Homemade bull bar designs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Reney, Sep 22, 2021.
  1. Sep 22, 2021 at 11:49 AM
    Reney
    Reney [OP] Member
    1998 Toyota Tacoma TRD
    Anybody made homemade bull bar/grill guard for their Tacoma? I’m in the early stages of planning one and it would be nice to see different designs, mounting ideas etc. Mine is a 98 but that particular part probably is t terribly important.
  2. Sep 22, 2021 at 12:24 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  3. Sep 22, 2021 at 2:07 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The year of the truck only plays into things when buying a bumper.
    Since your building your own you can see what your dealing with
    What Ideas do you have??
  4. Sep 22, 2021 at 2:33 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    There are several threads where people have built their own bumpers, or build ones from commercially available DIY "kits".
    Search around with the search feature, you'll find them.
    The link @Black DOG Lila posted is a great starting point as well.
  5. Sep 22, 2021 at 2:48 PM
    Reney
    Reney [OP] Member
    Yeah that’s what I figured to do was build it around what’s there, just haven’t seen what people have done with them. In high school my welding teacher built one for his Ford ranger and then later on for his Nissan Frontier. They both looked similar but were obviously different. They consisted of a couple steel pipes welded in between two contoured steel sides. Probably was like a 3” pipe and a 2” but I’m not sure and I don’t have pictures of course. I see the two mounting holes in the front of the frame but I’m not sure that is going to provide a sufficient amount of strength. Although I’m sure that’s where the majority of the manufactured grill guards and bull bars get mounted to.
  6. Sep 22, 2021 at 5:12 PM
    Bivouac
    Quite a few use the front tow hook bolts just get longer bolts and put the tow hooks back on .
    then removing the crush cans I weld a plate on there with a 12mm 1.25 weld nut that gives you 3 m12 bolts on each side
    should be plenty but for real serious winching
  7. Sep 23, 2021 at 6:38 PM
    Reney
    Reney [OP] Member
    Yeah I looked at it tonight and I think that’s a good plan. Probably will do something of the like…
  8. Sep 23, 2021 at 6:42 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I built my own ARB clone.
    I think I the build pics link in my signature. (Turn phone sideways for it to be visible)
