hood pins
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rhys, Aug 16, 2010.
  1. Aug 16, 2010 at 12:05 PM
    rhys
    rhys [OP] Well-Known Member
    Big Island
    6-spd 4x4 sb or
    afe intake, flexalite fan, cab a/c outlet, de-chrome in progress, bedlined sides, custom head and tail lights, arb front
    any body got em. how did you do the install?
    im thinking about putting these in to replace the manual lever under the hood.
  2. Aug 16, 2010 at 1:25 PM
    rhys
    Big Island
    6-spd 4x4 sb or
    nobody?
  3. Aug 16, 2010 at 1:27 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I'd think that if you run them without getting a fiberglass or carbon fiber hood, it might be kinda ricer status :notsure:
  4. Aug 16, 2010 at 2:30 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    before I got rid of my C/F Hood I had a set of Aerocatch Carbon Plus Flush Locking Hood Pins...
    I liked this hood pin a lot better since I sat flush on the hood and also had a way to keep it locked so that no one stole the hood and/or any parts in the engine bay...
    yeah its a lot more pricey...but the way they work gave me satisfaction knowing that no one ain't getting in the engine bay unless they were ready to start cutting...
  5. Aug 16, 2010 at 3:12 PM
    rhys
    Big Island
    6-spd 4x4 sb or
    yeah i would still keep the factory latch, just remove the lever that you reach in and lift. i just think it would be alot easier when you have an arb front bumper, a grill you cant stick your hand through, and a lift.
  6. Aug 16, 2010 at 3:40 PM
    White09TRD
    White09TRD Active Member
    RVA
    09 White 4x4 DC TRD Off Road
    Bone stock with K&N air filter
    Looks like they install with rivets and lots of drilling into your hood. Not a fan of these...
  7. Aug 16, 2010 at 3:42 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    If I did it, I would get these. I know you want to have something to replace the latch but is there any other reason? Just can't figure out why you'd want em is all
  8. Aug 16, 2010 at 3:48 PM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    FWIW, not a fan of this set up, factory set up superior imo. UNLESS you have the different grill, bumper, lift etc as per prior post, that makes the factory set up impractical.
  9. Aug 16, 2010 at 4:25 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I fail to see why you'd get these with a stock hood. My 280Z has hood pins (just some old skool Kragen ones with push pins and no locks) on the stock hood... but that is only because the mounting latch was cut out to fit the small block chevy v8, I'm going to put a real latch back in.
    As for security... they would have to break into the cabin to release it anyway or be an olympic gymnest or something to get under it.
    As for an ARB/CBI/AllPro bumper ect and say a grillcraft or satoshi... it's all irrelevant as the latch is accessible ABOVE the grill after you pull the hood release.
    If you want it for looks and to ruin resale potential... go for it. If you want it for a purpose... only get it for a carbon fiber or fiberglass aftermarket (or if you race it and the class requires it).
  10. Oct 11, 2011 at 12:13 AM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    I put some in simply because I had a hood flutter issue at higher speeds
  11. Oct 11, 2011 at 8:24 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    did you think to adjust the hood latch?. i dont see how it would be hard to open the hood with a bumper and lights , unless your a midget.
