Homemade tonneau cover (pics and how-to)
Discussion in 'Tonneau Covers, Caps and Shells' started by DizzyZ, Jul 15, 2010.
  1. Jul 15, 2010 at 11:29 AM
    DizzyZ
    DizzyZ [OP] Well-Known Member
    Dennis
    Paragould, AR
    2017 Tacoma TRD Off Road
    Well, I am planning an off road adventure, and need to keep my gear dry. I really like how the bakflip G2 tonneau cover looks and works, but I don't want to spend the $700+ on it. So, I decided I could create my own that would work until I can afford it... Here it is... I used 1" ridged foam board reinforced with 1" aluminum channel. The whole project cost around $100 and took about 5 hours (not counting the 5 trips to the hardware store). I included a write-up in case anyone is interested in how I did it...
    Before and After:
    IMG_3376_14945a85f3ecab007ba52fdc0b4345755710ecef.jpgIMG_3439_54fcd14f5b5de7310844c2291f8257b9cc878a79.jpg
    Cut the pieces 57 1/8" x 30 3/4":
    This will allow them to rest inside the bed cap on the rails:
    Trace around the funky bed shape and cut with a razor blade:
    As you can see, it needs to be reinforced:
    Glue on 1" aluminum channel with foam board adhesive.
    Tape is to temporarily hold it while it dries:
    Test fit:
    It is now much sturdier:
    To make it hinge lay the pieces next to each other and
    use gorilla tape (or other strong tape) to make the hinge:
    IMG_3392_fe5efce0d1f268eba4563003688dc63e012b1df6.jpgIMG_3393_c3da4150bf0a31a4db9c99e5cc24c428bd677bfc.jpgIMG_3394_6643c983328fc4035fef1cf95a3a42537f4ca5b9.jpg
    Fold the cover over and tape the other side of the hinge:
    IMG_3395_85a1c50c327e9ec02fb2d5b60664f930f07e775b.jpgIMG_3396_4ebd72ce87abf32874a6b383c161f6a660d151e5.jpgIMG_3397_ceebdca67346e6bc22398049f7cb393cddc9fdad.jpg
    Test Fit then add hardware:
    IMG_3398_a7aff9722b44658b9ab3a82ab8e261df1a433924.jpgIMG_3399_472faaa1364cf5488e72ad6120af760f86feffe9.jpg
    I used 4 of these to latch it down to the rails:
    IMG_3404_c545bc8f8fec710cb107036a38905e76da043ddb.jpgIMG_3405_e6d120ae04523cfa0baf7acf56fba080f25b01fa.jpg
    And 2 of these to secure it at the front of the bed.
    On the left is the original and on the right is how I modified it:
    Set it in place to determine where to mount.
    I had to get 1 1/2" screws and fender washers to mount:
    IMG_3408_c32824f02676d6f1cf5bda6eaa13f2a87b766512.jpgIMG_3407_6a0ca1faeabba5ca2aae6da0c679d0b5d3b84c14.jpgIMG_3409_d1537e9e2acb8bb7a4cfff686a22e0e9962e7902.jpg
    IMG_3410_3acc1b6422217852e4d143dc223e25c451b510ac.jpgIMG_3413_8df83d613ec3eacdeda68b37719a3247b97afffd.jpg
    Try it out:
    IMG_3421_0c986083c2990df6ab96c7ffa08b0e7a239835c8.jpgIMG_3418_8a46af564423a244e4379379a7b8d8cb60c94e50.jpgIMG_3423_5e4eaaa71b6782e1755ff3ba8916b5dad07ea14b.jpg
    IMG_3425_f1bd69e0cc784a2a2daa63309d2e122bee9c8324.jpgIMG_3426_f1ef6880af35ded0b39e7b2141288b35dfd770df.jpgIMG_3428_0387ae5a2c2670d59cf628b64e402d248c18da2c.jpg
    Paint it black (use paint that will not melt the foam!):
    Add weather stripping and you're done!:
    IMG_3444_1da0ddf78e1a3466a84b552446f94997dc9c3b11.jpgIMG_3443_a14524d669a861b7c398b998ee8ff46dcff233a8.jpg
    IMG_3441_aaa614fe91d56508b90871399bf529d719cdbe29.jpgIMG_3440_f4b62a5c882a32ef21c82f9548c1a98a9d9ba8df.jpgIMG_3439_54fcd14f5b5de7310844c2291f8257b9cc878a79.jpg
    EDIT:
    Okay! It has been several weeks, and over 3000 miles since I've made this thing... It is time for a review...
    First off, this was meant to be a temporary cover used only for camping or other needs, not for everyday use, but, I must say that it would probably be fine with everyday use. Having said that, all this thing did is make me want to buy the bakflip cover even more... I will probably do that next spring when I get my tax return money.
    I will start by listing the good:
    1. While it is not 100% water tight, it did keep my gear dry in HEAVY rains. I put a 5x7 tarp down in my bed and placed my gear on top of that so any water that did get in would run down the sides of the bed and under the tarp.
    2. It looks good! I am actually shocked at how well it turned out!
    3. It is VERY easy to put on and take off... Only about 30 seconds to remove or install!
    4. There is a lot of satisfaction in knowing you made it yourself... (I'm sure there are more good things, but that is all I can think of for now)
    Now for the bad (not really that bad, just things I wish I would have done sooner or different):
    1. When I first made it, the heat made the tape start to come unglued... I went to Lowes and bought some special glue that is weatherproof and works on foam (see pictures following this review) I put a small bead of glue at the seams of the tape and it has held it down great since (over 2500 miles with the glue).
