Hood won't lock completely
Discussion in '1st Gen. Tacomas (1995-2004)' started by tomd, May 18, 2013.
  1. May 18, 2013 at 5:24 AM
    tomd
    tomd [OP] Member
    Boston
    I have a 2003 two wheel drive. When I close the hood the first latch catches but the second latch won't. Hope someone can help me out. Thanks!
  2. May 18, 2013 at 5:47 AM
    DarkShark
    DarkShark Well-Known Member
    Clark
    Medford/Southern Oregon
    03 DCab 4wd
    Icons, Camburg and custom stuff......
    Wd40 the latch really good. You problem should be solved
  3. May 18, 2013 at 9:53 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Is there anything in the way that it is hitting around the engine bay?
  4. May 18, 2013 at 10:02 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    I bought my 01 over in New Hampshire. The salt on the roads created a lot of build up in the hood latch cable causing the spring not to return the latch completely. If lubricating the latch doesn't work, try disconnecting the cable from the latch and inspect the inner wire for corrosion. It may just take a little scotchbrite and some lube.
  5. May 18, 2013 at 10:25 AM
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    Probably caked with crud and old grease. Take it off and clean it (the one thing WD-40 is good for) and re-lubricate it with good grease. If the spring is broken, you need to replace it.
  6. May 18, 2013 at 11:28 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    Making sure you left no tools or junk in the way... (interference)
    Or that the latch itself is not rusty or corroded
    I would check the height of the bump stops
    mounted to the top of the radiator support/fender rail.
    If those are out of adjustment and set too tall...
    that would keep the hood from closing all the way.
  7. May 18, 2013 at 11:41 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Is the hood popper under the dash staying up? thats what happened to me, spray the cable with wd, then take a screw driver and pry the latch back to the open position, have a friend pull the tab under the dash back and forth while you keep oiling the latch and prying it into position, should fix it.
  8. May 18, 2013 at 11:54 AM
    tomd
    tomd [OP] Member
    Boston
    Apparently the spring wasn't returning all the way. I gave the end of it a push with a screwdriver, heard a little pop, and now all is well.
    I'll try cleaning the area and spraying with wd-40.
    Thanks to all!
    Black DOG Lila likes this.
  9. Sep 12, 2017 at 8:27 PM
    Saltysister
    Saltysister New Member
    Saltysister
    1999 Tacoma TRD
    My hood popper is staying up and primary engine hood lock is not engaging. In the daylight I will try a screwdriver and some WD-40.
    Question: should I WD-40 Hood popper under the dash?
    Thank you for the posts. Between these post and YouTube, I'm surprised what I can accomplish:oops:
  10. Sep 12, 2017 at 8:30 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    You could it wouldn't hurt, but I don't see the point.
    Also welcome to TW.
  11. Mar 11, 2019 at 7:18 PM
    calitaco329
    calitaco329 New Member
    2002 Toyota Tacoma TRD
    I had the same issue with my 2002 tacoma. Ultimately, like everyone has said you need to lubricate and clean out the junk binding up the mechanism, but until then you can press the latch right where the black point touches the metal in the photo That right side is stuck in the up position because the spring can't pull it back down. Just press down (towards the ground) where I indicated until you hear an audible click, like at least one previous poster has said. Then your hood latch inside should stop looking like this and the latch under the hood should look like so Hope that helps a bit more!
    bjarturthetaco and 99taco80 like this.
  12. Mar 5, 2020 at 4:22 AM
    DinosaurDoug_MA
    DinosaurDoug_MA Member
    2006 Tacoma....first toyota:1973HiLux
    above> Apparently the spring wasn't returning all the way. I gave the end of it a push with a screwdriver....
    Pics above are great...but gen1 only i think. Here are 2 pics from my gen2/2006 Tacoma, I was having same problem,
    and I thank you for reminding me it is NOT an adjustable setup ( can't just raise the latch and hope it engages when hood slammed down ).
    My problem (typical) is/was just friction/dirt/corrosion generally VERSUS a poor spring design.
    THERE ARE THREE SPRINGS:
    1) "exterior" spring that returns the emergency/2nd latch. No problem.
    2) "interior" heavy (and most buried) spring that, i think, pops the primary "hook" up for release when you pull release lever. No problem.
    3) "interior" wimpy spring that returns the cable lever (OUR PROBLEM) which...when stuck....tells primary hook to not engage+lock.
    SO...the wimpy spring should have been designed with more pull.
    Mine (at its loosest position) sits (originally) NOT VERY TIGHT.
    Replacing it (finding better spring, or shortening it) seems hard (where to find various springs?).....
    SO I HAD ANOTHER IDEA.
    STRETCH the spring, without re-doing (or even un-doing ) the spring attachment ends.
    By raising it, much like your thumb or finger could do; there's at least a half inch of air/space above, room enough for this hack.
    I carved up a wood piece (around 1/2" thick+deep, around 1" long/wide but shorter..3/4" long would probably sit better),
    chiseled a GROOVE on the top side so the spring would sit and stay in the groove and not flip the wood and lose it;
    after a few tweaks/cuts, INSERTED THIS WOOD PIECE ; amazingly it stayed so far ( metal latch frame isn't quite rectangular,
    I probably should have taken some wood off the lower back edge where it meets a semi-rounded lower latch floor+wall).
    But this, until it falls out maybe, gave MORE TENSION/PULL to the spring. Of course, I cleaned, WD40'd,
    worked it and put never-seize around, including the exposed cable end.
    I noticed there are aftermarket latches, autofitparts dot com (in TX, new to me) has a "hood latch 05-11 Tacoma" for around $25,
    which looks like a "new/aftermarket design" and might have improved this problem. Tempted by nice/low price!
    Also researched OEM parts, and ran into "this looks wrong" looking at the OEM part# 53510-04030 that autofitparts dot com
    says this aftermarket part is for. Anyways, Toyota latches ... gen2 ... might all have wimpy spring2 setups; and cost 60-70 bucks.
  13. Mar 5, 2020 at 4:26 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    OP posted this 7 years ago, probably got it fixed by now :thumbsup:
  14. Mar 5, 2020 at 7:44 PM
    Kwe1982
    Kwe1982 Well-Known Member
    Wisconsin
    Gone - Just a couple Tundras and a Sequoia
    Ha, just was going to do a search on this. Got the same issue.
    it’s like the forum knows my issues, first an injector replacement now some hood latch trouble shooting.:)
