homemade longboard
Discussion in 'Sports, Hobbies & Interests' started by jacobigindi, Jan 27, 2012.
  1. Jan 27, 2012 at 11:30 AM
    jacobigindi
    jacobigindi [OP] Well-Known Member
    Jacob
    Socal
    '11 SR5 5 lug AC
    Hey all, so i used to have a sector 9 coconut, but alas, she caught a bad case of delamination and died. She will be greatly missed. :( I bought a 25 inch deck from ehlers longboards and put some 9" chargers trucks and 76mm wheels on it. But i realized i definitely needed a longer board for cruising and downhill so after futsing around with an old element deck, i decided to bite the bullet and build a shlongboard. Its a standard skateboard deck i got on Amazon for 15 bucks and i made cutouts at the ends for bigger wheels. The board was alot weaker when the trucks were mounted at the ends, so i found some scrap 18 gauge steel and riveted it to the bottom of the deck using the original truck mounting holes and some new ones along the centerline i put in. That way the flex of the deck is limited by the tension in the steel. so its fairly flexy up to a certain point. I threw some old royals trucks on the ends and they work pretty well because of the angle they're mounted at. I have the 76mm wheels from ehlers longboards and the free abec 7's that came with it. I'll probably get some better bearings later. so far I'm lovin how low it is to the ground. The deck is about 2.5 inches off the ground, so its super easy to push and its super stable downhill. enjoy :D
  2. Jan 27, 2012 at 11:32 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    That ^^^ is cool!
  3. Jan 27, 2012 at 11:46 AM
    jacobigindi
    Jacob
    Socal
    '11 SR5 5 lug AC
    thanks man :D
  4. Jan 27, 2012 at 11:58 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    thats pretty sweet man. ive been thinking about making a longboard too but never thought about using a regular skateboard and cutting it.
