Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 23, 2023 at 6:09 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Great thought.
    I gave up 100% on decks in the PNW. Yeah I need to pressure wash my concrete every couple years, but that's NOTHING compared to deck maintenance.
  2. Jun 23, 2023 at 6:10 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    I mean I actually don’t see much rot. That one piece yes but overall solid. Am I missing something?
  3. Jun 23, 2023 at 6:14 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I desperately want to do a bunker back yard deck. Tony Stark 7’ shop w patio at door height. All concrete. I am WT at heart.
    F this thing.
  4. Jun 23, 2023 at 6:49 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Decks are temporary structures no matter how well you build them
  5. Jun 23, 2023 at 8:42 PM
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    No. We actually had several plans made up to 1) eliminate deck altogether, 2) half deck to provide a couple steps out the door before stepping down, 3) raised paver patio and 4) complete composite replacement. Going with complete replacement. As much as I wanted to do away with the whole thing, it just works better all round and wife has final say.:ballchain:
    soundman98 and dumontrider like this.
  6. Jun 23, 2023 at 8:43 PM
    Denk
    PNW
    Yeah. There were several other spots with rot at least half way through the beam. I didn't get all the pics.
  7. Jun 23, 2023 at 9:15 PM
    Bill0351
    Bill0351 Well-Known Member
    Bill
    2023 SR V6 4x4
    Tires/Cap
    Converting a deer stand to a 400 yard bench rest range for my Dad. 5A73A2CD-B0A8-45FE-935E-F92AF95A8038.jpgB2A3F337-2C1B-4D07-9076-0FBD4C8B5053.jpg226D36A8-E12E-45C5-9A9E-221A5C85A6C6.jpg
    Sig45, mbarbay, shakerhood and 11 others like this.
  8. Jun 24, 2023 at 7:12 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Take guests?;)
  9. Jun 24, 2023 at 3:32 PM
    Denk
    PNW
  10. Jun 24, 2023 at 7:26 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    measuring voltage in this situation is like bragging you get to drive a 700HP hellcat in a 20mph school zone...
    you need a clamp meter to measure the current/ampacity. voltage plays almost no part in the concern you have.
    theoretically, we could calculate the voltage drop by measuring the voltage at the disconnect, as well as at the main panel, and then use that in a formula for distance to come up with an anticipated ampacity of a 10ga wire.
    or we can just measure the ampacity.
    this is why asking the internet for trade-specific advice can turn really ugly really fast for those that don't actually know.
    i was an electrician for 12 years...
    first, this is not 120v circuit. this is a 240v circuit with a ground. the white wire is a current carrying conductor, and is no longer a neutral conductor.
    second, this is a very standard situation, where they used a grounded 2-wire, with a black/white wire in it. NEC has an exception in it that firstly allows this type of wire to be ran, but secondly also calls for the white wire to to be re-identified as a black current carrying conductor to indicate it is no longer an appropriate current return path.
    the trane document you posted indicates that the current ampacity requires 28A, with a max breaker of 50A. nec also requires circuits to be loaded no more than 80% of the wires ampacity. 10 gauge wire is rated up to 30A, or 24A max.
    you really need new 8gauge wire ran to support that a/c size, however, the installation with the breaker, or the re-labeled wire is not entirely wrong. just the incorrect wire sizing for the size of the unit.
  11. Jun 24, 2023 at 8:32 PM
    soggyBottom
    soggyBottom Well-Known Member
    I don't have a current clamp so my point was that 1) it's not 120v and 2) the voltage isn't sagging much with the small wire. Thanks for the feedback on the wire size.
    Pablo8 likes this.
  12. Jun 24, 2023 at 9:35 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Well stated.
  13. Jun 26, 2023 at 11:57 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Deck stairs were a bit soft on the edge. As it was “investigating” the step became detached from the stringer. Not what I planned for a Sunday but it’s fixed for the party next week.
    Following the rotten wood theme…..
    Framed with correct PT wood.
    Good as new(ish)
  14. Jun 27, 2023 at 11:35 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Back bedroom door used to look like a 5 year old stained and cleared it, stripped it down, put new stain and clear on it.
  15. Jun 29, 2023 at 6:20 AM
    Roll_Terps
    Roll_Terps Well-Known Member
    Maryland
    2017 SR DCSB White
    forgot to take progress photos, but it’s done. Pretty happy with how it came out and had a bunch of thunderstorms without introducing water to the basement, so I think the waterproofing plan is working
  16. Jun 29, 2023 at 8:28 AM
    jsi
    jsi Well-Known Member
    native earthling
    Tiling question - I tiled the back splash behind my range level with the counter top. But the new range is a different style and has exposed part of the wall that was previously hidden. I have left over tile for the spot, but I don't have any thin set or grout. There are any number of inexpensive ways to stick literally 2 tiles to a wall that will never see water, but what about inexpensive grout? I used the $54/tub fancy pre-mixed stuff on the rest of the wall. The dry mix version is $20/bag. All I need is maybe 1/4 cup to finish what I should have done to start with. Any suggestions on what to do?
    wilcam47 likes this.
  17. Jun 29, 2023 at 8:30 AM
    wilcam47
    Will
    Bourbon state
    Liquid nails and painters tape to hold it in place
  18. Jun 29, 2023 at 2:59 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Been working on this deck all week. House is on the Maine coast. Replacing the old PT with Western Red Cedar. Should wrap up that last section tomorrow. Using 316 SS #9 x 3" deck screws. I like the slightly smaller head on the #9 vs #10.
  19. Jun 30, 2023 at 11:58 AM
    Sig45
    Mark
    Maine
    Done just in time for the long holiday weekend. Client is very happy.
    jubei, Bagman, Kanyon71 and 16 others like this.
  20. Jun 30, 2023 at 12:00 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Looks awesome!!
    Sig45[QUOTED] likes this.
