Horn not working - air horn installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skootx, Dec 31, 2020.
  1. Dec 31, 2020 at 12:38 PM
    skootx
    skootx [OP] Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    I installed a Wolo 12v Air Horn in place of the stock horns, using the existing wiring and grounding the compressor to the chassis. It worked, but blew the 5A stock fuse. I ended up going up to a 20A fuse and everything was working great.
    Then I got my interior detailed and after that, the horn stopped working. I have no idea if those things are connected though. The fuse had blown, so I replaced it. It worked briefly, then stopped working. The fuse is fine.
    I'm thinking of replacing the relay as it's a cheap enough fix. But... can anyone tell me if I've wired it up incorrectly? I followed the instructions that came with the kit for the most part, but wanted to wire it up to work with the steering wheel rather than a new switch somewhere.
    Any ideas?
  2. Dec 31, 2020 at 12:52 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Without knowing what you did it’s pretty hard to determine. Your just going to have to go back through your work and test everything to find the problem. Sorry if that’s little help.
    eherlihy and TnShooter like this.
  3. Dec 31, 2020 at 1:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Can you tell us how you currently have it wired?
    I’d probably use the stock horn feed wire to power the new horn relay.
    When you say “going up to a 20A fuse” what fuse is this?
    The stock fuse in the truck? (I think it is a 10A)
    Or the fuse supplied with the new horn?
    Jimmyh likes this.
  4. Dec 31, 2020 at 2:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would use (as stated above) the stock wiring to power a Relay that then uses its own fused wiring from the battery to operate the horn compressor etc.
    Battery >> Stock 10 Amp Horn Fuse >> Horn Relay >> Air Horn Relay Coil.
    Battery >> Fuse recommended by Air Horn Mfg >> Air Horn Relay Contacts >> Air Horn Compressor.
  5. Dec 31, 2020 at 10:48 PM
    Muddinfun
    Muddinfun Well-Known Member
    You should never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, never, replace an OEM fuse with a higher amp rated fuse.
    That horn came with a 30 amp relay. You should use it as Jimmy recommended.
  6. Dec 31, 2020 at 11:04 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    This^^^^^^!!!!! Or post pics after the truck burns down:bananadead::bananadead::bananadead:.
    eherlihy likes this.
  7. Dec 31, 2020 at 11:07 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Not uncommon on some cars as the factory isn’t rated for the new horns amp draw.
    Confirm horn max amp draw and relay rating. It might be as simple as replacing a relay.
  8. Jan 1, 2021 at 4:45 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @skootx fuses have 2 jobs. First and most important is to protect the wires. Second, to protect the connected load. Fuses and wires are sized based on the load, in this case; your air horn.
    A relay is nothing more than an electrically operated switch. The relay is rated to carry a higher current than the horn switch in the steering wheel. it is much easier to bring a wire rated for 2 amps up to the steering wheel than it is for a wire rated 30 amps.
    Turning the relay on with the existing horn wiring is not an issue because the relay load is considerably less than the actual horn. Using the existing wiring to operate the new horn IS an issue because the existing wiring is not sized to carry that load along with everything else on that circuit. It could turn ugly...
    As for how it should be wired... The numbers 30 85 86 87 and 87A are are common nomenclature on standard Bosch relays. Number's 85 and 86 are the coil. Applying 12 volts across these two terminals will operate the switch by energizing the relay. Terminals 30, 87 and 87A are the actual switch contacts. Common, normally open and normally closed respectively.
    To visualize this switch take your left hand and make the letter V with your index and the middle finger. Your right index finger will bounce between the two legs of the V. Switch contacts are designated normally open or normally closed in their at rest position. Now going back to your fingers: your right index finger is terminal 30 now put it in the V and touch your index finger That is terminal 87A and they are connected when the relay is turned off. Energizing the relay pulls your right finger down to your left middle finger which is terminal 87 the normally open contact. Terminals 30 and 87 are the ones you'll use to apply power to the air horn compressor.
    For the actual wiring.... Take the existing horn wire and connect it to terminal 86. Ground terminal 85. Now the relay will turn on when you push the horn button on the steering wheel.
    Starting at the battery, use a wire as short as practical to feed a fuse. This wire is unprotected, so we want to keep it short and clear of anything that could damage the insulation and cause a short. The other side of the fuse will connect to either terminal 30 if you have a 4-pin relay or terminal 87 if you have a 5-pin relay. I generally do this so that terminal 87a is not energized when the relay is turned off. If you only have four terminals then it doesn't matter. The last terminal, to the compressor...
    If the air horn came with a 20 amp fuse use 12 awg wire. 30 amp requires 10 awg.
    Good luck.
    Jimmyh and THE_KiRRAx like this.
  9. Jan 1, 2021 at 4:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    Jimmyh and Larzzzz like this.
  10. Jan 1, 2021 at 5:54 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I find it odd that he says it blew the "Stock 5 Amp Fuse". All the schematics I have shows it as being a 10 amp fuse for the horn circuit.
    Sum Ting Wong... o_O
    davidstacoma and TnShooter like this.
  11. Jan 1, 2021 at 11:53 AM
    TnShooter
    Deogee
    STOCK
    Until we know how OP has it wired, all we can do is “guess”.
    I hope he didn’t substitute any fuses.
    davidstacoma and Larzzzz like this.
  12. Jan 1, 2021 at 12:04 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    He already said he changed some out for larger ones
  13. Jan 1, 2021 at 12:07 PM
    TnShooter
    Deogee
    STOCK
    Yeah, but he not did say what one.
    If you go to the link in his post, you’ll see these directions.
    I hope it was the fuse shown, and not some other fuse in the truck.
    Jimmyh likes this.
  14. Jan 1, 2021 at 1:19 PM
    Larzzzz
    Larry
    MA
    The way I read it was that he used the factory wiring to feed his new air horn compressor. And that he changed the fuse to a 20 amp to accommodate the existing wiring carrying all that extra current.
    :fingerscrossed: that's not the case.
    Oh, btw Happy New Year everyone..
    Jimmyh and TnShooter like this.
  15. Jan 1, 2021 at 3:11 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    That’s how I read it to. Sounds like he might be replacing some wiring. Hopefully it didn’t cook anything to important.
    Larzzzz[QUOTED] likes this.
  16. Jan 1, 2021 at 3:28 PM
    Larzzzz
    Larry
    MA
    Ayup
  17. Jan 1, 2021 at 7:12 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ you most likely damaged a wire by using a higher amp fuse,which is a no no.
    Larzzzz and Muddinfun[QUOTED] like this.
