Homemade tonneau
Discussion in 'Tonneau Covers, Caps and Shells' started by Randy Y, Jan 23, 2012.
  1. Jan 23, 2012 at 11:54 AM
    Randy Y
    Randy Y [OP] Active Member
    2010 4x4,4 cyl. 5 speed
    Thinking about building my on bed cover . Any ideas , suggestions , or pics ? Thx
  2. Jan 23, 2012 at 2:26 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    If you are doing it to raise MPGs don't make it very heavy or you will defeat what you are trying to do.
  3. Jan 23, 2012 at 3:34 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    I saw this at the mall a couple months ago, but the picture is crappy. I couldn't tell if it was homemade or purchased, but I've never seen anything quite the same before. Diamond plate, looked sturdy as hell. Looked almost too nice be made at home, but at least the pic may help give you some general ideas.
  4. Jan 23, 2012 at 3:35 PM
    Aw9d
    Aw9d That one guy
    My old boss had this on his Ford F150. It was neat because you can store stuff on top of it, like quads for example. But it was HEAVY! And it folded into 2 halves so you couldn't use it to move a bed or anything like that.
    He ended up taking it off after a year or so.
  5. Jan 23, 2012 at 5:46 PM
    Randy Y
    Yes mainly for mpg on longer trips, not to concerned about a water tight seal. Thinking about maybe using 1" ridged foam board with some kind of reinforcement for the edges and covering it with some kind of tonneau like material
  6. Jan 23, 2012 at 5:47 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
  7. Jan 23, 2012 at 6:06 PM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    my homemade plywood tonneau...
    sprayed it with 2 or 3 cans of bedliner to help keep water from soaking in.
    hinged so I can flip it up and take bed extender out if I need to without taking cover off. Was nice too being able to flip it up and put groceries or whatever between the extender and tailgate and not have to open tailgate
    believe it cost me about $60 to make. The bedliner spray was most of the cost.
    PistonHead81 likes this.
  8. Jan 27, 2012 at 4:29 PM
    focotacoma
    focotacoma Well-Known Member
    Fort Collins
    07 Speedway Blue 4x4 TRD off-road
    Im getting there......
  9. Jan 27, 2012 at 4:44 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Mythbusters did a special where they tested a truck with and without a tonneau, and it got better MPG without one. the tailgate does not actually create a lot of drag it turns out. But this was tested a long time ago on a pickup that wasnt a 2nd gen Taco, so take it with a grain of salt.
  10. Jan 27, 2012 at 5:48 PM
    cmoschip
    cmoschip Well-Known Member
    Robert
    Houston, Texas
    2008 TRD Sport DC 4x4
    That's a Diamond Back cover. http://www.diamondbackcovers.com/
  11. Jan 27, 2012 at 6:26 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Don't believe everything you see on Mythbusters. It really depends on the aerodynamics of the truck, cab length, bed length, etc. On older trucks I've had, it's been a mixed bag, sometimes they helped, sometimes they didn't. It did help the mileage a little bit on my double cab short bed. Nothing drastic, only a couple MPG but it did help.
  12. Jan 27, 2012 at 7:31 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Before you go ahead and build search CL and such for a used tonneau. $200 might go farther than you think, even if it needs to be painted you will end u with a better product.
    If you still prefer to build something my vote is for 3 black diamond plate sections. Make it a tri fold.
  13. Jan 27, 2012 at 7:36 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I thought it was with or without a tailgate :notsure:
    edit
    http://youtu.be/r3aqHbD-O9E
  14. Jan 28, 2012 at 2:05 PM
    penguins_cc
    Will
    Bellevue, WA
    You learn something every day. 1 1/2 years of TW addiction and I still hadn't heard about these covers. It's still a bit much for my personal use but that lightweight version is kinda tempting.
  15. Feb 10, 2012 at 5:40 PM
    spidy3
    Dom
    Upstate NY
    10 DC TRD Off Road
    so did you build???
  16. Feb 10, 2012 at 5:57 PM
    zul
    PNW
    One of the things they tested was with a cover, watch from 4:13.
  17. Nov 1, 2013 at 12:57 AM
    hktr
    hktr Member
    hktr
    CA.
    01 Tacoma DoubleCab SR5
    Front lift, Light Bar, etc...
    Hi Spidy3, great idea... any building plans or some guides to follow??
  18. Nov 1, 2013 at 1:00 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
  19. Nov 1, 2013 at 6:04 AM
    spieler
    spieler Well-Known Member
    Jonesborough, TN
    13 white DCSB SR5 4x4
    3" Lift kit/265 Duratracs/SCS Stealth 6 matte black wheels, OEM White grille switcheroo, TRD skid derped white, CSjumper drtl map dome parking lights fog light bulbs, Lifetime LED headlights, **Reverse light mod, Foglight anytime Mod, Trimmed mudflaps, Fully Debadged, 3rd brake light cover by well...me, Liquid Innovations black carbon dipped front emblem, G-Tek Fab diamond plate white door sill protectors, SOS Bolt-on Sliders bedlined, MattGecko rear window security bar, Hardwired Radar Detector w/custom sucker mount, Horse Stall Bed Mat, Audiocontrol LC2i with custom mount ACR-1 remote, Custom sub box behind drivers rear seat, Mag light holder behind seat, Center console organizer , Passenger seatbelt flapper fix, Tailgate anti-theft Mod, Bed storage Locks Mod, hygieneboy ghetto gutter grille guard
    Agree with above posts about different results from different trucks. My sport Trac that I traded for my taco got 3 mpg better with and Advanced Folding aluminum tonneau that only weighed about 30 lbs. The heavier they are it will defeat the gains. The OEM tonneaus for the Sport trac were about 75lbs so real heavy!.
    That was going to be my first Mod to SnowTaco to have a bed thats dry for a lot of stuff I do but my wife vetoed that because she said the truck was too sexy without it and it would make me look like an old man (im 39)....
