Homemade Traction Boards
Discussion in 'Off-Roading & Trails' started by beyer075, Jan 10, 2015.
  1. Jan 10, 2015 at 1:28 PM
    beyer075
    beyer075 [OP] Rock Licker
    Northern Nevada
    2016 White TRDOR
    Got the idea from my buddy.
    2x12 treated wood cut into four three foot sections - $36 at Home depot
    100 2'' long 3/8'' bolts (tire side), 40 2.5'' 3/8'' bolts (ground side), 140 nuts/washers - $45 at local ranching store (2.99 per pound)
    Total of $81
    These are not intended to be used to drive over gaps but just incase of getting stuck is sand, snow, ect.
    Nothing fancy but nice to have in the back.
    supralee likes this.
  2. Jan 10, 2015 at 1:37 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Cool idea, I might take two of them and attach them with some rubber.
    Don't forget to treat your end cuts!
  3. Jan 12, 2015 at 8:17 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Don't you think the wood would break in certain instances. Where plastic would not?
  4. Jan 12, 2015 at 8:22 PM
    302 I love Taylor Swift :D
    Lawrence
    302
    07' DCSB TRD Sport SSM
    Bedside decal
    In delaware you must carry a board with you to drive on the beach.
  5. Jan 13, 2015 at 5:23 AM
    beyer075
    Northern Nevada
    2016 White TRDOR
    Treated wood is a stronger then you'd think but I'm sure they will break at some point, or if used to bridge a gap. But if put under the tire when in soft material I think they'd be able to withstand some weight. I haven't tested these but my buddy who made did this originally used them to cross some deep snow in the GMC 2500. So the in theory they work in certain conditions.
    Honestly, I carry a few types of recovery gear at all times in my truck and these are just another tool depending on the circumstances.
  6. Jan 15, 2015 at 4:24 PM
    PBR Streetgang
    PBR Streetgang Well-Known Member
    Andrew
    Medford, OR
    2013 AC 4x4 TRD
    Icon stage 4 kit, Deaver J66 leaf springs, Firestone ride-rite airbags, Warn 9.5 XPS winch
    Looks good. Maybe attach something like 1/2 - 3/4" tall strips of wood across the width in a few places to add some horizontal traction surface area? Looking at snow machine tracks and tank tracks there are a lot of horizontal strips for traction.
  7. Jan 15, 2015 at 4:27 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The ACQ treatment neither strengthens or weakens the lumber as far as it's resistance to snapping
  8. Jan 15, 2015 at 5:04 PM
    beyer075
    Northern Nevada
    2016 White TRDOR
    Thanks! My knowledge of lumber is lacking. :)
  9. Dec 12, 2017 at 1:37 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I know this is an old thread, but I was (gasp!) searching around because I was inspired by another (recent) thread about mounting your traction aids
    So anywho...
    Curious what other people have come up with for DIY traction aids.
    I've always used rocks, tree branches, or whatever else has been in situ, but recently started thinking about carrying something with me, I guess because I'm getting caught up in the hype of "needing" bright orange traction aids, but without actually wanting to spend the $300 on them.
  10. Dec 12, 2017 at 6:45 PM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    Firewood . You have a little already. Or stack rocks.
  11. Dec 12, 2017 at 10:43 PM
    jbrandt
    Justin
    Yeah, that’s mainly why I’ve resisted buying expensive plastic things that I have to carry with me all the time, rather than just find some rocks or branches. But, I’m always interested in another DIY project, that maybe end up being useful.
  12. Dec 13, 2017 at 9:06 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
  13. Dec 13, 2017 at 10:12 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You can buy plastic recovery boards for less than the cost of making.. this.
    Amazon is your friend.
    Speedytech7 and Wishbone Runner like this.
  14. Oct 9, 2019 at 2:59 PM
    Teamrivers
    Teamrivers Well-Known Member
    Brent
    Atlanta, GA
    2018 TRD Off Road 4x4 DBL 5.5
    Diamond Back HD, full interior light change, DiodeDynamics main lamps, Caliraised amber fogs & ditches, Caliraised 25 Degree sliders no plate, SSO slimline front bumper w/ 20" LED Smitty Gen3 winch, Barricade rear bumper with rear in bumper lights from SuperbriteLEDs, Budbuilt rock 2 plates with rerouted exhaust, Method 306, 295 Ridge Graps. OEM Kings tuned from Filthy, Deaver Exp 1, SPC UCAs, 5.29 diffs. Dash mounted 1/4 threaded accessory plate. And a TRD Pro grill...assuming I qualify for pro status.
    Most of the cheapie junk solid to compete with maxx are one time use if that. I'm making a set out of scrap 1" treated trimmed in scrap aluminum angle iron. I'll have a few bucks and an hour or so in it for something that won't get stolen like most, and will outlast the competition. I may try and find old milk crates and create a folding lattice like the $100 per piece fiberglass trax that are sold. can't bridge them, but a bag of sand and a board can be more useful than some of these things.
  15. Oct 9, 2019 at 3:04 PM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    What if you used some nails sticking up? The sharp end will help the tire dig in. LOL Great idea man, sometimes when a vehicle is stuck at the beach and they havent dug themselves in I use some of my mesquite pieces that I take for the bbq pit and jam them under their tires and they 9/10 get out in 1 try.
  16. Oct 9, 2019 at 3:46 PM
    Teamrivers
    Brent
    Atlanta, GA
    Actually, if you just run screws directly into the tread. You may be on to something, thanks for the nudge to improve!
    Wixo[QUOTED] likes this.
  17. Oct 10, 2019 at 4:21 PM
    Wixo
    Hank
    Tint, LED interior
    I would suggest stainless steel wall studs so they dont rust or come out.
  18. Oct 13, 2019 at 10:42 AM
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Look heavy... relatively speaking.
  19. Oct 18, 2019 at 10:12 AM
    TheTurk
    TheTurk Well-Known Member
    Kendrick
    California, Central
    2019 TRD OR
    Smart! I've been using tie downs strapped to the tire
  20. Mar 28, 2020 at 9:33 PM
    Mech_Eng
    Mech_Eng Well-Known Member
    Birmingham, AL
    2009 TRD 4x4 DCSB
    See Build Page
