Homemade skid plates?
Discussion in 'Off-Roading & Trails' started by NC15TRD, Feb 10, 2013.
  1. Aug 26, 2020 at 2:16 PM
    #441
    665.0coupe
    665.0coupe Well-Known Member
    Luke
    Kansas
    2020 DCSB OR MT
    Did you verify this for a 3rd gen?
  2. Aug 26, 2020 at 2:28 PM
    #442
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    IIRC they bolt up the same, as the Allpro skids state 05+. YMMV
    665.0coupe[QUOTED] likes this.
  3. Sep 12, 2020 at 11:43 AM
    #443
    JDUB-Fabrication
    JDUB-Fabrication Well-Known Member
    Newburgh NY
    2010 Lexus GX460
    Created a PDF from the digital file, going to print and cut out of cardboard for exact fit. Might play with the edges for a more custom look. Once it's done and on the truck, I will post the DWG, DXF or whatever format people want.
    After crawling under the truck a few weeks ago it does seem the measurements are correct. I'd rather pay 5 bucks for a print from staples than waste metal. So prototype out of cardboard here I come, then ill CNC plasma the actual 3/16 plate.
  4. Sep 12, 2020 at 6:46 PM
    #444
    665.0coupe
    Luke
    Kansas
    2020 DCSB OR MT
    A dxf would be awesome! Any chance you could post a stp file as well?
    Pyrotech likes this.
  5. Sep 12, 2020 at 8:29 PM
    #445
    JDUB-Fabrication
    Newburgh NY
    2010 Lexus GX460
    Never exported to .stp I’ll check soon and report back. I use Rhino for modeling seems to be able to export to most formats.
  6. Sep 13, 2020 at 5:04 PM
    #446
    665.0coupe
    Luke
    Kansas
    2020 DCSB OR MT
    A .stp or .step is what is usually used to go between 3d modeling software.
  7. Oct 1, 2020 at 11:23 AM
    #447
    JDUB-Fabrication
    Newburgh NY
    2010 Lexus GX460
    Mocked up the foam core today. Lookin good. Now to cut it on the CNC plasma!
    Can definitely say it fits on a third gen.
    Tocamo, zCheech, Pyrotech and 3 others like this.
  8. Oct 1, 2020 at 11:31 AM
    #448
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you going to add reinforcement ribs? Makes a big difference in strength and doesn't add much weight at all.
  9. Oct 1, 2020 at 11:43 AM
    #449
    JDUB-Fabrication
    Newburgh NY
    2010 Lexus GX460
    Most definitely!
    EatSleepTacos[QUOTED] likes this.
  10. Oct 1, 2020 at 11:43 AM
    #450
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Excellent. I have 3/16 steel and even with reinforcements, my IFS is a bit wavy looking from getting beat on so much. I wouldn't want to imagine without the reinforcements.
  11. Oct 7, 2020 at 1:29 PM
    #451
    Pyrotech
    Pyrotech Well-Known Member
    yes, but the size is a little small at 19" OAL and 15" max for 3/16"
    but it is a great little tool, have one on my shop and have played around with 3d printed tooling for it
  12. Oct 7, 2020 at 1:41 PM
    #452
    Pyrotech
    DWG file would be awesome...
    665.0coupe and Canadian Joe like this.
  13. Oct 16, 2020 at 4:17 PM
    #453
    JDUB-Fabrication
    Newburgh NY
    2010 Lexus GX460
    Makin moves! Modified the file a little bit, added some flare and the oil filter trap door. Got it all cut and 3 of the 4 side bends done. Went with a perforated cut.
    Shit, the long thin bends are a bear, wishing I had just cut and welded those instead. The other bends are not so bad. Going with 75 degrees instead of 90 on the edges. Anyone think that will hurt the structure over a 90 bend?
    Tryin to get this done before an off-road park meet up next weekend!
    89A2A24C-2156-4EA7-9C68-AE502592EE19.jpg A559CDBC-FF57-4C88-8171-BC27D7C354A1.jpg
    zCheech, Mech1txs, 665.0coupe and 7 others like this.
  14. Oct 16, 2020 at 4:21 PM
    #454
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Looks awesome. And no, I don’t think that 15° is going to make any discernible difference.
  15. Oct 27, 2020 at 3:54 PM
    #455
    JDUB-Fabrication
    Newburgh NY
    2010 Lexus GX460
    Finally finished the front skid, with the paint still wet I slapped it on and headed to the trails. Worked great! Bashed it quit a few times. Might add some more reinforcements right in the front angle. Seemed to take the most abuse.
    Ended up needing to move the rear mounts back about 1/2 inch. Going to re measure now that I have some time and amend the file I made to post that for people.
    2A0FF114-5796-420E-91FC-05073D44502A.jpg ADD0C503-1BB6-4721-BF79-E05B3F2CE054.jpg
  16. Oct 28, 2020 at 12:23 PM
    #456
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    Did you have those when we were at mettowee?
    Slashaar likes this.
  17. Oct 28, 2020 at 1:58 PM
    #457
    JDUB-Fabrication
    Newburgh NY
    2010 Lexus GX460
    Yes sir, and they definitely took some abuse.
  18. Oct 28, 2020 at 2:19 PM
    #458
    665.0coupe
    Luke
    Kansas
    2020 DCSB OR MT
    Looks great!! I can't wait for a step file!
  19. Oct 29, 2020 at 8:29 AM
    #459
    JDUB-Fabrication
    Newburgh NY
    2010 Lexus GX460
    So I moved the rear mounting holes back 1/2 an inch. I haven't cut a skid since I made the change, so IF YOU USE THIS PLEASE REPORT BACK. I made the mounting holes 1.5 inches ID, so I can slide a 1.5inch OD tube in and weld from the bottom.
    I included all the accouterments. I ended up bending the sides to 75 degrees, the front two bends at 25 degrees, and the back to 30. I used the 25-degree angle to make the upright supports. I ended up cutting the perforation as open curves on the plasma. If and when I do this again, I would probably just cut and weld the side pieces, the big ones were not bad to bend but the sides sucked, and I don't like how the plate is a bit wavy from some bends, some welds, kind of rippled. I would rather a strait weld or a strait bend line.
    If anyone wants additional formats let me know, it won't let me upload a .dxf or .stp, so message me your email and ill send it along. I use Rhino for modeling so I also have it in .3dm.
    *For anyone that's interested: I am willing to cut these on my CNC plasma and sell them as DIY kits, or fully fabricated (unpainted).*
    *Local pickup only, I’m in the NY/NJ area message me for further details or questions.*
    File UPDATED 11/18/2020
    Parras, zCheech, Jojee117 and 10 others like this.
  20. Nov 3, 2020 at 3:25 PM
    #460
    Zoey'sTaco
    Zoey'sTaco Art Jockey
    Noah
    Dirty Jersey
    2020 DCSB SR5, Daily, camper-hauler, blizzard chaser, rock bouncer, tool box
    6112/5160/Maggie SC Hammer Hangers Tom Woods 1 piece Shaft ARE-DCU ARE HD leafs Rear Seat delete
    PM'ed. Im a local NJ artist and Teacher. I have a 2020 with decent rubber and upgraded legs but naked belly. Need halp. This is super cool that you're putting your work out there for others to glean/add to. Great work.
    corgimas likes this.
