Hot air Intake!? I thought Cold air was beneficial...
Discussion in 'Technical Chat' started by sachou, Nov 24, 2009.
  1. Nov 24, 2009 at 10:06 AM
    sachou
    sachou [OP] Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I've been thinking intakes lately, and how to improve them for any gasoline engine, and had believed very firmly that:
    Cold air=better
    More air=better
    Less restriction=better
    The faster the air is induced=better
    I also believed that GENERALLY, more performace=better gas mileage, providing that the same driving habits be retained.
    On my internet search for gas mileage and performance, it seems that gas mileage is proportional to hot air, and performance to cold air. The reasoning is that with warmer air, less fuel is mixed, saving gas. But wouldn't that just make the engine less efficient? Wouldn't that be counterproductive? If you had more performance (cold air), wouldn't you have to push down on the pedal less, thus saving gas?
    My plan:
    Box in my Downey CAI to keep it colder, wrap the chrome intake tube in fiberglass exhaust wrap, possibly route the box to the outside (ram air).
    Would this increase hp and mpg? Or should I just trade out for a stock box/deckplate?
    Chris4x4, I know you had a post about intakes and throttle body sizes related to a garbage can or something, but I can't find the post. Please enlighten me with your allknowingness.
  2. Nov 24, 2009 at 10:24 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    im not chris 4x4 but iv seen him post about throttle bodies saying they are about as usefull as a crap popsicle. On my personal experience, the deckplate mod is saweeeet. and the general idea iv gotten from others is its better than an aftermarket intake. again im not chris so i dont know nearly as much. .02 cents
  3. Nov 24, 2009 at 10:30 AM
    TBAGRR
    TBAGRR Well-Known Member
    Md
    07 4x4 sport
    Trd intake Doug Thorley long tubes URD short shifter Eibach front springs Tsb rear leafs
    cold air= more dense air=more fuel=more power!!!!!! yes this is right, however the engine usually doesnt have to work as hard on a cruise so the load is down so there is potential on fuel mileage increase. hot air will diminish performance so it can also add fuel mileage but every engine is diff. most stock airboxes are very restrictive so allowing it to breath is usually a win win situation
  4. Nov 24, 2009 at 12:53 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    http://fuelsaving.info/power_economy.htm
    The throttle doesn't regulate the amount of fuel flowing, it controls the airflow. You don't have to push it as far because the air is denser, so it doesn't have to allow as much air in for the same performance. The engine doesn't work more efficiently. The air-fuel mixture is set by the computer so it will be the same amount of fuel used for a given volume of air, it's just that the throttle doesn't have to be down as far to get the same volume of air. The system adds the correct amount of fuel for the air present. You can create more power because you have increased the engine's ability to get more air in there for a given throttle position but you'll burn more fuel as well.
  5. Nov 24, 2009 at 2:29 PM
    sachou
    Sam
    Alright, I gotcha. So pretty much generating more power doesn't do much for mpg, but freeing up restrictions helps both power and mpgs?
    Makes sense. You're not really an evil monkey after all!
  6. Nov 24, 2009 at 2:45 PM
    Evil Monkey
    Robert
    Escondido, CA
    I don't believe there is much in the way of restrictions. I think it's mostly marketing hype.
  7. Nov 25, 2009 at 9:22 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Colder air means more fuel and more power, but on the flip side, more power means you'll be using more gas... how are you going to get more power without using more gas? I think I read somewhere that warmer air gives you better MPG. You can't have more power and more MPG, they don't co-exist.
