Hot water through a pressure washer?
Discussion in 'Garage / Workshop' started by spitdog, Oct 6, 2019.
  1. Oct 6, 2019 at 12:28 PM
    spitdog
    spitdog [OP] Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    So after being a religious fluid film user since I bought my 2015 Im getting the urge to lightly pressure wash my frame with hot water from the house. Thinking about running a hose from the boiler to a regular light duty pressure washer. I would like to get of all the road grime and of course reapply. Will the hot water screw up the seals in the pressure washer?
  2. Oct 12, 2019 at 1:00 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It would depend on just what model you have Any Warning Do not exceed ?? degree water .
    Since your talking water in the area of 200 Degrees not super heated steam
    Not really sure hot water will give you that much more cleaning .
    shane100700 and wilcam47 like this.
  3. Dec 19, 2019 at 1:00 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    I've heard hot water will ruin your pressure washer.
  4. Dec 19, 2019 at 1:03 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The real question what is Hot??
    robssol likes this.
  5. Dec 19, 2019 at 1:08 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
  6. Dec 23, 2019 at 4:40 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If you're talking tap water "hot water" then you should be fine. I can't see water that is limited so it doesn't scald your skin ruining some rubber seals.
    That said, I can't see hot tap water doing that much more than the pressure already does. Might help keep the FF runny enough so it rinses out easier, though...
  7. Dec 29, 2019 at 2:39 PM
    Xtremsiege2
    Xtremsiege2 Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    The damage is probably done if anything hotter than 145 degree was used. My company sells industrial pressure washers and our regular duty models aren't recommended to be run with anything over 145 degrees otherwise the seals will deteriorate and ruin the unit. Our hot water systems run in the ballpark of 190 to 200 degrees I believe..
  8. Dec 30, 2019 at 1:02 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Just curious do your pressure washers have any labels stating not to exceed the 145 degrees ??
  9. Dec 30, 2019 at 6:55 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    Not sure if this helps the OP, but most of my local coin-op car washes have hot water in the do-it-yourself bays. I don't use it on the body for reasons of thermal shock and stressing the paint, but I will spray off the frame, wheel wells and wheels/tires with it. Not sure what the actual temperature of the water is, but it's enough to create some steam inside the wash bay.
  10. Dec 31, 2019 at 8:51 AM
    Xtremsiege2
    Norwalk CT
    I don't believe so, its only in the manual. I dont think most tap water systems will go beyond 145 without some kind of system in place to do so(boiler heating element?)
  11. Dec 31, 2019 at 9:06 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    :pccoffee:
    Let's see some frame pics!! My local parts store has fluid film in paint cans for 20 bux! Then they are being discontinued. Wondering if it helps
  12. Dec 31, 2019 at 10:08 AM
    spitdog
    There probably discontinue them because they want to stock the new wool wax which is suppose to be thicker than FF. If it was 20 bux for a gal that’s a steal, I think I paid around $45. Rattle cans you can get for 10 bux.
    https://www.kellsportproducts.com/
  13. Dec 31, 2019 at 11:47 AM
    stealthmode
    Alberta
    Thanks. I'll keep my eyes open for that stuff. But for 20 bux a gallon I might be Filimg for a while lol.
