Horn Relay Amperage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eurowner, Mar 16, 2017.
  1. Mar 16, 2017 at 4:03 PM
    eurowner
    eurowner [OP] Duke Sky
    Scoty
    I cannot find info for amperage of the horn relay. Thank you!IMG_20170308_114042596_HDR.jpg
  2. Mar 16, 2017 at 4:35 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    The relay probably has a higher amp rating than the wire and fuse. So if your looking to put an aftermarket horn, I'd use the wire gauge and/or fuse rating. But, there is no spec I can find on the amp rating from the horn relay part#. Go by the fuse as that's always the lowest / safest rating to use. Remember the fuse is there to protect the wire not the device at the end.
    eurowner[OP] and TRDinOhio like this.
  3. Mar 16, 2017 at 4:38 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Installing the Walmart mexican horns? "La Cucaracha, la Cucaracha!"
  4. Mar 16, 2017 at 4:51 PM
    eurowner
    Scoty
    First have to find interior dingleberries.
    smitty99[QUOTED] likes this.
  5. Mar 16, 2017 at 4:52 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    OP what are you trying to add to the horn circuit?
  6. Mar 16, 2017 at 4:54 PM
    eurowner
    Scoty
    I have a pair of Hella red horns just sitting on my bench. I have them in my '85 GMC K3500 plow truck, for 15+ years and people really notice.
  7. Mar 16, 2017 at 4:54 PM
    MESO
    State of Jefferson
    2 Hellas will be fine off stock circuit.
    Why not go QUADS?:devil:
  8. Mar 16, 2017 at 4:56 PM
    eurowner
    Scoty
    Cuz I only have a pair. But they ain't blue
  9. Mar 16, 2017 at 5:12 PM
    mutely
    Those look like the Hella Supertone (something or other), I believe they need a 15amp circuit. OEM is 10amp if I remember correctly. I'm sure you'll get away with running them (if you remove OEM horns from the circuit) as it's not like you run the horn for long durations of time. But be aware, the perfect install would be to use the OEM circuit to trigger your own relay, with 15A fuse & wiring.
  10. Mar 16, 2017 at 5:13 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    o_O
    :rofl:
  11. Mar 24, 2017 at 4:09 PM
    eurowner
    Scoty
    Bolted up and honking!
  12. Mar 24, 2017 at 4:15 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    Wire them up for use with your stock horns, or are the on a switch of their own ?
  13. Mar 24, 2017 at 7:44 PM
    eurowner
    Scoty
    I did not use a relay'd harness this time. I am not laying on the horn all the time.
  14. Mar 24, 2017 at 8:44 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    You'll find that you may eventually pop your horn fuse if you do lay on it. Those horns do draw roughly 12 amps if I remember right, and the stock circuit is fused at 10.
    It won't blow the first time you do it, just be aware that a good long honk will. Or potentially, "wear and tear" over a lifetime of beeping will pop it.
    Fuses can be fickle, especially so close to their rating. They are designed to withstand "transients" or sudden spikes in current. How much a 10A fuse puts up with intermittent 12A loads is really a crapshoot, in my experience.
    1bad2k likes this.
  15. Mar 24, 2017 at 10:30 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    This. My wife's Mazda only came with a high tone. The same Japanese domestic car came with high and low. The circuit is 15A. I added the low horn, and it still pops the fuse every couple of years and she doesnt use the horn much. A fuse is easy enough to replace though.
  16. Mar 25, 2017 at 8:14 PM
    eurowner
    Scoty
    Yep! I have relayed many setups for lights, etc for a long time, so if I need to upgrade it, easily done. My last 2 vehicles, the OEM wiring system had no problems with these horns.
  17. Mar 25, 2017 at 8:23 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    When I had them on my Subaru, I used an auxiliary circuit with the OEM wiring as the relay trigger. The relay setup would result in the horns being their actual full loudness. It also allowed me to connect everything up without cutting into the wiring.
    I eventually removed them as I found them to be too jarring for traffic. They definitely had their use when someone was aggressively merging into my lane and I wanted to let them know what I thought about that, but more than once when I was on the highway and a car drifted into my lane when I tapped the horn it jolted them enough that I was worried they may spin out. It made me too uncomfortable. If I had them on a toggle, that would have been more reasonable.
    But for what amounts to a few dollars in parts, throw them on an auxiliary circuit to truly let them rip.
  18. Jan 21, 2020 at 2:01 AM
    JoviTV
    JoviTV Active Member
    Northern NJ
    2016 Offroad Inferno
    Bought used Dec ‘19 with TRD pro grille, grabber ATx tires 285/75r16, small unknown lift kit. Installed TRD Grille accent lights, Anzo headlights. aluminum running boards.
    Sorry to revive an old thread but I am trying to do something similar: instead of horns that use higher amperage I plan to use a small 12v compressor that rated 16amps to send air through an air horn that I made.
    Correct me if I’m wrong but the horn’s relay is 20amps and the fuse is 10amps. Would changing the fuse to 20amps safely let me power the small compressor using the OEM wiring of the stock horn?