    2. After I got the glue on there I had to paint it... I wish I had gone with the Krylon H2O black paint for the 2nd coat also, (that paint worked and looked great on the foam). But, instead I let the salesman talk me into a different flat black paint... It was supposed to be good on the foam, but it ended up causing the foam to melt SLIGHTLY in some places... It really isn't bad, but just a regret that I have. NOTE: I RECOMEND USING KRYLON H2O SPRAY PAINT!!!
    3. The last foot of the foam was not supported since the bed rails don't extend all the way to the tailgate, and I noticed the back would move up and down when driving at high speeds. I used some leftover aluminum channel to make supports for it near the tailgate (see pictures).
    Final Thoughts...
    Overall I am very happy with it and would do it again. If I wanted it to be more permanent I would probably wrap all 4 sides in the aluminum channel, not just the long sides. Several people have recommended various covers for the foam, but I like the way the foam looks. I looked into covering it with vinyl and had a hard time finding pieces that were big enough to cover the whole thing with one piece... I found one site that has the marine grade vinyl large enough to do this....
    http://www.seattlefabrics.com/vinyl.html
    People have recommended using different materials also, such as wood or plastic, or metal, but the reason I chose the foam is because it is VERY easy to work with and shape. I would definitely use the foam again.
    I am looking forward to seeing any pictures if anyone else has tried this... I'm sure others will modify it to their liking...
    Now for the pictures:
    This is the glue I used where the tape meets the foam. The cover is a little dirty, but you will get the idea:
    IMG_3893_5a02a35fd7f047a95062fe522318638297042bb8.jpgIMG_3894_b63e9c5a555042259aafe7f7b7bfec49156df981.jpgIMG_3895_f5989159568bcb0a6fce8acc65246f5a44ed50be.jpg
    Here is the support I made for the last foot. I taped the top of the angle so there won't be any sharp edges, and I used the bolts that are already in the truck to hold them:
    IMG_3885_4e72deb91658f580b2a8086b123ebfeb86dae568.jpgIMG_3886_461e16dab7c34f086f0a29ca4ed53dde5bae9424.jpg
    As stated earlier, I have had this thing on for over 3000 miles with no problems. The only time I was concerned about it is when we were driving through a storm that had very strong gusts of wind coming at the truck from the side... But It held up good. I drove across the country from Arkansas to Colorado and back without any problems... Here is a link to another post I made with pictures from the trip (note the tonneau cover).
    http://www.tacomaworld.com/forum/off-roading-trails/107226-colorado-trip-ton-pictures.html
    PistonHead81 and Ben Benson like this.
  2. Jul 15, 2010 at 11:31 AM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    Great job!
  3. Jul 15, 2010 at 11:31 AM
    ShaShasBoo
    ShaShasBoo Well-Known Member
    Casey
    Lexington, KY
    06 DC Prerunner
    Damn. Looks good.
  4. Jul 15, 2010 at 11:32 AM
    Snowmang
    Snowmang Well-Known Member
    Jacob
    09 grey sport
    Exhaust billy 5100's smoked headlights and taillights.
    good job mang!
  5. Jul 15, 2010 at 12:03 PM
    toemoss
    toemoss Member
    Thomas
    Iowa
    06 4x4 TRD Sport doublecab
    I know what I am trying this week :)
  6. Jul 15, 2010 at 12:05 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    ive been wondering if this was possible....now i just have to get a day free and a hundi bucks.
  7. Jul 15, 2010 at 12:11 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    wow, cheap, simple, effective. I like.
  8. Jul 15, 2010 at 12:12 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Nice work. Maybe this should go in the cheap/free mods.
  9. Jul 15, 2010 at 12:15 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    thats flippen awesome. :D
    never thought about that.
  10. Jul 15, 2010 at 12:15 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Very nice!
  11. Jul 15, 2010 at 12:17 PM
    Dr. Pepper
    Dr. Pepper Well-Known Member
    Tampa, Florida
    08 PreRunner SR5
    Thats cool man, great job..looks good!
  12. Jul 15, 2010 at 12:51 PM
    Snake~
    Snake~ Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    Dude, that is genius! Nice job!
  13. Jul 15, 2010 at 12:52 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    pretty neat job
  14. Jul 15, 2010 at 12:54 PM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Not too bad. Let us know how that foam holds up at highway speeds!
  15. Jul 15, 2010 at 12:56 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    Props on the workmanship! Thanks for the write up. :thumbsup:
  16. Jul 15, 2010 at 12:56 PM
    DizzyZ
    Dennis
    Paragould, AR
    Yeah! That is the only thing I'm worried about, but it is pretty sturdy... I've had it up to 60mph without any problems... Those latches hold it down pretty tight, and the aluminum channel keeps it pretty rigid.
  17. Jul 15, 2010 at 12:58 PM
    NraFan
    JT
    SoCal
    Thats good. I hope it lasts. Pretty good idea and nice job!
  18. Jul 15, 2010 at 1:01 PM
    DizzyZ
    Dennis
    Paragould, AR
    I'll be taking it on a trip from Arkansas to Colorado and back in the first week of August... I'll let you know how it performs when I get back.
  19. Jul 15, 2010 at 1:04 PM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    Nice job- why not get some vinyl at the fabric store and glue that on to make it more permanent? I'm sure you can find a color match as well...?
  20. Jul 15, 2010 at 1:05 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    Wow that's awesome! I may have to do this....If I can ever find a Tacoma :/
