Hitting Oversized Pot Holes... Damage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 122032, Mar 14, 2014.
  1. Mar 14, 2014 at 2:03 PM
    122032 [OP] Member
    Josh
    Minnesota
    13 TRD Sport DC
    Anyone else get overly angry when you hit a pot hole you don't see? Minnesota has the worst after the winter hits.
    I hit a few in a row (at night couldn't see) that were about 6-8 inches deep at about 20-25 MPH. The truck hit them pretty hard. I drove by them this morning and it looks worse than how I felt I hit them. I visually inspected the front end under carriage of my truck and no scrape marks are visible.
    I'm paranoid that I may have damaged something. :mad:
  2. Mar 14, 2014 at 2:06 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You can cause damage from hitting overly large pot holes but you'd likely know it pretty quickly. Either your alignment would be way out or you'd have damage to the wheel or tire that you'd see and/or feel.
  3. Mar 14, 2014 at 2:08 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Could have damaged something, but how bad and how soon till it breaks? That's hard to know. Is it tracking straight? If not get an alignment. I think every state that has been under a blanket of white for the past 4 months has ridiculous potholes right now.
  4. Mar 14, 2014 at 2:14 PM
    122032 [OP] Member
    Josh
    Minnesota
    13 TRD Sport DC
    No wobble in the steering wheel and it drives straight. What is the worst case scenario here?
  5. Mar 14, 2014 at 2:45 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Took a few thousand miles off the ball joints and shocks probably. Check your tire sidewalls for a chunk missing. If everything else is as it was before you hit the potholes, then you lucked out for now.
  6. Mar 15, 2014 at 4:07 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I wouldn't worry about it, especially going that slow. Like Pugga stated, you would notice a shimmy or alignment issue due to damage tire/wheel or off alignment. Just do a visual on the tires/wheels. Some shops like NTB or Firestone can check your alignment for free.
  7. Mar 15, 2014 at 6:59 AM
    burnout524
    burnout524 Member
    Highly unlikely, but you could have cracked a rim. It happened to me a long time ago...the only reason I found it was because I had a slow tire leak. When I decided to take the wheel of to get it replaced, I noticed a huge bulge on the sidewall (not on the street side) and a crack in the rim right under it. :eek:
  8. Mar 15, 2014 at 9:13 AM
    Roasty
    Roasty Member
    PA
    2013 AC
    Eastern PA its really bad around here my tacoma has hit a few and is fine I did blow out a side wall and dented my rim in my old scion tC those low profile tires were horrible around here.
