission cooler comes with it. Not to mention everything is installed.
  5. May 14, 2009 at 7:09 PM
    98tacoma27
    Ben
    Not Beech Creek
  6. May 14, 2009 at 7:22 PM
    jpg366
    AL
    Thanks for the links. It seems the low end is around $120. Toyota's package, including tranny cooler, was many $hundreds higher. Not a bad price, but I work cheaper on weekends than they do.
    I recall hearing that u-haul offered a pretty inexpensive "lifetime" guarrantee. Any thoughts about square vs round tubing in the construction?
  7. May 14, 2009 at 7:34 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i was all set to put one on my 96, but the company I originally had put a hitch on my truck took it off and put the one i wanted on.
    I wouldnt think twice about putting one on, unless you do alot of heavy towing. Then it would be wise to get the towing package
  8. May 14, 2009 at 7:37 PM
    98tacoma27
    Ben
    Not Beech Creek
    My thought are this, and I believe you will find this a lot:
    All hitches have to be made to a standard (or class). The class in which they fall designates the weight load (I am sure you already know this). Therefore, the construction and materials all have to meet the same rating/standards. To me, it doesn't matter what it is made of (square vs round) because of the previous stated reason. I will personally look for easy of installation in this case. I would look to buy a vehicle specific hitch that doesn't not require drilling at a competitive price.
    Just MHO
  9. May 15, 2009 at 2:22 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I have the U-Haul hitch you are asking about. It was $120+tax and the harness which I believe I got for $40 is simple plug and play, I spent less than $200 for everything.
    The hitch is fairly easy to install with a little help and the proper tools or uhaul will install. I did the install myself, so I don't know what they charge.
    I rarely tow and when I do it is maybe 2000lbs. I haven't had a problem with the hitch and I like how it tucks under the truck so it is not as visable as some others.
    Lifetime warranty is $5 with installation.
  10. May 15, 2009 at 7:49 AM
    eschmunk
    eschmunk Well-Known Member
    Stuttgart, Germany
    09 Prerunner TRD Off-Road
    GrillCrafter Upper and Lower, Lamin-X Fog Light Covers, Di-Noc Carbon Valence Cover, WeatherTech Digital Fit Liners, Rubbermaid "ActionPacker" containers for bed storage.
    Can't speak for the u-haul hitch. I got the towing package from Toyota, haven't used it yet but soon enough.
  11. May 16, 2009 at 5:38 AM
    MWCmike
    MWCmike Member
    Midwest City, OK
    08 Double Cab PreRunner
    None yet
    My local U-Haul quoted me $109.00 for their hitch. I went to the Toyota dealership and got the hitch ($179.00) and the harness ($95.00) yesterday. The OEM hitch has 6 attach points vs the 4 for all the aftermarket stuff I have seen online. Just seems like a better hitch to me.
  12. May 16, 2009 at 8:11 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    I have the Uhaul hitch. It has the round tubes that lead to the frame, but don't hang down low. Tucked out of the way better than the other brands. It's actually manufactured by Valley. Comes with clear instructions. Installs in about 20 mins. It has 6 points of attachment (bolts).
    The wiring kit is best bought from Toyota, (IMO) as it adds 1 relay, 1 module, and 2 circuits. Expensive, but not a bad deal considering it's the only one that won't have questions asked if you have (warrantable) electrical problems in the future. The kit Uhaul tried to sell me was much cheaper up front, for a reason. The toyota kit runs from the module in the kick panel, all the way to the back.
  13. Jul 21, 2009 at 8:15 PM
    jpg366
    AL
    Update- I received the Valley hitch from U-Haul ($120) today, and installed it with no problems. Shipped from Dallas the day after I ordered it, got here in 2 days via Fedex ground. I expected a Class-III, but was sent a Class-IV. Fit was excellent. I'll get the wiring kit from Toyota ($104 quoted by phone) and install it this weekend. Thanks to all for the guidance.
  14. Jul 21, 2009 at 8:19 PM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
  15. Jul 22, 2009 at 3:12 AM
    FoxySandChick
    Kristin
    Henderson, NV
    You don't need the wiring from Toyota, you can get it much cheaper than $104. Check out the Towing Bible section on adding wiring to a non-wired truck. It is simple, remove taillights and plug in.
    Get the 4-flat wiring adapter: Hoppy electronic tail light converter part number 43355. I got mine at a local auto parts store and I think it was $60.
    http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html
  16. Jul 28, 2009 at 9:00 PM
    jpg366
    AL
    Update #2. Ended up with Toyota's wiring kit. Took a couple of hours to install. Sure was nice to have all that ground clearance!
    Probably could repeat it in an hour, now that I know how things come apart and exactly where the harness connectors are. BTW, found a nice 4-wire tester for $4 at Northern Tool.
  17. Jul 30, 2009 at 5:18 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Do you have pics of your uhaul hitch? I'm planning on getting one within the next couple weeks. Toyota just quoted me $450 + tax for theirs and installation. I said f**k that.
  18. Jul 31, 2009 at 3:25 AM
    FoxySandChick
    Kristin
    Henderson, NV
    I don't have pics, but it looks really good. It tucks up under the truck, so it doesn't really show, the only part that is noticable is the square receiver.
  19. Aug 1, 2009 at 6:00 PM
    jpg366
    AL
    I'll see if I can put some up tomorrow. U-haul site has pic of the bare hitch. Flanges bolt up (2 bolts per side) to bottom of frame rails, then two to middle of bumper. Only part visible from rear is the receiver, which does not stick out beyond bumper. No sore shins. You'll need to be able to measure 150 ft-lbs torque for the 4 frame bolts.
  20. Aug 3, 2009 at 8:13 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    That'd be great! Thanks :)
    Just what I wanted to hear. I just didn't want the hitch to protrude awkwardly and be an eyesore
