Homelink rear view mirror
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mmatheny, Aug 21, 2017.
  1. Aug 21, 2017 at 7:20 AM
    mmatheny
    mmatheny [OP] Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    So my Taco didn't come with a Homelink mirror. Can one be purchased and will the power plug on the back of my current mirror (with compass and auto dimming) plug right into the new mirror? What year models will fit my '17? Thinking a junk yard.
  2. Aug 21, 2017 at 7:25 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Don't know the answer but I do NOT like the home link.
    If someone broke into my truck or if you leave your window down or doors unlocked. Bad guy can open your garage too because your truck key isn't require to make it operate.
    Unless theyve changed. Good luck!
  3. Aug 21, 2017 at 7:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    Choco_Taco and cliffyk like this.
  4. Aug 21, 2017 at 7:32 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    If you install an aftermarket, it doesn't work unless the ignition is in the "ON" position.
    You should be able to get any aftermarket unit you like, so long as it mounts on the standard bracket glued to the windshield. You can forgo the Toyota part, and just find an aftermarket one. Nothing cleaner than a factory looking install, and plus homelink has no batteries to replace and controls 3 doors!
    I think you will be hard-pressed to find a plug and play one at the junkyard.
  5. Aug 21, 2017 at 8:05 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Only if an idiot installs it. I've had homelink from factory in 4 vehicles, and retrofitted in another vehicle. They all work off the ignition, including the tacoma. It's the battery powered garage door openers that are the problem.
    I'm would place a bet that the wiring is there, but I can't confirm that. 2016/17 Limited & Pro have the mirror you are after (homelink / auto dimming / compass). But, you could make any homelink minor work (thousands on eBay), you'd probably just have to change the tab that's glued to the windshield and change the wiring connector.
  6. Aug 21, 2017 at 8:07 AM
    bradshawnh
    Boston, MA
    Good luck getting that tab off the windshield, 9 times out of 9 it will break the windshield glass first. DO NOT TRY.
    I'm pretty sure the Tacoma uses the mostly-standard teardrop shaped mount, a lot of other brands use the same one. I'd just spend the bucks on the right one from a Limited or another Toyota product that's plug and play.
  7. Aug 21, 2017 at 8:08 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Seems Gentex makes plug and play mirrors that plug right in. Might go that route! Thanx guys.
  8. Aug 21, 2017 at 8:09 AM
    bradshawnh
    Boston, MA
    Gentex is a great brand. Good luck.
    Heepspo likes this.
  9. Aug 21, 2017 at 8:11 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Gentex is who makes the mirrors for most OEMs. Amazon has the correct mirror for $500 (half of what the dealer charges). It's supposedly plug and play if you already have the self-dimming/compass mirror.
    Serenity Driver likes this.
  10. Aug 21, 2017 at 8:17 AM
    csmacomber
    csmacomber Well-Known Member
    Arizona
    2017 Inferno DCSB OR MT 4x4
    I purchased a Gentex one for my OR, and it was about 2 minutes to install. Unplug mirror that came in the truck, remove from mount, put new mirror on, and plug in. This is the one I got: Gentex GENK45AM4 Auto-Dimming Mirror with HomeLink and Compass
    The only problem I had was programming it. It didn't like learning the programming from my universal remote and I don't own the original remote for the door anymore. I had to borrow my Father-in-Laws factory remote (he has the same door as I do) and the program it with my code.
    yub likes this.
  11. Aug 21, 2017 at 8:20 AM
    bradshawnh
    Boston, MA
    I agree, programming homelink to a modern day rolling-code opener is an annoyance. First pair remote to car, then car to garage...makes no sense.
  12. Aug 21, 2017 at 8:24 AM
    Radarninja
    Northern California
    06 taco
    I suppose mine was made at the factory on a Friday or Monday because it doesn't require ignition on.
  13. Aug 21, 2017 at 8:26 AM
    mutely
    It's easy, just apply a small amount of heat to the tab with a butane torch, wait a few seconds for the heat to melt the glue, twist it and it'll come right off with ease. It's when you pull them they can break the windshield. I've done it multiple times, never broken a windshield.
    But as you said it's a lot easier using the right mirror / tab, I was just giving the OP some cheaper / easier options.
  14. Aug 21, 2017 at 8:28 AM
    mutely
    Your Tacoma on a factory mirror, not dealer / distributer installed?
  15. Aug 21, 2017 at 8:32 AM
    mutely
    Gentex made the OEM one in my Tundra and wife's Subaru, I also retrofitted a Gentex in another vehicle. No sure if the Tacoma is Gentex, but it's a good product / manufacturer.
  16. Aug 21, 2017 at 8:45 AM
    nevadawolf03
    nevadawolf03 Well-Known Member
    PNW
    2016 SR5 DCLB
    SR wheels, side marker black-out, Clazzio's, Tweeters, Tailgate inserts, interior vinyl inserts
  17. Aug 21, 2017 at 8:47 AM
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    Nevermind the fact that most probably have a garage door opener in their vehicle that opens the garage without truck power anyway.
    echomonkey, jptheriot and Lateralus01 like this.
  18. Aug 21, 2017 at 8:50 AM
    csmacomber
    Arizona
    I only have the mirror. And I don't believe it works without the key turned on (but I don't really care either as my truck always spends the night in the garage). I can test to verify when I get home as everything is factory on my truck except for the actual mirror itself.
  19. Aug 21, 2017 at 9:00 AM
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    I used the mirror from a 2013 Subaru Outback. I wired it specifically to be on all the time, not because I care one way or the other about the garage door opener being on or off with the ignition on, but because I hate having to turn off the damn compass in the mirror every single time I turn the truck on. BTW, the Subaru mirror is a direct replacement and the compass shines through the mirror in red as opposed to the Toyota one that has a little window in the mirror for the compass in blue.
  20. Aug 21, 2017 at 9:12 AM
    JTS2016TACO
    Jamie
    Chandler, AZ
    Let us know as I'm curious if it works with the truck off, it doesn't matter to me either way as it would be annoying to me to have to turn on the truck to open the garage if I were to leave in any other vehicle and leave my truck at home. (my truck sits outside though)
