Hooking up aftermarket lights to work with existing fog wiring
Discussion in 'Lighting' started by NativeTaco, Dec 23, 2012.
  1. Dec 23, 2012 at 10:34 AM
    NativeTaco
    NativeTaco [OP] Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    I have an 08 that had stock fogs. I replaced my bumper with an aftermarket tube bumper. The bumper has mounts for lights and I am hoping that I will be able to just get some kc lights and hook them up using the existing wiring. I figure I may have to change the plug on the lights to fit the oem fog connection. Does this seem reasonable, using the switch that is in the cab already? Well I have to change anything else. I know nothing about wiring. Can anybody help with this?
    I'm not sure what a relay is and what it does, or what the power output to the oem fogs was, so I don't know if this may be possible if I buy the fit lights or if I am doomed to have to run new wiring.
    I just want to use everything that is already there, but I don't know of that will be possible.
  2. Dec 23, 2012 at 11:37 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    OK, stop. No internet message board is going to supply you with what you need to know to do something like this successfully. You're going to need to educate yourself about "wiring" and general DC electronics. Whether it is through a book, a class or other literature, you need to get yourself some learnin!
    I don't have a primer to suggest, since DC junk has been in my blood since I was a kid. I learned by experimenting (on things other than $30k trucks!!).
    Or, how about this - do you know/live near someone that *does* know anything about electronics and electricity? Ask them to teach you and show you what you need to know.
    Not suggesting you're unable to learn or that you should give up, but you need to get your fundamentals down first. It'll serve you well in the long run.
  3. Dec 23, 2012 at 12:01 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    ^You obviously have't been aroun TW long enough with your 42 posts.^
    And since you're such a DC electronics expert you should have been able to tell him yes or no.
    OEM fogs are 42 watts, you can probably wire in 2 55W bulbs with no problem (if you blow a fuse you know you need to rewire with larger wire & relay but switch will still be good since it only carries a small load).
    A relay does the main power switching so the actual switch doesn't have to carry as big of a load.
  4. Dec 23, 2012 at 1:00 PM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Thank you for that. I am familiar with the fundamentals of electricity (I am a science teacher) but just not wiring in a vehicle. I figured that if I figure out what may work or not (to buy the right stuff), then find out what I need to do (what the job actually entails), so that I can focus my research for how to actually do it, or perhaps decide to hire someone else to do it.
    I realize there are morons around on the Internet who need some looking out for, but I guess I'm just saying I'm not one, despite how ignorant my OP Must have looked to you. I started here looking for info on how to do a job on this specific vehicle, then get more general info somewhere else.
  5. Dec 23, 2012 at 1:05 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  6. Dec 23, 2012 at 1:12 PM
    4Wheelin4Banger
    Randy
  7. Dec 23, 2012 at 1:25 PM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    With only a change of connector? Or will other stuff need to be done?
  8. Dec 23, 2012 at 1:29 PM
    4Wheelin4Banger
    Randy
    Just swap the connector or splice the wires.
  9. Dec 23, 2012 at 1:51 PM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Cool, thanks! I'm looking at the rigid dually's. I think those will be ok too.
  10. Dec 23, 2012 at 2:29 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    Just as a heads up, because it hasn't been said, the ADV and Rigid lights are NOT for on road use. If you do hook them up to the stock fog wiring, do not use them on the road, it is not legal.
    On that note, google the "how does a Bosch relay work". Most relays work off of a very basic principle, and a 4-pin Bosch relay (pins labeled 30, 85, 86, 87) is very simple, and is easily self-teachable, expecially considering your career. The 5-pin Bosch type relay is a little bit different, with a 30, 85, 86, 87, and 87a. I tried searching all over this website when trying to re-familiarize myself with relays, but there's really not enough information here to make sense, as alot if it is tacoma specific. If you read the "e-how", or "how stuff works" on the Bosch relay, and understand the basic concept, you'll be able to apply it to all kinds of different things.
    Because you're a teacher, I assume you understand different learning types, I for one, need to do something in order to learn it. I can't just read about it and then apply the theory, I've gotta be hands-on. So before you start digging into and trying to tap into your truck's OEM harness, you might want to just get your hands into the theory; go to radio shack, get a spst switch, spdt switch, a Bosch relay, a handful of small test leads (alligator clip type), a few 9v batteries, and a test light of some kind. This is exactly what I did, and it's easier for me to suggest that, than to try and explain the theory to you.
  11. Dec 23, 2012 at 2:45 PM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Good idea, I might even have some of that stuff in my prep room at school! That's too bad about the rigid lights, I wonder if they have a dot legal version? Would it be that noticeable when driving that I was using illegal lighting? Are they just that bright?
  12. Dec 23, 2012 at 4:08 PM
    Ryan DCFS
    East Bay Area
    Dot legal: To my knowledge, there are no DOT legal Rigid or ADV lights, and I'm pretty up to date on these lights. Check the manufacturer websites and your local laws.
    Would it be noticeable: Absolutely. It would be very easy to impede the vision of oncoming drivers.
    These lights are incredibly bright..
  13. Dec 24, 2012 at 6:46 AM
    obscurotron
    N. Nevada
    '14 DCSB 4x4
    Funny, my bulbs are labeled 35W on a '12. I may be new to TW (it has better 2nd Gen forums than other boards).
    It's the "teach a man to fish" vs "give him a fish" theory. He'd do better to learn some basics, first.
  14. Dec 24, 2012 at 8:14 AM
    4Wheelin4Banger
    Randy
  15. Dec 24, 2012 at 8:19 AM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    I understand, but being a teacher I think that learning from talking to people and asking questions is just as effective for learning than learning from a book. I don't see why I can't ask questions, hoping that someone with experience may give me some pointers, instead of just going to a book on electronics and tearing into my truck. Basically, you have to learn from somewhere, why does it have to be a book rather than a person?
    And I don't want this thread to be a shitstorm, cuz then anyone with useful info for me will probably just skip over this.
    Thanks to those who helped, sorry to bother the rest of you that felt I went about learning the wrong way.
    /failedthread
  16. Dec 24, 2012 at 8:21 AM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Oh and btw I have a friend who is a machinist, I will probably have him machine a housing for my oem fogs that I can bolt to my bumper and not really change anything but where the lights are mounted. Custom, unique, cheap easy. Only bad thing is that I still haven't learned much about this topic. Guess I will just go get a book...
  17. Dec 24, 2012 at 8:31 AM
    acdronin
    acdronin Well-Known Member
    Good morning teach, OK, if the stock fogs are 42w X 2 that's 84W divided by 12 (volts of your system), = 7 amps total.
    If you replace them with 55w X2 KC's comes out to 110W divided by 12 (volts) = 9.166667 amps total. I'm guessing that the fuse in the fuseblock for the fogs is probably rated at 10 amps. If you look at the inside cover of your fuse block it should have the diagram saying which fuse is which. If it is indeed a 10 amp fuse you should be fine. Never put a larger fuse in without replacing the existing wire with heavier GA wire.
    You should be fine teach.
  18. Dec 24, 2012 at 9:43 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    ILuvtheMountains,
    In your search for lamps, search for lamp housings that use 9145 bulbs. That is the bulb number used in the stock Toyota lamps. This would solve your search without changing anything and meet your electrical needs. I am not certain how difficult your search will be.
  19. Dec 27, 2012 at 12:05 AM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Thank you sir. Between your concise explanation and a few readings online and I feel better about what to look for and how to make sure it will work.
  20. Dec 27, 2012 at 12:31 AM
    acdronin
    Your welcome, let us know how it works out:)
