Hot/Load orientation of under-hood fuse box.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SilverBulletBetsy, Jan 3, 2023.
  1. Jan 3, 2023 at 5:58 PM
    SilverBulletBetsy
    SilverBulletBetsy [OP] New Member
    2020 TRD Off-Road
    K&N Cold Air Intake, Warn 10 Winch, Lightforce 20" lightbar, BA HiLine Bumper
    Hello all, and I hope my first post here makes sense.
    I am attempting to install an add a fuse and have done a good amount of research on the subject. The last thing that is holding me up is to properly orient the pigtail wire on the add a fuse.
    Ive tried searching and using my multimeter, but it’s too thick to get into the empty fuse Block.
    has anyone here previously been able to find out which side of the(any) empty (10a) fuse block gives off 12v? Thanks in advance for any help!
  2. Jan 3, 2023 at 6:12 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I'd probably trial and error this with a multimeter, but I bet @MESO knows off the top of his noggin
    SilverBulletBetsy[OP] likes this.
  3. Jan 4, 2023 at 7:09 AM
    SilverBulletBetsy
    2020 TRD Off-Road
    Well if you get a chance to go through its be super helpful! Thanks for tagging
  4. Jan 4, 2023 at 10:13 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Take the fuses out of the add a fuse, use a meter on the wire and put the addafuse into the empty slot on the lower left. Correct orientation will give you no reading, incorrect (backwards) will give you 12v.
    Kolache007 likes this.
  5. Jan 4, 2023 at 10:25 AM
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    The inside legs of the two rows of fuses are 12v supply. Orient the pigtail towards the front of the truck if using the row on the left, to the rear of the truck if using the row on the right. Thats what I did to wire my switchpro years ago and havent had any faults or failures yet.
  6. Jan 4, 2023 at 11:33 AM
    SilverBulletBetsy
    2020 TRD Off-Road
    Y’all are awesome. I truly appreciate it.
  7. Jan 4, 2023 at 11:33 AM
    SilverBulletBetsy
    2020 TRD Off-Road
    this makes so much sense yet it never crossed my mind. Thanks!
    vicali[QUOTED] likes this.
  8. Jan 4, 2023 at 11:38 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    You can also probe a blown fuse to determine which side has power. Some add-a fuse products require a fuse in the "original" circuit slot in order to reach the "added" slot. I assume it uses one leg of the original fuse to jump to the newly added circuit.
