Hood height adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3GTCMLMTD, May 16, 2023.
  1. May 16, 2023 at 6:00 PM
    3GTCMLMTD
    3GTCMLMTD [OP] Well-Known Member
    2022 Limited
    The front of my hood is sitting too low. The two bump stops at the front are as high as they can go, but it’s still not right. Any ideas? Maybe something I don’t know or haven’t thought of?
  2. May 16, 2023 at 6:06 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Can you post a pic of the problem?
    3GTCMLMTD[OP] likes this.
  3. May 16, 2023 at 6:17 PM
    3GTCMLMTD
    2022 Limited
    Look at the difference here by the fender. Seems ok with matching up to the grill, but near the fender is where it’s lowest point is. Wanting to put a deflector on it, but I can’t because of this. I’m just glad I didn’t slam the hood when I test fitted it. The deflector ended up hitting the lights.
  4. May 16, 2023 at 6:33 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Mine is the complete opposite, ha. I just pulled my hood struts and ditch lights trying to re-align it. Got no where. The manual says to replace the hinge bolts with standard ones before aligning though.
  5. May 16, 2023 at 7:01 PM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    Yep. That is the reason I could not install a stone deflector. The deflector hit the grill surround. I returned it. I went to Lowes and bought the rubber "caps" that are placed on the legs of chairs to stop the chair legs from scratching the floor. I put them over to hood stops and was able to raise the stops further. This will line up the hood with the fenders. The only issue is that it is a little harder to pull the hood release. I have not installed another deflector with this set up yet.
    can lower ths stops and have more room for adjustment
    What I ment to say, with the caps on, you
  6. May 16, 2023 at 7:03 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Mine is the same way and I can't adjust either. I have seen others just like this and figured Tacomas are not as good of a fit and finish from the factory.
  7. May 16, 2023 at 7:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Does the hood and fender line up in this area? This is technically the correct place to look when adjusting the bumps stops
  8. May 16, 2023 at 7:17 PM
    Originally, my hood did sit lower than the fenders. After installing the caps, everything lined up.
  9. May 16, 2023 at 10:02 PM
    3GTCMLMTD
    2022 Limited
    Damn, that's definitely not good either.
    I just might give that a try and see how it works for me. I never would have thought of that. Thanks.
    It sure seems like that is the case. Hopefully, we can all get these issues sorted out and fixed one way or another.
    I'll check that as soon as I get a chance. It will be interesting to see how those line up. Thanks.
    HondaGM likes this.
  10. May 16, 2023 at 11:43 PM
    3GTCMLMTD
    2022 Limited
    Dammit. Nope, the hood sits lower.
    HondaGM likes this.
  11. May 17, 2023 at 12:02 PM
    shaggy135
    Had Toyota look at my hood today since I was in for an oil change. The collision center started to tell me that my core support was damaged and showed me some breaks under the fenders. If I chose to go down that path, it would be upwards of $3k and not under warranty. Then he started talking about how my truck is "heavily modified" and asked if I had hit anything. I left shortly after. When I got home, I started looking back in my pics. My hood has been like this for almost 2 years, ha.
    TRDRed and 3GTCMLMTD[OP] like this.
  12. May 17, 2023 at 12:07 PM
    3GTCMLMTD
    2022 Limited
    That’s not a very good experience. Sounds like they didn’t want to mess with it and gave you a high price, I’m guessing. I’m thinking I will also bring mine in and see what they say.
  13. May 17, 2023 at 12:10 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Did you upgrade the radiator support bushings at any point? That can affect hood alignment if the new bushings are too tall.
    3GTCMLMTD[QUOTED][OP] likes this.
  14. May 17, 2023 at 12:12 PM
    3GTCMLMTD
    2022 Limited
    No, I’ve never done that. I did change the grill, but from looking at old pictures I have with the stock grill it was the same way.
  15. May 17, 2023 at 12:38 PM
    shaggy135
  16. May 17, 2023 at 12:44 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    My hood also sits a little lower than the fenders with the bump stops screwed up all the way.
    So if anyone comes up with a solution I'd love to see it.
  17. May 17, 2023 at 1:12 PM
    099
    see post 5
  18. May 17, 2023 at 2:09 PM
    3GTCMLMTD
    2022 Limited
    There are more people than I expected responding that have the same issue. Hopefully everyone gets it sorted out and back to how it should be.
  19. May 17, 2023 at 4:15 PM
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    My hood to fender fit isn't great either, was low in front and back. Took it to a shop and the guy was able to get the front with the bumper adjustment; but the rear, he didn't have nice things to say about factory fit and finish (let alone replacement parts), but said an upside to the sheet metal being paper thin is being able to just tweak things..he put his palm on the top of the fender and just leaned on it a couple times and probably fixed 80-90% of the problem. The back of the hood misalignment isn't noticeable from the outside really anymore, but still drives me bananas though since I get to stare at it any time I in it. Maybe I should have gotten black, it would certainly hide these issues much better..
  20. May 17, 2023 at 5:48 PM
    3GTCMLMTD
    2022 Limited
    Damn, just by pushing on it? That doesn’t sound good in regards to how sturdy these trucks are. I’m just like you now. Every time I go up to the truck that’s the first thing I look at.
