Hood Won't Pop Open - Fixed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tah-koh-mah, Feb 10, 2020.
  1. Feb 10, 2020 at 4:00 PM
    Tah-koh-mah
    Tah-koh-mah [OP] Well-Known Member
    2012 Tacoma TRD-Off Road
    Thanks to @llamasmurf for helping me fix this problem that's been bugging me since I bought the truck. The problem was that when I go to pop my hood the hood would not "pop" up to allow you to reach under and unlatch it up front. I would have to either jam my fingers under the hood or pry it open with the plastic part of my key. Annoying to say the least. Now here's the fix....
    Unscrew these two rubber knobs/standoffs. That's it. I unscrewed them 2 complete turns and boom, problem fixed. I couldn't believe it was that simple!
    Here is the before pic....this is after I have already pulled the latch inside the truck to pop the hood. This is how bad it was....
    This is after I adjusted the rubber stops.....
    I know this is a such a small thing that won't matter to some of you, but this was a life saver for me (or finger saver). I hope this helps someone out who's been struggling with the same issue! Again thanks to llamasmurf for helping me.
  2. Feb 10, 2020 at 4:28 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    Thanx for the tip. Up till now I thought they were just side to side levelers.
  3. Feb 10, 2020 at 5:40 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I had a friend help me when I was doing mine, and got it a little less out of alignment. So I dont have as much of a gap. It is very easy to do once you realize what does it. Try turning them in 1/4 turn at a time until it 'just' engages the latch mechanism.
    :hattip:
    Glad I could help, @3JOH22A was the one that told me what to do. I just put it in my build thread where you found it. :thumbsup:
  4. Feb 10, 2020 at 6:00 PM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    There’s also a little lever thing behind the grille, sort of next to the Toyota logo, with which you can use to push the hood up a bit more to allow more room to get your fingers under after releasing the latch.
    I use this all the time it’s muscle memory by now, but I’m definitely going to give those knobs a twist next time I’m in there to make my life easier.
  5. Feb 10, 2020 at 6:15 PM
    Mistermegabyte
    Mistermegabyte Active Member
    Pacific NW
    2014 Tacoma Access Cab 2WD 5-Speed MT
    All Stock
    Just bought a 2014 Tacoma that does the exact same thing, so I'm going to def try this. Thanks!!
  6. Feb 10, 2020 at 9:55 PM
    Mistermegabyte
    Pacific NW
    All Stock
    Just got home from work and tried your fix and it's good to go now! Only took half a turn. Thanks again.
  7. Feb 11, 2020 at 4:43 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Mine has stuck in the past. Some white lithium grease on the mechanism, some silicon lube in the cable, and I haven't had an issue in a long time.
  8. Feb 11, 2020 at 5:03 AM
    llamasmurf
    Wes
    Northern Ontario
    Mine was not stuck, it was well lubed. It takes upward pressure once it latches to engage the latch correctly for release.
  9. Feb 11, 2020 at 5:23 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Good post @Tah-koh-mah :thumbsup:.
    Consider adding “Fixed” or something similar to your thread title - helps when others are searching for the problem in the future.
    @llamasmurf is an encyclopedia :rofl:
  10. Feb 11, 2020 at 5:42 AM
    Tah-koh-mah
    Good idea.
    llamasmurf likes this.
  11. Feb 11, 2020 at 5:46 AM
    Tah-koh-mah
    Glad it worked out for you. And thanks for coming back to tell us it worked for you too.
    oldtimertoyota and llamasmurf like this.
  12. Feb 11, 2020 at 5:48 AM
    PzTank
    Above the Notches
    Thanks!
  13. Feb 11, 2020 at 7:13 AM
    Larzzzz
    Larry
    MA
    The latch is spring loaded to unlock when the cable is pulled. Something is sticking somewhere.
  14. Feb 11, 2020 at 7:26 AM
    Mistermegabyte
    Pacific NW
    All Stock
    I think you are missing OP's point. The latch DOES release when you pull on the under the dash handle. You can hear and feel it. The problem is that the hood doesn't pop up enough or at all to get your fingers in there too move the lever to actually open it up. Mine did the exact same thing.
    Muldoon and llamasmurf like this.
  15. Feb 11, 2020 at 7:27 AM
    Tah-koh-mah
    I think what @llamasmurf is trying to say is that the latch does not pop open the hood. The latch has a spring that moves laterally to unhook itself from the hood. The rubber stops I unscrewed are actually what "pops" the hood up once the latch unhooks itself.
    Dang, @Mistermegabyte typed faster than I did. But yea.
  16. Feb 11, 2020 at 7:30 AM
    llamasmurf
    Wes
    Northern Ontario
    Exactly
    :amen:
  17. Feb 11, 2020 at 11:35 AM
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    Just did this over lunch hour. I really like this one! Thanks.
  18. Feb 11, 2020 at 11:41 AM
    Tah-koh-mah
    No problem. Just paying it forward from great people on this forum. Figured I wasn't the only one with this problem.
  19. Feb 11, 2020 at 11:46 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Thanks for the tip. My 2014 does this sometimes as well when I haven't opened the hood for an extended period of time.
    llamasmurf and Tah-koh-mah[OP] like this.
  20. Feb 24, 2024 at 4:06 PM
    Txyz
    Txyz New Member
    Son of gun. Fixed that simple! I have lived with this irritating little issue couple of years now.
    oldtimertoyota likes this.
