How 2 remove ignition assembly from steering column?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crackedmirror, Jul 7, 2021.
  1. Jul 7, 2021 at 8:33 AM
    crackedmirror
    crackedmirror [OP] Well-Known Member
    The bolts holding it there have no grabby ends.
  2. Jul 7, 2021 at 9:14 AM
    drewmox
    drewmox Well-Known Member
    Andrew
    2003 4x4 3.4L Black DC
    SS3 Fogs, Bilstein 5100s, KC Cyclone 3rd brake, stock AF otherwise.
    The only ignition cylinder I’ve removed was from a Honda Element. To get those security bolts off you need something like an impact safe screw driver. You need to hammer the hell out of the bolts at an angle on that lower section until the bolts start to spin. Then you can usually get them off my hand.
    make sure you use new security screws when you put the new cylinder on unless you want someone to bring their own to take your truck. :locked:
    crackedmirror[OP] likes this.
  3. Jul 7, 2021 at 9:18 AM
    crackedmirror
    would cutting a slot using a hacksaw and unscrewing using a flathead also work? i'm guessing they're red loctited as well.
    tsab916 and ControlCar like this.
  4. Jul 7, 2021 at 9:26 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    That would be my first step, or possibly sting on an impact hex shank and break them loose that way.
  5. Jul 7, 2021 at 9:32 AM
    Glamisman
    Glamisman Well-Known Member
    center punch the the shear bolt and drill it out. A left hand drill bit works best as if it bites, it unscrews the bolt for you. Once you have one loosened the other should unscrew with your finger tips.
    Wyoming09 and crackedmirror[OP] like this.
  6. Jul 7, 2021 at 9:36 AM
    drewmox
    Andrew
    If you can get a hacksaw in there. A dremel with a metal cutting wheel would be easier.
  7. Jul 7, 2021 at 9:37 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Whats the end goal here? If you're re-keying or changing the cylinder, you don't need to get that apart.
  8. Jul 7, 2021 at 9:41 AM
    crackedmirror
    paint
  9. Jul 7, 2021 at 1:40 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I venture you can try a bunch of ways but will end up drilling!
    Working for the Lock Smith we always just drilled.
  10. Jan 26, 2024 at 8:45 AM
    Cborice
    Cborice New Member
    Rodney
    Toyota tundra 2001
    Lifted
    Are these brass?
  11. Jan 26, 2024 at 7:43 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    ^^^^awesome….softer metal!
  12. Jan 26, 2024 at 7:48 PM
    ControlCar
    Steven
    Sugar Land TX
  13. Jan 26, 2024 at 8:26 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You need a sharp chisel and hammer, tap backwards and they will loosen up. There's no lock-tite on the threads, usually you can get them turning with your finger once they're loose
