Hood latch not working!!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by davidjmay, Aug 23, 2013.
  1. Aug 23, 2013 at 4:06 PM
    davidjmay
    davidjmay [OP] Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    I don't like posting "HELP" threads, but I'm desperate here. My hood latch has been acting funny lately, but today it completely gave up. It won't open when I pull the latch inside the cab!! :mad: I can't even open the hood at all. This is such a PITA and I have no clue how to fix it or even what's wrong. Has anyone else ever had this problem? :confused:
  2. Aug 23, 2013 at 4:27 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Is there resistance when you pull the release?
    the action is either gummed up, or the cable broke.
    If the action is gummed try spraying the action with some type of fluid (like PBlaster), and then push down on the hood while someone pulls the release.
    if the cables broke i don't know what to tell you.
  3. Aug 23, 2013 at 4:51 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    I tried spraying wd40 on it and a combination of pulling the latch/pushing and pulling on the hood. No luck :(
  4. Aug 23, 2013 at 4:56 PM
    just2wd
    just2wd Well-Known Member
    Dan
    California
    07 PreRunner TRD Off Road
    i had this problem but it was the little rubber things that you can twist under the hood that wasn't making my hood pop up, maybe try that, twist them til theres about 1 more thread showing
  5. Aug 23, 2013 at 5:24 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Thanks... I'm pretty sure mine is the latch though. It doesn't resist when I pull on the lever. Still trying to figure out how to get the hood off :eek:
  6. Aug 23, 2013 at 5:50 PM
    95 taco
    95 taco Battle Born
    If you can't pull the hood up then it's a broken cable, I can figure out how to get the cable pulled I you want.
  7. Aug 23, 2013 at 6:05 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    For some reason I don't think the cable is broken. I can feel it pulling the cable and I can hear the mechanism moving near the grill
    I could be wrong though
  8. Aug 23, 2013 at 6:48 PM
    95 taco
    95 taco Battle Born
    Hmm, have you tried pulling/ prying on the good while someone pulls the release?
  9. Aug 23, 2013 at 6:53 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    Do this, it usually works for me
  10. Aug 23, 2013 at 7:04 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Interested in the outcome of this, and wishing for the best, because I think mine is on the way out. It doesn't like to open sometimes. Sometimes when I pull the release it will act like I didn't pull it, and sometimes when I pull it, it feels so lacking in resistance that I'm not sure it's released the hood until I get out and lift on it.
    Best of luck, OP!
  11. Aug 23, 2013 at 7:46 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Check the spring under the hood that attached to the latch, mine came unhooked and it did the same thing
  12. Aug 24, 2013 at 12:20 AM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    I tried pulling on it, but i'll see if I can get something in there to pry it with tomorrow. Thanks!
    Thats how mine was acting the past couple times I opened it. I would check it every time you open it and lube it with some oil or grease to make sure that the same thing doesnt happen to you
    I would check that... If i could get my hood open. The last time my latch quit working, that was the problem. The only difference is this time, my hood is closed and won't open... Last time it was open and wouldn't close. Much easier fix as you can actually access the spring
  13. Aug 24, 2013 at 6:19 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Oddly but I have never had a hood latch not open on ANY vehicle I've ever owned so this is completely new to me.
    Sub'b for the results.
  14. Aug 24, 2013 at 11:19 AM
    95 taco
    95 taco Battle Born
    If the prying doesn't work smack the hood (lightly with your palms) while someone pulls the release, this should cause the latch to disengage, as there is no pressure on it.
  15. Aug 24, 2013 at 8:53 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Got it fixed!!
    Did some searching and found a couple threads on TTORA about it. One suggestion was to drive over some rough bumps while pulling the lever in... Pulled in the lever, found a speed bump and hit it at around 35 mph and boom! It popped up, drove it home and put some WD-40 on it, shut it and opened it with no problems. Some guys were saying that when it gets dirty, the mechanism gets stuck. I think this was the problem, as I went up Silverado the other day and got her pretty dirty.
    95taco, I'm sure your suggestion would have worked if I'd have hit it harder. This is the same theory, just a lot more force.
    A BIG thanks everyone for the inputs! Hopefully someone will run across this thread sometime and find a solution. Keep in mind that I could still feel that the lever was still attached to the cable... If the cable is broken anywhere (which is a much bigger problem) you'd have to find a different solution
  16. Aug 24, 2013 at 9:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Those are to adjust the position of the hood so it sits level with the fenders and grille when closed.
    The spring that makes the hood pop up is in the center latch mechanism.
    Tools likes this.
  17. Aug 24, 2013 at 9:25 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    When I pull the release, the hood latch releases, but doesn't spring the hood up the inch or two it is supposed to...? Been like this for a long time. hmmmm
  18. Aug 24, 2013 at 9:35 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Yes, but I have heard of people having to adjust them upwards to create the tension needed for the latch to work. Wasn't an issue for me
    Can you lift the hood after you pull the hood latch? Even if the hood doesn't "spring up", if you can freely lift the hood an inch or two in order to get to the secondary latch, the hood release switch has done its job.
    Jlarios956 likes this.
  19. Aug 24, 2013 at 10:33 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    It's doing it again. At least now I know how to fix it (hopefully) but next order of business is to get a whole new latch assembly. I'll call dealership tomorrow and find out how much one costs. Does anyone know where else I can buy one?
    Besides a pick your part junkyard
  20. Aug 25, 2013 at 7:27 AM
    Madjik_Man
    Colorado Front Range
